Perspectives and editor views [message #119186] |
Wed, 23 November 2005 00:51  |
Originally posted by: 5ub5.3mai1.com
I've just notice a weird editor view/perspectives behaviour.
I a single editor view in my main perspective. I create a new perspective
and close all non editor views and have 3 editor views open. When I switch
back to my main perspective, I now have 3 editor views open.
Why is the editor view in my main perspective changed?
Re: Perspectives and editor views [message #121204 is a reply to message #119772] |
Thu, 01 December 2005 18:19  |
on Fri, 25 Nov 2005 15:29:10 -0500, Eric Rizzo <eclipse3@rizzoweb.com>
wrote:
> I would have sworn that it used whatever window settings were at when
> you last exited Eclipse, but I just tried it and it is quite surprising
> in its behavior.
Actually, I missundertood the way windows works. If you open a second
window and set it up that way you want it, and when exit Eclipse with all
windows open, Eclipse will remember the state of all open windows and will
restore the session with both windows open. Apparently, I was individually
closing each open window, so when you closed the last window, this
naturally would be the same as exiting Eclipse and hence will only
rememner that I had only one window open at the time.
FUDForum. Page generated in 0.08789 seconds
