Chain generation from language1 -> language2 -> java [message #896171] |
Tue, 17 July 2012 13:40 |
Sergio Otero Messages: 39 Registered: June 2012 |
Member |
I'm developing an editor that basically consist of 2 DSLs.
I have 2 separated xtext projects with different file extensions.
The first language "lang1" generates files with extension "lang2" and this last one generates "java"
The only problem i have is that when i write a "lang1" file, "lang2" result is generated in "src-gen", but i need to open that file and write in order to trigger the generation to "java".
Also, when i do a clean of the project, all "java" files are deleted and only "lang2" files are present in "src-gen".
How i could i chain the generation from lang1->lang2->java?
Sergio
FUDForum. Page generated in 0.03498 seconds
