Home » Language IDEs » Java Development Tools (JDT) » Shift_JIS encoding
Shift_JIS encoding [message #119258] Fri, 21 November 2003 07:37 Go to next message
Originally posted by: amit.khare.wipro.com
My problem is :
I want to edit and compile SHIFT_JIS encoded java files on eclipse. I work
on Windows 2000 machine with eclipse 2.1.2.
By what eclipse recommends , I changed the user settigs ( System setting
s) to Japanese locale. Eclipse now picks up MS932 as the default encoding
and is able to compile all the files.
However I would like to do so in SHIFT_JIS since all the older code is
executed by java -encoding Shift_jis. The code compile on MS932 simply
fails to execute.
Is there any way I could provide the eclipse compiler :
javac -encoding Shift_jis ?
Re: Shift_JIS encoding [message #119815 is a reply to message #119258] Mon, 24 November 2003 01:15 Go to previous message
The way to do it is to:
a) Install the eclipse translation pack 2.1.1
b) restart eclipse.
c) shift_jis ( or any other required encoding ) appears in the encoding
preference for the workbench .
d) select appropriate encoding.
Previous Topic:Eclipse M5 CVS problem
Next Topic:New code formatter question
Current Time: Tue Jul 22 01:33:49 EDT 2025
Powered by FUDForum. Page generated in 0.04885 seconds
