VE performace [message #119342] |
Tue, 28 February 2006 12:46  |
Hi, I love Eclipse, however I find that the performance of VE is still a
lingering problem for me, and in fact has gotten worse with my switch to
linux. First, some platform info:
Eclipse
Version: 3.1.2
Build id: M20060118-1600
eclipse.vm=/opt/j2sdk1.4.2_10/bin/java eclipse.vmargs=-Xmx512M
EMF 2.1.0
GEF 3.1.1
VE 1.1.0
running on linux - Ubuntu Breezy (5.10) with Sun J2SDK 1.4.2 dual boots to
Windows XP with exact same setup
system is P4 3GHz 1GB ram, 2GB linux swap partition (unused according to
System Monitor)
hosts: 127.0.0.1 localhost
Eclipse on Ubuntu was installed manually at /opt/eclipse/ and Sun JDK is
set as my default java - and Eclipse is using this one. I read that this
is the preferred install method, as the Ubuntu packaged Eclipse can
exhibit some unexpected behaviour, such as launching under GNU java
regardless of settings. I have set up multiple Extension Locations so that
I can launch Eclipse with only VE and no other plugins/features to slow it
down.
My goal is to do swing development on Ubuntu, since I find that most
development functions on Ubuntu are WAY faster, however VE on Ubuntu is
actually quite a bit slower. The configs for the winXP and Ubuntu are
identical.
Does anyone know why VE would be considerably slower on linux? Or if there
are tricks/hacks (besides pausing gui rebuilding) to speed up VE?
On a different note, in a JTabbedPane, under WinXP I could simply click
the tab I wanted to work on and VE would rebuild the gui to show me that
tab. Under Ubuntu, clicking the tab does nothing. I have to right-click
the JTabbedPane and select Switch To, select the desired tab. Then I have
to pause and resume VE to get it to actually display the tab. So clearly
there seems to be some real differences between using VE in WinXP and
linux.
Thanks for your thoughts...
Greg
Re: VE performace [message #119443 is a reply to message #119431] |
Tue, 28 February 2006 14:58  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
The problem is that the main eclipse site (which is the default one)
only has 1.1.0 on it. The actual VE update site is a different one, the
1.1.0 points to the real update site for VE, which is where 1.1.0.1 is at.
Greg Renegar wrote:
> Hmm... Seems a bit odd that the initial VE install from the update site
> would install the second most recent version.
> Thanks again for your help.
> On Tue, 28 Feb 2006 14:07:16 -0500, Jeff Myers wrote:
>>Try updating again, unfortunately 1.1.0.1 only shows up after installing
>>1.1.0.
>> - Jeff
Rich Kulp
Re: VE performace [message #612217 is a reply to message #119342] |
Tue, 28 February 2006 13:49  |
Selecting JTabbedPane tabs directly wasn't added until 1.1.0.1. You said
were using 1.1.0. Could it be that you have 1.1.0.1 on Windows and 1.1.0
on Linux?
> linux.
> Greg
Rich Kulp
Re: VE performace [message #612219 is a reply to message #119382] |
Tue, 28 February 2006 13:59  |
> on Linux?
>> linux.
>> Greg
Right you are. It seems that VE 1.1.0 is the latest available (for linux)
via the VE update site. Is that correct? If not, do you recommend manually
updating the VE version?
Greg
Re: VE performace [message #612220 is a reply to message #119406] |
Tue, 28 February 2006 14:07  |
1.1.0.
- Jeff
>> on Linux?
>>> linux.
>>> Greg
> Greg
Re: VE performace [message #612221 is a reply to message #119418] |
Tue, 28 February 2006 14:26  |
> 1.1.0.
> - Jeff
Re: VE performace [message #612222 is a reply to message #119431] |
>>1.1.0.
>> - Jeff
Rich Kulp
FUDForum. Page generated in 0.08366 seconds
