Home » Eclipse Projects » Remote Application Platform (RAP) » Widget.notifyListeners() and Image scaling
Widget.notifyListeners() and Image scaling [message #118951] |
Tue, 20 January 2009 19:25  |
First of all, let me say what an awesome project and awesome job you guys
have done! With a couple weeks worth of work, I was able to take a decent
sized application written in SWT and deploy and display it on the web! :D
Now I'm going through the app and ironing out the incompatibilities
between RAP and SWT.
One of the things I noticed is that Widget.notifyListeners() as well as
Display.post() are both missing. This is causing me some heart-burns.
Since programmatically calling Combo.setSelect() in SWT doesn't fire an
selection event, I used to use Widget.notifyListeners() to manually fire
one. Unfortunately RAP doesn't like that. Is there a RAP work-around, or
any plans to address this by any chance?
Another difficulty I'm having is scaling image. The only two ways I know
to resize an image are ImageData.scaledTo() and GC.drawImage(). Neither is
available in RAP. Any help here?
Thanks, and keep up the great work!
Re: Widget.notifyListeners() and Image scaling [message #118977 is a reply to message #118951] |
Wed, 21 January 2009 06:52   |
Howard,
glad to hear that you liked RAP:) Are you aware of upcoming [1] and
past [2] webinars about single sourcing RAP and RCP? Some of the
presented techniques will probably also fit for single sourcing
standalone SWT and RWT applications.
Please also see my comments below.
Rüdiger
[1] https://www1.gotomeeting.com/register/733916337
[2] http://www.eclipse.org/rap/buzz.php#articles
> guys have done! With a couple weeks worth of work, I was able to take a
> decent sized application written in SWT and deploy and display it on the
> web! :D Now I'm going through the app and ironing out the
> incompatibilities between RAP and SWT.
Feel free to file enhancement requests. Widget#notifyListeners()
seems to be not too difficult to implement, whereas I am not sure if
that is also the case for Display.post().
To work around the missing notifyListeners() you could rely on RWT
internals like so:
event = new SelectionEvent( widget, ... );
event.processEvent();
> is available in RAP. Any help here?
AFAIK the same can be achieved with AWT. Though using AWT - even in
headless mode - might require some extra software when deploying the
application on the server.
Re: Widget.notifyListeners() and Image scaling [message #124106 is a reply to message #119120] |
Mon, 09 March 2009 15:54   |
I just noticed that I have some issues with image resizing. I have a label
that displays images from the DB. I have a resize listener on the
composite containing the label so that when the app is resized, the image
will resize and use extra space or use less space along with the app.
Unfortunately with the way RAP image works, multiple copies of the images
in different sizes are created as I slowly expand or contract the browser.
Is there a better way to achieve my desired result?
imageComposite.addListener(SWT.Resize, new Listener() {
public void handleEvent(Event p_event) {
int imageWidth = imageComposite.getSize().x;
int imageHeight = imageComposite.getSize().y;
Image image = getBeanImage(imageBytes, imageWidth, imageHeight);
label.setImage(image);
imageComposite.layout();
public Image createImage(byte[] imageBytes, int width, int height) {
ImageData imageData = new ImageData(new
ByteArrayInputStream(imageBytes));
if (width != 0 && height != 0) {
// If the image is smaller than scaling dimension, leave it alone
and don't stretch it.
if (imageData.width < width) {
width = imageData.width;
if (imageData.height < height) {
height = imageData.height;
imageData = imageData.scaledTo(width, height);
Image image = ResourceFactory.findImage(imageData);
return image;
Re: Widget.notifyListeners() and Image scaling [message #124171 is a reply to message #124106] |
Tue, 10 March 2009 07:24   |
Hi Howard,
> label that displays images from the DB. I have a resize listener on the
> image will resize and use extra space or use less space along with the
> app. Unfortunately with the way RAP image works, multiple copies of the
> images in different sizes are created as I slowly expand or contract the
> browser. Is there a better way to achieve my desired result?
Creating new image versions on every resize seems like overkill to me.
After all, a browser is capable of scaling images as well (you could use
the browser widget to exploit this capability). On the other hand,
resizing on the server saves bandwidth - I guess the best solution
depends on your use case. Maybe a feasible approach is to limit the
possible image sizes in the layout to a few, or to add a "fit to window"
button to minimize the number of requests for resized images?
Ralf
> return image;
Re: Widget.notifyListeners() and Image scaling [message #124258 is a reply to message #124247] |
Tue, 10 March 2009 12:56  |
Thanks for the suggestions Ralf, I think that'll work as I'm not expecting
resizing to happen too often. It was only a worst case scenario.
p-lex, I think the latest response you got is a winner. I would be
interested to see your finished implementation if possible.
Current Time: Sun Jul 27 06:27:57 EDT 2025
Powered by FUDForum. Page generated in 0.06300 seconds
