Home » Eclipse Projects » Eclipse Platform » Format code function
Format code function [message #119161] Fri, 29 August 2003 03:56 Go to next message
We are using Eclipse 2.1 on Solaris 8.
We are working in a team and need a common formating convention.
I have noticed that there is a default formating option in Eclipse 2.1.
Is it possible to export a file with the conventions and import these
settings to the other in the team?
We also tried "Jalopy plugin" were it was possible to export a file with
the coding conventions and import it to the other people in the team.
However the plugin makes CPU go up to 100 %. Finally the whole system
hangs.
All hints are very much appreciated.
//mikael
Re: Format code function [message #119188 is a reply to message #119161] Fri, 29 August 2003 04:23 Go to previous messageGo to next message
There is import an Export of the preferences. But I do not believe,
that you can export the formatter options only
>hangs.
Contact the author.
martin
Re: Format code function [message #119312 is a reply to message #119188] Fri, 29 August 2003 13:06 Go to previous message
Originally posted by: mzarra.extraquest.com
I had already contacted the author of Jalopy and have received
absolutely no response to my two emails. Apparently he is planning on
taking the Jalopy formatter commercial and seems to have little interest
in user input at this point.
>>with the coding conventions and import it to the other people in the
>>team. However the plugin makes CPU go up to 100 %. Finally the whole
>>system hangs.
> Contact the author.=20
> martin
Previous Topic:TextEditor.setTitleToolTip() bug?!
Next Topic:Problem to access Help from Eclipse
Current Time: Thu Jul 10 10:27:43 EDT 2025
Powered by FUDForum. Page generated in 0.28424 seconds
