Home » Archived » BIRT » rptdesign file changes for connection pool
rptdesign file changes for connection pool [message #119535] Mon, 30 January 2006 04:07 Go to next message
Originally posted by: kerem.ersoy.m2m.com.tr
Hi!
I was following Mr.Jason Weathersby's "using a supplied connection with
BIRT" blog post.
I am getting "java.lang.NoClassDefFoundError:
org/eclipse/birt/report/data/oda/jdbc/OdaJdbcDriver" error.
I suspect I am using the wrong attributes in my design file. What should the
values of <data-sources> tag be?
Re: rptdesign file changes for connection pool [message #119945 is a reply to message #119535] Mon, 30 January 2006 07:59 Go to previous messageGo to next message
Kerem,
I will upload this example today.
Jason Weathersby
BIRT PMC
"Kerem" <kerem.ersoy@m2m.com.tr> wrote in message
news:drkl80$13g$1@utils.eclipse.org...
> Hi!
> BIRT" blog post.
> the values of <data-sources> tag be?
Re: rptdesign file changes for connection pool [message #120339 is a reply to message #119535] Mon, 30 January 2006 12:58 Go to previous messageGo to next message
Kerem,
Here is the example from the Birtworld posting.
Jason
> Hi!
> BIRT" blog post.
> the
Re: rptdesign file changes for connection pool [message #153548 is a reply to message #120339] Thu, 13 April 2006 16:13 Go to previous messageGo to next message
Originally posted by: lei.chen.optimalpayments.com
Hi Jason,
I'm trying to get your example working with Weblogic 8.1, but I'm
getting the following error. Note in my report SQL there are IN
parameter defined as '?'s.
When I used the default OdaJdbcDriver, everything seems to work fine.
I wonder whether SubOdaJdbcDriver is doing something weird there.
Lei
There are errors on the report page:
- There are error(s) in report : report
Error0 : odaconsumer.CannotGetResultSetMetaData ( 1 time(s) )
detail : org.eclipse.birt.data.engine.core.DataException: Cannot get the
result set metadata.
SQL statement does not return a ResultSet object.
Missing IN or OUT parameter at index:: 1
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.g etRuntimeMetaData(PreparedStatement.java:379)
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.g etProjectedColumns(PreparedStatement.java:339)
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.s etColumnsProjection(PreparedStatement.java:1028)
org.eclipse.birt.data.engine.executor.DataSourceQuery.prepar e(DataSourceQuery.java:315)
org.eclipse.birt.data.engine.impl.PreparedExtendedDSQuery$Ex tendedDSQueryExecutor.prepareOdiQuery(PreparedExtendedDSQuer y.java:277)
org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.pre pareExecution(PreparedQuery.java:672)
org.eclipse.birt.data.engine.impl.PreparedQuery$Executor.acc ess$000(PreparedQuery.java:498)
org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(Pr eparedQuery.java:225)
org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.ex ecute(PreparedDataSourceQuery.java:145)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.execut e(DteDataEngine.java:205)
org.eclipse.birt.report.engine.executor.QueryItemExecutor.op enResultSet(QueryItemExecutor.java:62)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:122)
org.eclipse.birt.report.engine.executor.ReportExecutorVisito r.visitTableItem(ReportExecutorVisitor.java:187)
org.eclipse.birt.report.engine.ir.TableItemDesign.accept(Tab leItemDesign.java:69)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:125)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:89)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:175)
at jsp_servlet._birt.__run._jspService(run.jsp:112)
at weblogic.servlet.jsp.JspBase.service(JspBase.java:33)
weblogic.servlet.internal.ServletStubImpl$ServletInvocationA ction.run(ServletStubImpl.java:996)
weblogic.servlet.internal.ServletStubImpl.invokeServlet(Serv letStubImpl.java:419)
weblogic.servlet.internal.ServletStubImpl.invokeServlet(Serv letStubImpl.java:315)
weblogic.servlet.internal.WebAppServletContext$ServletInvoca tionAction.run(WebAppServletContext.java:6452)
weblogic.security.acl.internal.AuthenticatedSubject.doAs(Aut henticatedSubject.java:321)
weblogic.security.service.SecurityManager.runAs(SecurityMana ger.java:118)
weblogic.servlet.internal.WebAppServletContext.invokeServlet (WebAppServletContext.java:3661)
weblogic.servlet.internal.ServletRequestImpl.execute(Servlet RequestImpl.java:2630)
at weblogic.kernel.ExecuteThread.execute(ExecuteThread.java:219 )
at weblogic.kernel.ExecuteThread.run(ExecuteThread.java:178)
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL
org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery (Statement.java:342)
org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaData( Statement.java:296)
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.doGetMetaData(OdaQuery.java:387)
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQu ery.getMetaData(OdaQuery.java:355)
org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.g etRuntimeMetaData(PreparedStatement.java:369)
... 28 more
Caused by: java.sql.SQLException: Missing IN or OUT parameter at index:: 1
oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseE rror.java:125)
oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseE rror.java:162)
oracle.jdbc.driver.OraclePreparedStatement.processCompletedB indRow(OraclePreparedStatement.java:1536)
oracle.jdbc.driver.OraclePreparedStatement.executeInternal(O raclePreparedStatement.java:2880)
oracle.jdbc.driver.OraclePreparedStatement.executeQuery(Orac lePreparedStatement.java:2926)
weblogic.jdbc.wrapper.PreparedStatement.executeQuery(Prepare dStatement.java:124)
org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery (Statement.java:338)
... 32 more
Jason Weathersby wrote:
> Kerem,
> Jason
>> Hi!
>> BIRT" blog post.
>> the
Re: rptdesign file changes for connection pool [message #153822 is a reply to message #153548] Mon, 17 April 2006 10:57 Go to previous message
Lei,
What is the SQL you are passing in? The Sub example doesnt do anything
specific with it. It only sets the connection variable for the JDBC driver.
Jason
"Lei" <lei.chen@optimalpayments.com> wrote in message
news:443EB0CD.2060109@optimalpayments.com...
> Hi Jason,
> I'm trying to get your example working with Weblogic 8.1, but I'm getting
> the following error. Note in my report SQL there are IN parameter defined
> as '?'s.
> Lei
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 28 more
> at
> at
> at
> at
> at
> at
> at
> ... 32 more
>> Kerem,
>> Jason
>>> Hi!
>>> BIRT" blog post.
>>> the
Previous Topic:Problems with load report from stream and report library
Next Topic:Using run instead of frameset for drill through
Current Time: Thu Jul 17 22:32:05 EDT 2025
Powered by FUDForum. Page generated in 0.08648 seconds
