Home » Eclipse Projects » GEF » Anchors and resizing
Anchors and resizing [message #119372] Wed, 25 February 2004 02:15 Go to next message
Hi all,
I have a number of Figures that send Points to their anchors to control
the anchors' locations. The anchors move with the Figures, but when the
Figures are re-sized, the anchor positions don't expand and contract.
I've tried updating the location Points in the Figures' paintFigure()
method, but it hasn't been working. Any thoughts?
I apologize in advance if this has been asked elsewhere, but I hadn't
found it.
Matt
Re: Anchors and resizing [message #119398 is a reply to message #119372] Wed, 25 February 2004 08:23 Go to previous messageGo to next message
Matt,
You needn't update anchor locations in your own code
if your anchor extends the AbstractConnectionAnchor.
Matt wrote on 2004-2-25 15:15:
> Hi all,
> the Figures, but when the Figures are re-sized,
> thoughts?
> elsewhere, but I hadn't found it.
> Matt
Re: Anchors and resizing [message #119722 is a reply to message #119398] Fri, 27 February 2004 07:19 Go to previous messageGo to next message
Originally posted by: josephlee.163.com
implement the following code in you figure.
public void validate() {
if(isValid()) return;
//you can use getSize method to get the new location of your figure.
layoutConnectionAnchors();
super.validate();
hope these can give you some suggestions.
Ryan Pu wrote:
> Matt,
> > Hi all,
> > thoughts?
> > Matt
Re: Anchors and resizing [message #119798 is a reply to message #119722] Sat, 28 February 2004 07:43 Go to previous message
You should not do like that. You needn't code in figure if
your anchor extends AbstractConnectionAnchor. Because when
figure translated or moved, Figure#fireMoved() will be
called, thus listener added by AbstractConnectionAnchor
will notify listeners of connections to update. And as a
result, the connections will call the anchor's
getReferencePoint() and getLocation() again to get a newer
location.
joseph wrote on 2004-2-27 20:19:
> your figure. layoutConnectionAnchors();
> super.validate();
> Ryan Pu wrote:
>> Matt,
>> > Hi all,
>> > thoughts?
>> > Matt
Previous Topic:Re: refresh the label's content
Next Topic:WorkspaceModifyOperation class missing.
Current Time: Mon Sep 01 05:19:19 EDT 2025
Powered by FUDForum. Page generated in 0.04702 seconds
