Re: connections leading to nowhere [message #119320 is a reply to message #119240] |
Tue, 24 February 2004 13:49   |
This is what the logic example does, and we borrowed this "laziness" from
VA-Java's composition editor.
If your application really has connections which go across or are within
containers, there are ways of handling this for your specific editor.
"Ingo Koch" <nospam@gmx.net> wrote in message
news:c1fr1l$gk4$1@eclipse.org...
> Hello Group,
> I have 2 nodes, connected with a wire.
> One of these nodes is within a container.
> When i downsize the container that way, that the the node within
> gets out of the bounds of the container, the node disappears. - thats ok.
> But the connection leads into nowhere, exactly there where the node is
> supposed to be...
> I know of the seperate connection layer and that this topic is sure
> problematic,
> but is there a way or are there plans to avoid this - i mean, that the
> connection leads "into" the container and ends at the containers bounds?
> I
Re: connections leading to nowhere [message #119574 is a reply to message #119320] |
Thu, 26 February 2004 09:28   |
Well, the screenshot was from the logic editor and my application
behaves the same way.
What would you suggest to do to handle this problem?
Regards, Ingo
> > Hello Group,
ok.
> > supposed to be...
> > problematic,
> > I
Re: connections leading to nowhere [message #119598 is a reply to message #119574] |
Thu, 26 February 2004 09:45  |
I have no idea what the user would expect in this situation. Some clients
are clipping the anchor to the node's parent.
news:c1kvjh$26v$1@eclipse.org...
> Regards, Ingo
> > > Hello Group,
> ok.
> > > supposed to be...
> > > problematic,
bounds?
> > > I
FUDForum. Page generated in 0.03418 seconds
