Re: web.xml wrong editing with [message #119955 is a reply to message #119812] |
Tue, 12 July 2005 11:33  |
Ok, it must be a different problem. Assuming you haven't already
figured out the problem, can you post the web.xml, or the portion that's
causing the problem.
Larry
Andy wrote:
> Larry Isaacs wrote:
>> Which version of XDoclet are you using? If not 1.2.3, give that one a
>> try. I believe I saw something like this in an earlier version that
>> was fixed in 1.2.3, but I'm not certain it was the same error.
>> Cheers,
>> Larry
>> Andy wrote:
>>> Hi, I use Tomcat 5.5 eclipse 3.1 wtp m5
>>> Got an error:
>>> cvc-complex-type.2.4.a: Invalid content was found starting with
>>> element 'display-name'. One of
>>> '{"http://java.sun.com/xml/ns/j2ee":servlet-class,
>>> "http://java.sun.com/xml/ns/j2ee":jsp-file}' is expected.
>>> when I use anannotated java classes
> I use XDoclet 1.2.3
FUDForum. Page generated in 0.06113 seconds
