Home » Archived » BIRT » Reg:How to set Page Navigation Property for reports
Reg:How to set Page Navigation Property for reports [message #119481] Sun, 29 January 2006 23:24 Go to next message
Originally posted by: buday.metrikus.com
I've created a report which contains several records(almost 100 - 150
records).
When i'm executing the report, all the recods are displaying in a single
page.
But i w'd like to display records page wise i.e. Some 20 records are in
first page, next 20 records should be displayed in next page and so on..
Is there any way to do this
I'm using BIRT version 2.0.0
Thanks in advance
Re: Reg:How to set Page Navigation Property for reports [message #120177 is a reply to message #119481] Mon, 30 January 2006 13:43 Go to previous message
For HTML reports, you can use the Page Break Interval property to specify
the number of data rows to display per page. To access this property, select
the table, then select Page break properties.
"boni.uday" <buday@metrikus.com> wrote in message
news:5d5f4ff7ffe4d0c6d273d8dac9d96ae7$1@www.eclipse.org...
> records).
> page.
> Thanks in advance
Previous Topic:Using Birt in an RCP application
Next Topic:Problem with renderContext.setImageDirectory(IMAGE_URL)
Current Time: Fri Aug 22 23:44:29 EDT 2025
Powered by FUDForum. Page generated in 0.13345 seconds
