Home » Newcomers » Newcomers » JDK 1.5 library problems
JDK 1.5 library problems [message #119239] Wed, 23 November 2005 10:43 Go to next message
Originally posted by: tim.julian.hsc.utah.edu
I have just installed the JDK 1.5_05
I have just installed Eclipse 3.2M3
It will not accept Java 1.5 constructs such as Scanner class,enums, and
printf.
I go to run/run/libraries, and click on the 1.5_05.
It still does not except Scanner class, enums, nor printf.
Any ideas?
Is there a document so I can make this happen everytime for certain?
Thanks for the help!
Re: JDK 1.5 library problems [message #119591 is a reply to message #119239] Thu, 24 November 2005 12:03 Go to previous message
> printf.
You need to setup your project's compiler compliance to 1.5.
See Window>Preferences>Java>Compiler>JDK Compliance. Put 5.0.
Then it should work.
Olivier
Previous Topic:Run on server problems
Next Topic:Line spacing problem in Eclipse 3.0 on Solaris/Motif
Current Time: Sat Jul 26 08:27:33 EDT 2025
Powered by FUDForum. Page generated in 0.09941 seconds
