Re: Grid Display [message #894852 is a reply to message #894654] |
Tue, 10 July 2012 18:57 |
A R Messages: 104 Registered: April 2012 |
No, grid is not in table. I have grid with 2 coulmns and 4 rows. In each cell I have embedded a report, which contains a table and chart. My table is hidden and chart is visible.
Mr. Williams , please let me know if any details required further.
AR
[Updated on: Tue, 10 July 2012 19:09] Report message to a moderator
Re: Grid Display [message #894856 is a reply to message #894852] |
Tue, 10 July 2012 19:28 |
I am able to see the required display by using two separate grids for tables and charts.
I wanted to know does this create any issue ? Because, here input to my chart is table. I am using a script to populate the values from table to chart in required manner.
Friends please respond with ur suggestion.
AR
[Updated on: Tue, 10 July 2012 19:39] Report message to a moderator
Re: Grid Display [message #895166 is a reply to message #895151] |
Wed, 11 July 2012 20:45 |
Can you reproduce the issue using the sample db and then post the report?
Jason
On 7/11/12 4:04 PM, A R wrote:
> Version: 2.6.1.v20100618-3507w31211924
> Build id: v20100915-1750
Re: Grid Display [message #902421 is a reply to message #902305] |
Fri, 17 August 2012 14:24 |
I do not think so.
Jason
On 8/16/2012 6:20 PM, A R wrote:
> Hi Jason - Sorry for the delay in response .
> I tried to reproduce the issue, in different ways. I am able to find the
> same issue when I tried with the different screen resolutions . My
> underswtanding is , display is changing depending on the the screen
> resolution. Correct me if I am wrong.
> Thanks
> AR
FUDForum. Page generated in 0.03450 seconds
