p2 installing jdk 1.5 bundles under jdk 1.6 [message #118655] |
Mon, 29 September 2008 18:31  |
I am trying to install a feature into a p2-enabled RCP application that is
running under JDK 1.6. When I try to install the feature using the p2 ui,
it tries to calculate requirements and returns an error complaining about
unsatisfied java package dependencies for javax.xml.bind.annotation and
javax.xml.stream in org.apache.camel.camel-core 1.3.0 (the full error
message is at the end of this post). The javax.xml.bin.annotation and
javax.xml.stream packages are part of JDK 1.6 but not JDK 1.5. I looked in
the manifest for the camel-core bundle and it has Build-Jdk: 1.5.0_13. If
I embed the feature in the application without p2, it works fine, so I
don't think this is a real runtime problem, but a problem with the p2
requirements resolver. Is there something I can do to get p2 to understand
that these packages are present in the Java 1.6 version that the
application is running in so that it will allow me to install this feature?
Edwin
Full error text:
Cannot complete the request. See the details.
Unsatisfied dependency: [org.apache.camel.camel-core 1.3.0]
requiredCapability: java.package/javax.xml.bind.annotation/0.0.0
requiredCapability: java.package/javax.xml.stream/0.0.0
Unsatisfied dependency: [com.rbc.fusion.ats 1.5.0] requiredCapability:
Unsatisfied dependency: [com.rbccm.eddie.client 1.0.0.SNAPSHOT]
requiredCapability:
java.package/com.rbccm.eddie.fusion.ats.file/1.0.0.SNAPSHOT
requiredCapability:
java.package/com.rbccm.eddie.globalproductgroup/1.0.0.SNAPSH OT
requiredCapability:
java.package/com.rbccm.eddie.fusion.camel.component.ats.upda te/1.0.0.SNAPSHOT
requiredCapability: java.package/org.apache.camel.impl/0.0.0
requiredCapability: java.package/com.rbccm.eddie.rmds/1.0.0.SNAPSHOT
requiredCapability: java.package/org.apache.camel.spi/0.0.0
requiredCapability: java.package/com.rbccm.eddie.util/1.0.0.SNAPSHOT
requiredCapability:
java.package/com.rbccm.eddie.fusion.camel.jmx/1.0.0.SNAPSHOT
requiredCapability: java.package/com.rbccm.eddie.security/1.0.0.SNAPSHOT
requiredCapability:
java.package/com.rbccm.eddie.fusion.camel.component.ats/1.0. 0.SNAPSHOT
requiredCapability:
java.package/com.rbccm.eddie.fusion.camel.processor/1.0.0.SN APSHOT
requiredCapability: java.package/org.apache.camel/0.0.0
requiredCapability:
java.package/com.rbccm.eddie.springframework/1.0.0.SNAPSHOT
requiredCapability: java.package/com.rbccm.eddie.fusion.ats/1.0.0.SNAPSHOT
requiredCapability: java.package/org.apache.camel.util.jndi/1.3.0
requiredCapability: java.package/org.apache.camel.component.timer/1.3.0
requiredCapability: java.package/org.apache.camel.model.dataformat/1.3.0
requiredCapability: java.package/org.apache.camel.component.vm/1.3.0
requiredCapability: java.package/org.apache.camel.language.bean/1.3.0
requiredCapability: java.package/org.apache.camel.management/1.3.0
requiredCapability: java.package/org.apache.camel.model/1.3.0
requiredCapability: java.package/org.apache.camel.component.file/1.3.0
requiredCapability: java.package/org.apache.camel.builder/1.3.0
requiredCapability: java.package/org.apache.camel.spi/1.3.0
requiredCapability: java.package/org.apache.camel.impl/1.3.0
requiredCapability: java.package/org.apache.camel.component.ref/1.3.0
requiredCapability: java.package/org.apache.camel.language/1.3.0
requiredCapability: java.package/org.apache.camel/1.3.0
requiredCapability: java.package/org.apache.camel.builder.xml/1.3.0
requiredCapability:
java.package/org.apache.camel.processor.loadbalancer/1.3.0
requiredCapability: java.package/org.apache.camel.component.mock/1.3.0
requiredCapability: java.package/org.apache.camel.component.seda/1.3.0
requiredCapability: java.package/org.apache.camel.view/1.3.0
requiredCapability:
java.package/org.apache.camel.processor.resequencer/1.3.0
requiredCapability: java.package/org.apache.camel.component.direct/1.3.0
requiredCapability: java.package/org.apache.camel.model.config/1.3.0
requiredCapability: java.package/org.apache.camel.converter.jaxp/1.3.0
requiredCapability:
java.package/org.apache.camel.component.file.strategy/1.3.0
requiredCapability: java.package/org.apache.camel.language.simple/1.3.0
requiredCapability: java.package/org.apache.camel.component.bean/1.3.0
requiredCapability: java.package/org.apache.camel.component.dataset/1.3.0
requiredCapability:
java.package/org.apache.camel.processor.interceptor/1.3.0
requiredCapability: java.package/org.apache.camel.model.loadbalancer/1.3.0
requiredCapability: java.package/org.apache.camel.converter/1.3.0
requiredCapability: java.package/org.apache.camel.component.jmx/1.3.0
requiredCapability: java.package/org.apache.camel.component.list/1.3.0
requiredCapability: java.package/org.apache.camel.processor/1.3.0
requiredCapability:
java.package/org.apache.camel.processor.idempotent/1.3.0
requiredCapability:
java.package/org.apache.camel.processor.validation/1.3.0
requiredCapability: java.package/org.apache.camel.model.language/1.3.0
requiredCapability: java.package/org.apache.camel.util/1.3.0
requiredCapability: java.package/org.apache.camel.component.log/1.3.0
requiredCapability: java.package/org.apache.camel.converter.stream/1.3.0
requiredCapability: java.package/org.apache.camel.processor.aggregate/1.3.0
requiredCapability: java.package/org.apache.camel.impl.converter/1.3.0
Unsatisfied dependency: [com.rbccm.eddie.ui 1.0.0.SNAPSHOT]
requiredCapability: java.package/com.rbccm.eddie.util/0.0.0
requiredCapability: java.package/com.rbccm.eddie.ui.action/1.0.0.SNAPSHOT
requiredCapability: java.package/com.rbccm.eddie.ui.view/1.0.0.SNAPSHOT
requiredCapability: java.package/com.rbccm.eddie.ui/1.0.0.SNAPSHOT
requiredCapability: java.package/com.rbccm.eddie.security/0.0.0
requiredCapability: java.package/com.rbccm.eddie.globalproductgroup/0.0.0
requiredCapability: java.package/com.rbccm.eddie.fusion.ats/0.0.0
Unsatisfied dependency: [com.rbccm.eddie.ui.feature.feature.group 1.0.0]
requiredCapability:
org.eclipse.equinox.p2.iu/com.rbccm.eddie.ui/[1.0.0.SNAPSHOT ,1.0.0.SNAPSHOT]
requiredCapability:
org.eclipse.equinox.p2.iu/org.apache.camel.camel-core/[1.3.0 ,1.3.0]
requiredCapability:
org.eclipse.equinox.p2.iu/com.rbccm.eddie.client/[1.0.0.SNAP SHOT,1.0.0.SNAPSHOT]
Re: p2 installing jdk 1.5 bundles under jdk 1.6 [message #118747 is a reply to message #118655] |
Tue, 30 September 2008 10:54   |
Can you please open a bug for this. Thanks.
"Edwin Park" <esp1@cornell.edu> wrote in message
news:6fa0ea1b2cd5ee360938870d714f4c08$1@www.eclipse.org...
> feature?
> Edwin
> Full error text:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
> requiredCapability:
FUDForum. Page generated in 0.04966 seconds
