Home » Archived » BIRT » Internal server error
Internal server error [message #119454] Sun, 29 January 2006 23:09 Go to next message
Originally posted by: bek-816.shaw.ca
I've gone through the installation instructions three times to ensure I
didn't miss anything, but I continue to get an "HTTP 500 - Internal server
error
Internet Explorer" when I preview a report (following the flash example).
I read similar threads in the archives and the solution was always to
install the axis jar file. I put my axis jar files (all six of them) in
C:\eclipse\plugins\org.eclipse.birt.report.viewer_2.0.0\birt \WEB-INF\lib
as per the instructions.
Any suggestions? Am I missing something obvious? I have the latest
release version of Eclipse, BIRT, EMF, JRE, GEF, IText, etc.
Thanks.
-Brian
Re: Internal server error [message #119563 is a reply to message #119454] Mon, 30 January 2006 04:33 Go to previous messageGo to next message
Originally posted by: kerem.ersoy.m2m.com.tr
if you have put the birt libraries into jre/lib/ext or your classpath , that
may be causing errors.
"Brian Kates" <bek-816@shaw.ca>, haber iletisinde sunlari
yazdi:77b95388e08a725bb9cc0f6ebd9c8f11$1@www.eclipse.org...
> error Internet Explorer" when I preview a report (following the flash
> example). I read similar threads in the archives and the solution was
> always to install the axis jar file. I put my axis jar files (all six of
> them) in
> Thanks.
> -Brian
Re: Internal server error [message #119835 is a reply to message #119563] Mon, 30 January 2006 09:57 Go to previous messageGo to next message
Originally posted by: bek_816.hotmail.com
No, I haven't done that, at least to the best of my knowledge. I didn't
put the birt jar files anywhere except inside the eclipse folder. Is
there anyway I can turn logging on and see exactly what the error is?
-Brian
Re: Internal server error [message #120190 is a reply to message #119454] Mon, 30 January 2006 15:02 Go to previous messageGo to next message
Did you start Eclipse with the clean option?:
eclipse -clean
"Brian Kates" <bek-816@shaw.ca> wrote in message
news:77b95388e08a725bb9cc0f6ebd9c8f11$1@www.eclipse.org...
> them) in
> Thanks.
> -Brian
Re: Internal server error [message #120214 is a reply to message #119835] Mon, 30 January 2006 15:05 Go to previous messageGo to next message
the log is in "workspace\.metadata\.plugins\org.eclipse.tomcat\". You may
want a clean start first.
Re: Internal server error [message #120592 is a reply to message #120190] Mon, 30 January 2006 21:26 Go to previous messageGo to next message
Here is what I did:
1) Started a 'clean' version of eclipse.
2) Open a birt project
3) Went straight to the preview tab.
Below is my log:
WebappLoader[]: Deploying class repositories to work directory
D:\workspace\.metadata\.plugins\org.eclipse.tomcat\ROOT
ContextConfig[]: Added certificates -> request attribute Valve
StandardManager[]: Seeding random number generator class
java.security.SecureRandom
StandardManager[]: Seeding of random number generator has been completed
StandardWrapper[:default]: Loading container servlet default
StandardWrapper[:invoker]: Loading container servlet invoker
CoyoteConnector Coyote can't register jmx for protocol
WebappLoader[/viewer]: Deploying class repositories to work directory
D:\workspace\.metadata\.plugins\org.eclipse.tomcat\viewer
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/axis-ant.jar to
c:\eclipse\plugins\org.eclipse.birt.report.viewer_2.0.0\birt \WEB-INF\lib\axis-ant.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/axis.jar to
c:\eclipse\plugins\org.eclipse.birt.report.viewer_2.0.0\birt \WEB-INF\lib\axis.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/commons-discovery-0.2.jar
to
c:\eclipse\plugins\org.eclipse.birt.report.viewer_2.0.0\birt \WEB-INF\lib\commons-discovery-0.2.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/jaxrpc.jar to
c:\eclipse\plugins\org.eclipse.birt.report.viewer_2.0.0\birt \WEB-INF\lib\jaxrpc.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/saaj.jar to
c:\eclipse\plugins\org.eclipse.birt.report.viewer_2.0.0\birt \WEB-INF\lib\saaj.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/viewservlets.jar to
c:\eclipse\plugins\org.eclipse.birt.report.viewer_2.0.0\birt \WEB-INF\lib\viewservlets.jar
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/wsdl4j-1.5.1.jar to
c:\eclipse\plugins\org.eclipse.birt.report.viewer_2.0.0\birt \WEB-INF\lib\wsdl4j-1.5.1.jar
ContextConfig[/viewer]: Added certificates -> request attribute Valve
StandardManager[/viewer]: Seeding random number generator class
StandardManager[/viewer]: Seeding of random number generator has been
completed
StandardWrapper[/viewer:default]: Loading container servlet default
StandardWrapper[/viewer:invoker]: Loading container servlet invoker
Any suggestions?
-Brian
Re: Internal server error [message #121701 is a reply to message #120214] Tue, 31 January 2006 11:02 Go to previous messageGo to next message
I attached the log in my reply to Paul. Does anything stand out?
thanks.
-Brian
Re: Internal server error [message #122177 is a reply to message #120592] Tue, 31 January 2006 18:24 Go to previous messageGo to next message
There is no exception logged. Do you still see 500 error?
Re: Internal server error [message #122324 is a reply to message #122177] Tue, 31 January 2006 23:11 Go to previous message
I still the 500 error message...the interesting thing is that I got it
working on my IBM ThinkPad at work, but I can't get it working on my home
computer. The only difference is that at work I use WebSphere whereas at
home I have Tomcat.
Previous Topic:MULTIPLE DATA SETS
Next Topic:Problems with PDF in Production but works fine in test
Current Time: Mon Jul 21 20:09:39 EDT 2025
Powered by FUDForum. Page generated in 0.26329 seconds
