Home » Eclipse Projects » GEF » Running GEF outside of Eclipse...
Running GEF outside of Eclipse... [message #10819] Fri, 21 June 2002 13:54 Go to next message
I know GEF is fairly well entrenched / integrated into Eclipse, but has
there been any consideration of allowing it to run outside of Eclipse -
i.e. in a separate window and/or hosted in a web browser?
Is this possible if Eclipse was running in the background but invisible?
For instance - could you host a GEF editor inside an SWT Shell that isn't
inside Eclipse.
-Steve
Re: Running GEF outside of Eclipse... [message #11092 is a reply to message #10819] Fri, 21 June 2002 14:08 Go to previous message
Originally posted by: none.ibm.com
Steve-
We've had success at running the Palette in a Shell by itself. We haven't
tried much more than that. Most things should work fine. People are using
portions of GEF in non-EditorPart contexts (for example to render a
preview), so a Shell isn't much different.
SWT cannot be hosted in a web browser, but I assume you could take an SWT
Image and convert it to its AWT equivalent.
"Steven Shaw" <sshaw@rational.com> wrote in message
news:aevo31$p6d$1@rogue.oti.com...
> inside Eclipse.
> -Steve
Previous Topic:Getting started with GEF / hello Gef application?
Next Topic:Supporting for more than one kind of Connections
Current Time: Tue Jul 22 00:52:28 EDT 2025
Powered by FUDForum. Page generated in 0.04507 seconds
