Home » Eclipse Projects » Remote Application Platform (RAP) » RAP and Jboss
RAP and Jboss [message #119229] Thu, 22 January 2009 08:32 Go to next message
Hi all!
I'm new to RAP and I've a question: is it possible to deploy RAP app into
application containers (such as Jboss, e.g.)?
I read that RAP could be deployed into servlet containers, but it's a
little different.. If it's possible, could you provide me with a demo or
HOWTO, please?
Thanks in advance,
Irene.
Re: RAP and Jboss [message #119267 is a reply to message #119229] Thu, 22 January 2009 11:49 Go to previous messageGo to next message
I have an application where the thick-client is written in SWT. Server
code and webservices etc deployed on JBoss in a EAR. I got a requirement
to move the client onto the web, so I chose RAP.
I then created a new RAP entry point, threw it into a new WAR, and
deployed it on JBoss. Voila, my app now runs on the web. Okay it wasn't
voila, but after 2 weeks of work to get this decent sized app onto the
web, I'm amazed. :)
If you can create a WAR or EAR, then you can deploy RAP app.
As for setup details, you can take a look at the RAP FAQ,
http://wiki.eclipse.org/RAP/FAQ that's where I got most of my inspirations
from.
Re: RAP and Jboss [message #122338 is a reply to message #119267] Mon, 23 February 2009 19:25 Go to previous messageGo to next message
Hello Howard,
I am thinking of doing exactly what you did: porting an SWT app to
JBoss/RAP/WAR. I looked at your RAP FAQ link and I'm having trouble
putting it all together into one simple Hello World.
Would you be able to post a bit more info on what you did?
Also saw https://bugs.eclipse.org/bugs/show_bug.cgi?id=252881 regarding
WAR files but I can't figure out what to do with it. I haven't gotten a
non-WAR RAP Hello World yet either, I'm hazy on PDE builds and entry
points, I haven't figured out where the OSGi console is. I need some
pointers.
Thanks for any help,
Daniel
Re: RAP and Jboss [message #122371 is a reply to message #122338] Mon, 23 February 2009 23:22 Go to previous messageGo to next message
Originally posted by: evolanakis.innoopract.com
Daniel,
here are some additional pointers on .war deployment:
http://help.eclipse.org/ganymede/topic/org.eclipse.rap.help/ help/html/advanced/deployment.html
http://rapblog.innoopract.com/2007/12/rap-deployment-part-2- deploying-your.html
Bug 252881 is about providing a wizard to automate .war deployment. I
haven't had time to implement it yet. Feel free to vote for it. The more
votes it has, the easier for me to get support for working on it.
Elias.
Daniel Kranowski wrote:
> Hello Howard,
> pointers.
> Daniel
Elias Volanakis
Innoopract, Inc.
http://www.innoopract.com
Re: RAP and Jboss [message #122497 is a reply to message #122338] Tue, 24 February 2009 13:56 Go to previous messageGo to next message
Hi Daniel,
If you are referring to RCP, see the links Elias provided.
If you have an existing standalone SWT app and not an RCP app, the FAQ
should get you started. I started writing and posting contents of my war,
until I realized that the FAQ has exactly what I was writing. :p Try
following the write up under "How do I use a RWT standalone application in
Tomcat" before you hook your app to the hello world. If you have other
more specific questions, I'll try to remember to check back and help.
Howard
Re: RAP and Jboss [message #122516 is a reply to message #122497] Tue, 24 February 2009 14:59 Go to previous messageGo to next message
Thanks Elias & Howard! The Tomcat example worked perfectly for me in both
Tomcat 5.5.27 and also JBoss 5.0.0.GA.
Now I just have to figure out why the Hello World actually worked....
i.e. What are RWTDelegate, RWTServletContextListener, entryPoints? What
is expecting to see w4t.xml? But I'll start looking into those myself for
now.
Re: RAP and Jboss [message #122598 is a reply to message #122338] Wed, 25 February 2009 07:56 Go to previous messageGo to next message
Originally posted by: jancsi.reea.net
The OSGi console appears if only it is enabled from the web.xml file.
If it is enabled, then it will appear on the console where you started
jboss/tomcat. I think you have to start both tomcat and jboss as
application not as service (with catalina run / run.sh )
Jancsi
> Hello Howard,
> pointers.
> Daniel
Re: RAP and Jboss [message #122615 is a reply to message #122598] Wed, 25 February 2009 08:47 Go to previous message
You can even put a port behind the console command (eg. -console 9999)
and access it via telnet.
Cheers
Benny
Jancsi Farkas wrote:
> Hello,
> Jancsi
>> Hello Howard,
>> regarding WAR files but I can't figure out what to do with it. I
>> haven't gotten a non-WAR RAP Hello World yet either, I'm hazy on PDE
>> builds and entry points, I haven't figured out where the OSGi console
>> is. I need some pointers.
>> Daniel
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Previous Topic:GridData - exclude
Next Topic:RWT.getLocale() aware JFace data binding
Current Time: Sun Aug 31 13:35:13 EDT 2025
Powered by FUDForum. Page generated in 0.26107 seconds
