Home » Archived » Test and Performance Tools Platform (TPTP) » Dependencies for reusing LogNavigator & Log View
Dependencies for reusing LogNavigator & Log View [message #119158] Fri, 07 December 2007 01:36
What are the jars / packages i need to include in my pluing dependencies
section to reuse the LogNavigator & Log View for following tasks -
Import Log file
Import Symptom DB
View Results in Log View
Analyze Log File against Symptom DB
View Analysis results in Analysis Results View
Correlate Log Files
View Corrleation results in Log Interaction view.
I have currently folloiwng dependencies included in the manifest file-
Require-Bundle: org.eclipse.ui,
org.eclipse.core.resources,
org.eclipse.tptp.platform.common,
org.eclipse.tptp.platform.common.ui,
org.eclipse.tptp.platform.common.ui.trace,
org.eclipse.tptp.platform.log.views,
org.eclipse.tptp.monitoring.logui,
org.eclipse.tptp.platform.log.doc.user,
org.eclipse.hyades.trace.ui,
org.eclipse.hyades.trace.views,
org.eclipse.hyades.sdb
Here is my plgin.xml
<plugin>
<extension
id="application"
point="org.eclipse.core.runtime.applications">
<application>
<run
class="org.eclipse.ui.tutorials.rcp.part1.Application">
</run>
</application>
</extension>
<extension
point="org.eclipse.ui.perspectives">
<perspective
class="org.eclipse.hyades.trace.internal.ui.PDPerspective"
fixed="false"
id="org.eclipse.hyades.trace.internal.ui.tracePerspective"
name="org.eclipse.hyades.trace.internal.ui.tracePerspective "/>
</extension>
<extension
id="product"
point="org.eclipse.core.runtime.products">
<product
application="org.eclipse.ui.tutorials.rcp.part1.application "
name="RCP Tutorial 1"/>
</extension>
<extension point="org.eclipse.ui.perspectiveExtensions">
<perspectiveExtension
targetID="org.eclipse.hyades.trace.internal.ui.PDPerspective ">
</perspectiveExtension> </extension>
</plugin>
With this i am able to import the log file using import wizard and Symptom
DB. But no results are displayed in the Log View. I am importing Windows
Application log & Security Logs.
If i Use standalone GLA , the logs are displayed correctly in the log view.
Thanks in advance...
Prasad
Previous Topic:HSQLDB for Large Resource Support
Next Topic:'org.eclipse.hyades.logging.commons.FileLoggerFactory' cannot be converted to 'org.apache.commons.lo
Current Time: Tue Jul 22 12:08:29 EDT 2025
Powered by FUDForum. Page generated in 0.03217 seconds
