Home » Modeling » GMF (Graphical Modeling Framework) » Diagram code generation generates invalid code
Diagram code generation generates invalid code [message #119283] Fri, 13 April 2007 19:48 Go to next message
Originally posted by: adolfo.correia.siliconstrategy.com.br
I am learning about GMF and I decided to take the GMF tutorial with the
mindmap example (http://wiki.eclipse.org/index.php/GMF_Tutorial).
When I try to generate code for the diagram, eclipse (successfully)
generates invalid code. The error is on the
org.eclipse.gmf.examples.mindmap.diagram.edit.parts.TopicEdi tPart
generated class.
The method in error is:
protected boolean addFixedChild(EditPart childEditPart) {
if (childEditPart instanceof TopicNameEditPart) {
((TopicNameEditPart) childEditPart).setLabel(
getPrimaryShape().getFigureTopicNameFigure());
return true;
return false;
The return type of getPrimaryShape() is
org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel, and there is no
method getFigureTopicNameFigure() in this class.
The strange thing is that the WrapLabel class is an API class and it would
never have a method based on my model (TopicNameFigure is defined on the
Graphical Definition). This seams like a bug to me, but maybe I'm wrong.
Another interesting thing is that the error disappers if I remove the
Feature Label Mapping on the Mapping Definition. So I guess this is the
place to investigate further, but I'm clueless since I'm a GMF newbie.
I'm using Eclipse 3.3M4 and GMF 2.0.0.v20070103 available on the Europa
update site.
Any suggestions on what to do now?
Adolfo Correia
Re: Diagram code generation generates invalid code [message #119466 is a reply to message #119283] Mon, 16 April 2007 07:09 Go to previous message
Hello Adolfo,
Looks like you've used standalone DiagramLabel for TopicName. AFAIU, this
label should be child figure of TopicFiogure..
Alex Shatalin
Previous Topic:Displaying link between 2 models
Next Topic:Can GMF work with dynamic EMF?
Current Time: Mon Jun 02 23:10:58 EDT 2025
Powered by FUDForum. Page generated in 0.08573 seconds
