Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Two problems @GenericGenerate strategy="foreign" and @ManyToMany
Two problems @GenericGenerate strategy="foreign" and @ManyToMany [message #118628] |
Wed, 16 April 2008 00:15 |
Jason Henriksen Messages: 231 Registered: July 2009 |
--------------090903010004070201020205
Hi Martin,
I'm trying to build the ultimate example collection for my co-workers to
use. I've got nearly everything working, but I'm stuck on two items.
Would you load this .xsd file and explain why I get:
" org.eclipse.emf.teneo.annotations.mapper.StoreMappingExcepti on: The
feature/eclass parent/M2mbjoin should be a ManyToOne but it already has
a OneToMany, ManyToMany or OneToOne annotation" on the object "m2mbjoin"
And a "can't find property" error on "o2oschild".
Thanks for any help!
Jason Henriksen
P.S. If you notice anything else I'm not doing in the best way, I'd love
your feedback on this file.
(I'm pasting it in for the sake of searching later, but also attaching
it so you can DL it more easily)
<xsd:schema
xmlns:com.ibm.example.connection="http:///com/ibm/example/connection.ecore"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
ecore:nsPrefix="com.ibm.example.connection"
ecore:package="com.ibm.example.connection"
targetNamespace="http:///com/ibm/example/connection.ecore"
xmlns="http:///com/ibm/example/connection.ecore"
EMF is all about making a model and storing it in an XML Resource. That
resource could be a local file or a remore XML page.
Teneo lets EMF treat the database as a resource. It handles the mapping
from EMF object into Hibernate maps and from there
Hibernate can save the data.
This XSD shows the complete set of possible object associations as
renderd in the CONTAINMENT view.
This view is supported by ILOG, but does not allow the same item to be
referenced in more than one place without creating a copy of that item.
Most of the time this limitation does not matter, however since EMF
supports xsd:IDREF but ILOG does not, you have to be slightly careful.
All but one of the associations in this document are ILOG compatible.
To use the IDREF/anyURI view look for the example discussing references.
Note:
- When the teneo documentation adds columns we don't see in the
underlying legacy tables, we have to add properties to turn those
features OFF. (all extra columns can be killed thu properties)
- Teneo documentation about object associations can be found here:
http://elver.org/hibernate/hibernaterelations.html
Table of Name Abbreviations:
o2o => One to One
o2m => One to Many
m2o => Many to One
m2m => Many to Many
s => Single Directional (always parent to child for these examples)
b => Bi-Directional
parent => parent table holds foreign key
child => child table holds foreign key
join => join table
childInvis => child table holds foreign key, but has no attribute to
read it
childEmbed => child table is embedded in parent table
Example Object Names:
o2osparent
o2oschild
o2osjoin
o2oschildInvis
o2oschildEmbed
o2obparent
o2obchild
o2objoin
o2obchildInvis pointless (it's not bidirectional try o2osjoin)
o2obchildEmbed impossible (embedded type doesn't know what it is
embedded into)
o2msparent impossible (need multiple o2oschildEmbed, or API Helper)
o2mschild
o2msjoin
o2mschildInvis
o2mschildEmbed
o2mbparent impossible (need multiple o2oschildEmbed, or API Helper)
o2mbchild
o2mbjoin
o2mbchildInvis impossible (bidirectional implies child can see parent)
o2mbchildEmbed impossible (need multiple o2oschildEmbed, or API Helper)
m2osparent
m2oschild impossible (child would become parent and use o2m)
m2osjoin
m2oschildInvis impossible (see m2oschild)
m2oschildEmbed pointless (use o2oschildEmbed; embedded single is not
longer asingle item)
m2ob* pointless (use o2mb*)
m2ms* pointless (m2m implies bidirectional)
m2mbparent impossible (need multiple o2mschildEmbed on both sides, or
API Helper)
m2mbchild impossible (need multiple o2mschildEmbed on both sides, or
API Helper)
m2mbjoin
m2mbchildInvis impossible (need multiple o2mschildEmbed on both sides,
or API Helper)
m2mbchildEmbed impossible (need multiple o2mschildEmbed on both
sides, or API Helper)
<!-- used by one of the child objects, but needs to be declared up here -->
<xsd:annotation><xsd:appinfo source="teneo.jpa">
@GenericGenerator(name="foreign", strategy = "foreign", parameters={
@Parameter(name="property", value="idChild")
</xsd:appinfo></xsd:annotation>
<!-- ==== Child Type Definitions Start Here ==== -->
<!-- Paren't handles the mapping, no child annotations needed -->
<xsd:complexType name="o2osparent">
source="teneo.jpa">@Table(name="o2osparent")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
<xsd:element type="xsd:int" name="idChild">
<xsd:annotation><xsd:appinfo source="teneo.jpa">@Id
@GeneratedValue(strategy=AUTO) @Column(name="IDCHILD"
unique="true")</xsd:appinfo></xsd:annotation></xsd:element >
<xsd:element type="xsd:string" name="data">
<xsd:annotation><xsd:appinfo source="teneo.jpa">@Column(name="DATA"
unique="true" length="25")</xsd:appinfo></xsd:annotation></xsd:element >
</xsd:sequence>
</xsd:complexType>
<!-- My primary key matches the parent's primary key. I don't have
an attribute for my parent, but with this object the parent could be
found -->
<!-- note that the id is NOT generated here. Getting this to work
without an exception is a big trick -->
<!-- We have to tell hibernate to read the value of the parent and use
that as its primary key. Otherwise -->
<!-- we'll get all kind of violation erros. -->
<xsd:complexType name="o2oschild">
source="teneo.jpa">@Table(name="o2oschild")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
@Id
@GeneratedValue(generator="foreign")
@Column(name="IDCHILD")
</xsd:appinfo></xsd:annotation></xsd:element>
</xsd:sequence>
</xsd:complexType>
<!-- The parent has handled everything needed for this association.
The child cannot see the parent. -->
<xsd:complexType name="o2osjoin">
source="teneo.jpa">@Table(name="o2osjoin")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
<!-- The parent will add an unmapped column to my table. Given only
the child object, this parent object could not be found without dropping
to SQL. I also have no Java dependencies on the parent class. -->
<xsd:complexType name="o2oschildInvis">
source="teneo.jpa">@Table(name="o2oschildInvis")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
<!-- This object is not allowed to have a primary key! Also it must
be marked as embedable, and have no table specified. Different data
column for clarity -->
<xsd:complexType name="O2oschildEmbed">
source="teneo.jpa">@Embeddable</xsd:appinfo></xsd:annotation >
<xsd:sequence>
name="phone"><xsd:annotation><xsd:appinfo
source="teneo.jpa">@Column(name="phone" unique="true"
</xsd:sequence>
</xsd:complexType>
<!-- This child can find its parent. The parent holds the foreign
key column -->
<xsd:complexType name="o2obparent">
source="teneo.jpa">@Table(name="o2obparent")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
<xsd:element type="Parent" name="parent">
source="teneo.jpa">@OneToOne(mappedBy="o2obparent")</xsd:appinfo ></xsd:annotation></xsd:element>
</xsd:sequence>
</xsd:complexType>
<!-- This child can find its parent. The child holds the foreign key
column -->
<xsd:complexType name="o2obchild">
source="teneo.jpa">@Table(name="o2obchild")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
<xsd:annotation><xsd:appinfo source="teneo.jpa">@OneToOne
@JoinColumn(name="PARENT")</xsd:appinfo></xsd:annotation ></xsd:element>
</xsd:sequence>
</xsd:complexType>
<!-- The parent covered defining the join. I just add the annotation
so I can find my way to the parent and mention which parent field I
belong to -->
<xsd:complexType name="o2objoin">
source="teneo.jpa">@Table(name="o2objoin")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
source="teneo.jpa">@OneToOne(mappedBy="o2objoin")</xsd:appinfo ></xsd:annotation></xsd:element>
</xsd:sequence>
</xsd:complexType>
<!-- I can't use the primary key for the association because child
holds the FK. But I'm also supposed to be uni-directional from the
parent. Solution: Make the parent accessor private -->
<xsd:complexType name="o2mschild">
source="teneo.jpa">@Table(name="o2mschild")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
ecore:suppressSetVisibility='true' ecore:suppressGetVisibility='true'>
</xsd:sequence>
</xsd:complexType>
<!-- In the join table case, the parent has already done all the
mapping needed. This makes the parent Invisible, but without the
'secret column' needed in the next example -->
<xsd:complexType name="o2msjoin">
source="teneo.jpa">@Table(name="o2msjoin")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
<!-- In the Invisible case we want to have no mention of the parent
at all. The only way is to ignore the parent mapping and let Teneo add
it without the class knowing about it. -->
<xsd:complexType name="o2mschildInvis">
source="teneo.jpa">@Table(name="o2mschildInvis")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
<!-- This child class will be embedded just like the other. No table
name allowed, and no id column allowed. For illustration it is also
given different data columns -->
<xsd:complexType name="o2mschildEmbed">
<xsd:sequence>
<xsd:element type="xsd:string" name="city">
<xsd:annotation><xsd:appinfo source="teneo.jpa">@Column(name="CITY"
name="state"><xsd:annotation><xsd:appinfo
source="teneo.jpa">@Column(name="STATE"
length="2")</xsd:appinfo></xsd:annotation></xsd:element >
</xsd:sequence>
</xsd:complexType>
<!-- This is the most straight forward one to many case -->
<xsd:complexType name="o2mbchild">
source="teneo.jpa">@Table(name="o2mbchild")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
<xsd:annotation><xsd:appinfo source="teneo.jpa">@ManyToOne
@JoinColumn(name="parent")</xsd:appinfo></xsd:annotation ></xsd:element>
</xsd:sequence>
</xsd:complexType>
<!-- the parent has taken care of all the annotations needed -->
<xsd:complexType name="o2mbjoin">
source="teneo.jpa">@Table(name="o2mbjoin")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
@JoinTable(name="o2mbjoinjointable", joinColumns = {
@JoinColumn(name="idChild", unique = true) }, inverseJoinColumns = {
@JoinColumn(name="id") } )</xsd:appinfo></xsd:annotation></xsd:element>
</xsd:sequence>
</xsd:complexType>
<!-- This object has no awareness of the parent. This could be a
reusable code or often referenced and easily shared data object -->
<xsd:complexType name="m2osparent">
source="teneo.jpa">@Table(name="m2osparent")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
<!-- Again, this object has no awareness of the parent. This could
be a reusable code or often referenced and easily shared data object -->
<xsd:complexType name="m2osjoin">
source="teneo.jpa">@Table(name="m2osjoin")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
<!-- This type cannot be supported by JRules and requires special
handling by EMF. Notice that the type is IDREF. Refer to the earlier
example XSD to see how to manage these -->
<!-- If you need URLs instead of in-document references look ahead to
the anyURI examples
<xsd:complexType name="m2mbjoin">
source="teneo.jpa">@Table(name="m2mbjoin")</xsd:appinfo ></xsd:annotation>
<xsd:sequence>
<xsd:element type="xsd:int" name="id">
<xsd:element type="xsd:IDREF" ecore:reference="Parent"
name="parent" ecore:opposite="m2mbjoin">
source="teneo.jpa">@ManyToMany(mappedBy="m2mbjoin" targetEntity="Parent"
indexed=false)
@JoinTable(name="m2mbjoinjointable")</xsd:appinfo></xsd:annotation ></xsd:element>
</xsd:sequence>
</xsd:complexType>
<!-- ====== Parent definition starts here ====== -->
WARNING: I define the parent AFTER the children to be sure that the
parents are saved before the children!
If there is no other information available, Teneo saves the objects in
the order that they are defined.
<xsd:complexType name="Parent">
<xsd:annotation>
@Table(name=PARENT)
</xsd:appinfo>
</xsd:annotation>
<xsd:sequence>
<xsd:annotation>
@Id
@Column(name="ID" unique="true")
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
<xsd:annotation>
@Column(name="DATA" unique="true" length="25")
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
<!-- Badly formatted for easier comparison. Expand what you're
interested in -->
<xsd:element maxOccurs="1" name="o2osparent" type="o2osparent">
@JoinColumn(name="o2osp")</xsd:appinfo></xsd:annotation> </xsd:element>
<!-- the child does all the work to hold this relationship. I can
use @PrimaryKeyJoinColumn because the key of the child is the join I
care about -->
<xsd:element maxOccurs="1" name="o2oschild" type="o2oschild">
@PrimaryKeyJoinColumn</xsd:appinfo></xsd:annotation></xsd:element >
<xsd:element maxOccurs="1" name="o2osjoin" type="o2osjoin"
minOccurs="0">
source="teneo.jpa">@JoinTable(name="o2osjoin_jointable", joinColumns = {
@JoinColumn(name="id", unique = true) }, inverseJoinColumns = {
@JoinColumn(name="idChild") }
<xsd:element maxOccurs="1" name="o2oschildInvis" type="o2oschildInvis">
<!-- Nothing to annotate on the child => No ability to control child
column name; -->
source="teneo.jpa">@OneToOne</xsd:appinfo></xsd:annotation ></xsd:element>
<xsd:element maxOccurs="1" name="o2oschildEmbed" type="O2oschildEmbed">
source="teneo.jpa">@Embedded</xsd:appinfo></xsd:annotation ></xsd:element>
<xsd:element maxOccurs="1" name="o2obparent" type="o2obparent">
@JoinColumn(name="o2obp")</xsd:appinfo></xsd:annotation> </xsd:element>
<xsd:element maxOccurs="1" name="o2obchild" type="o2obchild">
<!-- note: the option mappedBy="parent" means that this is controlled
by the 'parent' attribute of the CHILD object) -->
source="teneo.jpa">@OneToOne(mappedBy="parent")</xsd:appinfo ></xsd:annotation></xsd:element>
<xsd:element maxOccurs="1" name="o2objoin" type="o2objoin">
@JoinTable(name="o2objoin_jointable", joinColumns = {
@JoinColumn(name="idChild") } )</xsd:appinfo></xsd:annotation></xsd:element>
<xsd:element maxOccurs="unbounded" name="o2mschild" type="o2mschild">
source="teneo.jpa">@OneToMany(mappedBy="parent")</xsd:appinfo ></xsd:annotation></xsd:element>
<xsd:element maxOccurs="unbounded" name="o2msjoin" type="o2msjoin">
<xsd:annotation><xsd:appinfo source="teneo.jpa">@OneToMany
@JoinTable(name="o2msjoinjointable", joinColumns = {
<xsd:element maxOccurs="unbounded" name="o2mschildInvis"
type="o2mschildInvis">
column name -->
source="teneo.jpa">@OneToMany</xsd:appinfo></xsd:annotation ></xsd:element>
<xsd:element maxOccurs="1" name="o2mschildEmbed1" type="o2mschildEmbed">
<xsd:annotation><xsd:appinfo source="teneo.jpa">@Embedded
@AttributeOverrides({ @AttributeOverride(name="city",
column=@Column(name="city1")), @AttributeOverride(name="state",
column=@Column(name="state1"))})</xsd:appinfo></xsd:annotation ></xsd:element>
<xsd:element maxOccurs="1" name="o2mschildEmbed2" type="o2mschildEmbed">
column=@Column(name="city2")), @AttributeOverride(name="state",
column=@Column(name="state2"))})</xsd:appinfo></xsd:annotation ></xsd:element>
<xsd:element maxOccurs="1" name="o2mschildEmbed3" type="o2mschildEmbed">
column=@Column(name="city3")), @AttributeOverride(name="state",
column=@Column(name="state3"))})</xsd:appinfo></xsd:annotation ></xsd:element>
<xsd:element maxOccurs="unbounded" name="o2mbchild" type="o2mbchild">
<xsd:element maxOccurs="unbounded" name="o2mbjoin" type="o2mbjoin">
<xsd:element maxOccurs="1" name="m2osparent" type="m2osparent">
@JoinColumn(name="m2osp")</xsd:appinfo></xsd:annotation> </xsd:element>
<xsd:element maxOccurs="1" name="m2osjoin" type="m2osjoin">
@JoinTable(name="m2osjoinjointable", joinColumns = {
<!-- WARNING: This association cannot be supported by JRules due to
lack of support for IDREF types -->
<xsd:element maxOccurs="unbounded" name="m2mbjoin" type="xsd:IDREF"
ecore:reference="m2mbjoin" ecore:opposite="parent">
source="teneo.jpa">@ManyToMany(indexed=false, targetEntity="m2mbjoin")
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
Content-Type: text/xml;
name="connections.xsd"
Content-Disposition: inline;
filename="connections.xsd"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4KPHhzZDpz Y2hlbWEgCnht
bG5zOmNvbS5pYm0uZXhhbXBsZS5jb25uZWN0aW9uPSJodHRwOi8vL2NvbS9p Ym0vZXhhbXBs
ZS9jb25uZWN0aW9uLmVjb3JlIiAKeG1sbnM6ZWNvcmU9Imh0dHA6Ly93d3cu ZWNsaXBzZS5v
cmcvZW1mLzIwMDIvRWNvcmUiIAp4bWxuczp4c2Q9Imh0dHA6Ly93d3cudzMu b3JnLzIwMDEv
WE1MU2NoZW1hIiAKZWNvcmU6bnNQcmVmaXg9ImNvbS5pYm0uZXhhbXBsZS5j b25uZWN0aW9u
IiAKZWNvcmU6cGFja2FnZT0iY29tLmlibS5leGFtcGxlLmNvbm5lY3Rpb24i IAp0YXJnZXRO
YW1lc3BhY2U9Imh0dHA6Ly8vY29tL2libS9leGFtcGxlL2Nvbm5lY3Rpb24u ZWNvcmUiCnht
bG5zPSJodHRwOi8vL2NvbS9pYm0vZXhhbXBsZS9jb25uZWN0aW9uLmVjb3Jl Igo+Cgo8IS0t
IAoNCkVNRiBpcyBhbGwgYWJvdXQgbWFraW5nIGEgbW9kZWwgYW5kIHN0b3Jp bmcgaXQgaW4g
YW4gWE1MIFJlc291cmNlLiAgVGhhdCByZXNvdXJjZSBjb3VsZCBiZSBhIGxv Y2FsIGZpbGUg
b3IgYSByZW1vcmUgWE1MIHBhZ2UuDQpUZW5lbyBsZXRzIEVNRiB0cmVhdCB0 aGUgZGF0YWJh
c2UgYXMgYSByZXNvdXJjZS4gIEl0IGhhbmRsZXMgdGhlIG1hcHBpbmcgZnJv bSBFTUYgb2Jq
ZWN0IGludG8gSGliZXJuYXRlIG1hcHMgYW5kIGZyb20gdGhlcmUgDQpIaWJl cm5hdGUgY2Fu
IHNhdmUgdGhlIGRhdGEuDQoKVGhpcyBYU0Qgc2hvd3MgdGhlIGNvbXBsZXRl IHNldCBvZiBw
b3NzaWJsZSBvYmplY3QgYXNzb2NpYXRpb25zIGFzIHJlbmRlcmQgaW4gdGhl IENPTlRBSU5N
RU5UIHZpZXcuICAKVGhpcyB2aWV3IGlzIHN1cHBvcnRlZCBieSBJTE9HLCBi dXQgZG9lcyBu
b3QgYWxsb3cgdGhlIHNhbWUgaXRlbSB0byBiZSByZWZlcmVuY2VkIGluIG1v cmUgdGhhbiBv
bmUgcGxhY2Ugd2l0aG91dCBjcmVhdGluZyBhIGNvcHkgb2YgdGhhdCBpdGVt LgpNb3N0IG9m
IHRoZSB0aW1lIHRoaXMgbGltaXRhdGlvbiBkb2VzIG5vdCBtYXR0ZXIsIGhv d2V2ZXIgc2lu
Y2UgRU1GIHN1cHBvcnRzIHhzZDpJRFJFRiBidXQgSUxPRyBkb2VzIG5vdCwg eW91IGhhdmUg
dG8gYmUgc2xpZ2h0bHkgY2FyZWZ1bC4KQWxsIGJ1dCBvbmUgb2YgdGhlIGFz c29jaWF0aW9u
cyBpbiB0aGlzIGRvY3VtZW50IGFyZSBJTE9HIGNvbXBhdGlibGUuICBUbyB1 c2UgdGhlIElE
UkVGL2FueVVSSSB2aWV3IGxvb2sgZm9yIHRoZSBleGFtcGxlIGRpc2N1c3Np bmcgcmVmZXJl
bmNlcy4NCg0KTm90ZToNCiAtIFdoZW4gdGhlIHRlbmVvIGRvY3VtZW50YXRp b24gYWRkcyBj
b2x1bW5zIHdlIGRvbid0IHNlZSBpbiB0aGUgdW5kZXJseWluZyBsZWdhY3kg dGFibGVzLCB3
ZSBoYXZlIHRvIGFkZCBwcm9wZXJ0aWVzIHRvIHR1cm4gdGhvc2UgZmVhdHVy ZXMgT0ZGLiAo
YWxsIGV4dHJhIGNvbHVtbnMgY2FuIGJlIGtpbGxlZCB0aHUgcHJvcGVydGll cykNCiAtIFRl
bmVvIGRvY3VtZW50YXRpb24gYWJvdXQgb2JqZWN0IGFzc29jaWF0aW9ucyBj YW4gYmUgZm91
bmQgaGVyZTogaHR0cDovL2VsdmVyLm9yZy9oaWJlcm5hdGUvaGliZXJuYXRl cmVsYXRpb25z
Lmh0bWwNCiAgDQoKClRhYmxlIG9mIE5hbWUgQWJicmV2aWF0aW9uczoKIG8y byA9PiBPbmUg
dG8gT25lCiBvMm0gPT4gT25lIHRvIE1hbnkKIG0ybyA9PiBNYW55IHRvIE9u ZQogbTJtID0+
IE1hbnkgdG8gTWFueQoKIHMgPT4gU2luZ2xlIERpcmVjdGlvbmFsIChhbHdh eXMgcGFyZW50
IHRvIGNoaWxkIGZvciB0aGVzZSBleGFtcGxlcykKIGIgPT4gQmktRGlyZWN0 aW9uYWwKCiBw
YXJlbnQgPT4gcGFyZW50IHRhYmxlIGhvbGRzIGZvcmVpZ24ga2V5CiBjaGls ZCA9PiBjaGls
ZCB0YWJsZSBob2xkcyBmb3JlaWduIGtleQogam9pbiA9PiBqb2luIHRhYmxl CiBjaGlsZElu
dmlzID0+IGNoaWxkIHRhYmxlIGhvbGRzIGZvcmVpZ24ga2V5LCBidXQgaGFz IG5vIGF0dHJp
YnV0ZSB0byByZWFkIGl0CiBjaGlsZEVtYmVkID0+IGNoaWxkIHRhYmxlIGlz IGVtYmVkZGVk
IGluIHBhcmVudCB0YWJsZQoKRXhhbXBsZSBPYmplY3QgTmFtZXM6CiBvMm9z cGFyZW50CiBv
Mm9zY2hpbGQKIG8yb3Nqb2luCQkJCiBvMm9zY2hpbGRJbnZpcwogbzJvc2No aWxkRW1iZWQK
CiBvMm9icGFyZW50CiBvMm9iY2hpbGQKIG8yb2Jqb2luCiBvMm9iY2hpbGRJ bnZpcwlwb2lu
dGxlc3MgKGl0J3Mgbm90IGJpZGlyZWN0aW9uYWwgdHJ5IG8yb3Nqb2luKQog bzJvYmNoaWxk
RW1iZWQJaW1wb3NzaWJsZSAoZW1iZWRkZWQgdHlwZSBkb2Vzbid0IGtub3cg d2hhdCBpdCBp
cyBlbWJlZGRlZCBpbnRvKQoKIG8ybXNwYXJlbnQgCQlpbXBvc3NpYmxlIChu ZWVkIG11bHRp
cGxlIG8yb3NjaGlsZEVtYmVkLCBvciBBUEkgSGVscGVyKQogbzJtc2NoaWxk CiBvMm1zam9p
bgogbzJtc2NoaWxkSW52aXMKIG8ybXNjaGlsZEVtYmVkCQoKIG8ybWJwYXJl bnQgCQlpbXBv
c3NpYmxlIChuZWVkIG11bHRpcGxlIG8yb3NjaGlsZEVtYmVkLCBvciBBUEkg SGVscGVyKQog
bzJtYmNoaWxkCiBvMm1iam9pbgogbzJtYmNoaWxkSW52aXMJaW1wb3NzaWJs ZSAoYmlkaXJl
Y3Rpb25hbCBpbXBsaWVzIGNoaWxkIGNhbiBzZWUgcGFyZW50KQogbzJtYmNo aWxkRW1iZWQg
CWltcG9zc2libGUgKG5lZWQgbXVsdGlwbGUgbzJvc2NoaWxkRW1iZWQsIG9y IEFQSSBIZWxw
ZXIpCgogbTJvc3BhcmVudAogbTJvc2NoaWxkCQlpbXBvc3NpYmxlIChjaGls ZCB3b3VsZCBi
ZWNvbWUgcGFyZW50IGFuZCB1c2UgbzJtKQogbTJvc2pvaW4KIG0yb3NjaGls ZEludmlzCWlt
cG9zc2libGUgKHNlZSBtMm9zY2hpbGQpCiBtMm9zY2hpbGRFbWJlZAlwb2lu dGxlc3MgICh1
c2UgbzJvc2NoaWxkRW1iZWQ7IGVtYmVkZGVkIHNpbmdsZSBpcyBub3QgbG9u Z2VyIGFzaW5n
bGUgaXRlbSkKCiBtMm9iKgkJCXBvaW50bGVzcyAgKHVzZSBvMm1iKikgCgog bTJtcyoJCQlw
b2ludGxlc3MgIChtMm0gaW1wbGllcyBiaWRpcmVjdGlvbmFsKQoKIG0ybWJw YXJlbnQJCWlt
cG9zc2libGUgKG5lZWQgbXVsdGlwbGUgbzJtc2NoaWxkRW1iZWQgb24gYm90 aCBzaWRlcywg
b3IgQVBJIEhlbHBlcikKIG0ybWJjaGlsZAkJaW1wb3NzaWJsZSAobmVlZCBt dWx0aXBsZSBv
Mm1zY2hpbGRFbWJlZCBvbiBib3RoIHNpZGVzLCBvciBBUEkgSGVscGVyKQog bTJtYmpvaW4K
IG0ybWJjaGlsZEludmlzCWltcG9zc2libGUgKG5lZWQgbXVsdGlwbGUgbzJt c2NoaWxkRW1i
ZWQgb24gYm90aCBzaWRlcywgb3IgQVBJIEhlbHBlcikKIG0ybWJjaGlsZEVt YmVkIAlpbXBv
c3NpYmxlIChuZWVkIG11bHRpcGxlIG8ybXNjaGlsZEVtYmVkIG9uIGJvdGgg c2lkZXMsIG9y
IEFQSSBIZWxwZXIpCgotLT4KDQoJPCEtLSB1c2VkIGJ5IG9uZSBvZiB0aGUg Y2hpbGQgb2Jq
ZWN0cywgYnV0IG5lZWRzIHRvIGJlIGRlY2xhcmVkIHVwIGhlcmUgLS0+Cgk8 eHNkOmFubm90
YXRpb24+PHhzZDphcHBpbmZvIHNvdXJjZT0idGVuZW8uanBhIj4NCgkJQEdl bmVyaWNHZW5l
cmF0b3IobmFtZT0iZm9yZWlnbiIsIHN0cmF0ZWd5ID0gImZvcmVpZ24iLCBw YXJhbWV0ZXJz
PXsNCgkJICAgIEBQYXJhbWV0ZXIobmFtZT0icHJvcGVydHkiLCB2YWx1ZT0i aWRDaGlsZCIp
DQoJCX0pIA0KCTwveHNkOmFwcGluZm8+PC94c2Q6YW5ub3RhdGlvbj4NCgkK ICA8IS0tICAg
PT09PSBDaGlsZCBUeXBlIERlZmluaXRpb25zIFN0YXJ0IEhlcmUgPT09PSAg LS0+CgogIDwh
LS0gUGFyZW4ndCBoYW5kbGVzIHRoZSBtYXBwaW5nLCBubyBjaGlsZCBhbm5v dGF0aW9ucyBu
ZWVkZWQgLS0+CiAgPHhzZDpjb21wbGV4VHlwZSBuYW1lPSJvMm9zcGFyZW50 Ij4KCTx4c2Q6
YW5ub3RhdGlvbj48eHNkOmFwcGluZm8gc291cmNlPSJ0ZW5lby5qcGEiPkBU YWJsZShuYW1l
PSJvMm9zcGFyZW50Iik8L3hzZDphcHBpbmZvPjwveHNkOmFubm90YXRpb24+ CiAgICA8eHNk
OnNlcXVlbmNlPgoJICAgIDx4c2Q6ZWxlbWVudCB0eXBlPSJ4c2Q6aW50IiBu YW1lPSJpZENo
aWxkIj4JPHhzZDphbm5vdGF0aW9uPjx4c2Q6YXBwaW5mbyBzb3VyY2U9InRl bmVvLmpwYSI+
QElkIEBHZW5lcmF0ZWRWYWx1ZShzdHJhdGVneT1BVVRPKSBAQ29sdW1uKG5h bWU9IklEQ0hJ
TEQiIHVuaXF1ZT0idHJ1ZSIpPC94c2Q6YXBwaW5mbz48L3hzZDphbm5vdGF0 aW9uPjwveHNk
OmVsZW1lbnQ+CgkgICAgPHhzZDplbGVtZW50IHR5cGU9InhzZDpzdHJpbmci IG5hbWU9ImRh
dGEiPgk8eHNkOmFubm90YXRpb24+PHhzZDphcHBpbmZvIHNvdXJjZT0idGVu ZW8uanBhIj5A
Q29sdW1uKG5hbWU9IkRBVEEiIHVuaXF1ZT0idHJ1ZSIgbGVuZ3RoPSIyNSIp PC94c2Q6YXBw
aW5mbz48L3hzZDphbm5vdGF0aW9uPjwveHNkOmVsZW1lbnQ+Cgk8L3hzZDpz ZXF1ZW5jZT4K
ICA8L3hzZDpjb21wbGV4VHlwZT4KCiAgPCEtLSBNeSBwcmltYXJ5IGtleSBt YXRjaGVzIHRo
ZSBwYXJlbnQncyBwcmltYXJ5IGtleS4gIEkgZG9uJ3QgaGF2ZSBhbiBhdHRy aWJ1dGUgZm9y
IG15IHBhcmVudCwgYnV0IHdpdGggdGhpcyBvYmplY3QgdGhlIHBhcmVudCBj b3VsZCBiZSBm
b3VuZCAtLT4NCgkJPCEtLSBub3RlIHRoYXQgdGhlIGlkIGlzIE5PVCBnZW5l cmF0ZWQgaGVy
ZS4gIEdldHRpbmcgdGhpcyB0byB3b3JrIHdpdGhvdXQgYW4gZXhjZXB0aW9u IGlzIGEgYmln
IHRyaWNrIAkJLS0+ICAgIA0KCQk8IS0tIFdlIGhhdmUgdG8gdGVsbCBoaWJl cm5hdGUgdG8g
cmVhZCB0aGUgdmFsdWUgb2YgdGhlIHBhcmVudCBhbmQgdXNlIHRoYXQgYXMg aXRzIHByaW1h
cnkga2V5LiAgT3RoZXJ3aXNlIAktLT4NCgkJPCEtLSB3ZSdsbCBnZXQgYWxs IGtpbmQgb2Yg
dmlvbGF0aW9uIGVycm9zLgkJCQkJCQkJCQkJCQkJCQkJLS0+DQogIDx4c2Q6 Y29tcGxleFR5
cGUgbmFtZT0ibzJvc2NoaWxkIj4KCTx4c2Q6YW5ub3RhdGlvbj48eHNkOmFw cGluZm8gc291
cmNlPSJ0ZW5lby5qcGEiPkBUYWJsZShuYW1lPSJvMm9zY2hpbGQiKTwveHNk OmFwcGluZm8+
PC94c2Q6YW5ub3RhdGlvbj4KICAgIDx4c2Q6c2VxdWVuY2U+DQoJICAgIDx4 c2Q6ZWxlbWVu
dCB0eXBlPSJ4c2Q6aW50IiBuYW1lPSJpZENoaWxkIj4JPHhzZDphbm5vdGF0 aW9uPjx4c2Q6
YXBwaW5mbyBzb3VyY2U9InRlbmVvLmpwYSI+DQoJICAgIEBJZCANCgkgICAg QEdlbmVyYXRl
ZFZhbHVlKGdlbmVyYXRvcj0iZm9yZWlnbiIpDQoJCUBDb2x1bW4obmFtZT0i SURDSElMRCIp
DQoJCTwveHNkOmFwcGluZm8+PC94c2Q6YW5ub3RhdGlvbj48L3hzZDplbGVt ZW50PgoJICAg
IDx4c2Q6ZWxlbWVudCB0eXBlPSJ4c2Q6c3RyaW5nIiBuYW1lPSJkYXRhIj4J PHhzZDphbm5v
dGF0aW9uPjx4c2Q6YXBwaW5mbyBzb3VyY2U9InRlbmVvLmpwYSI+QENvbHVt bihuYW1lPSJE
QVRBIiB1bmlxdWU9InRydWUiIGxlbmd0aD0iMjUiKTwveHNkOmFwcGluZm8+ PC94c2Q6YW5u
b3RhdGlvbj48L3hzZDplbGVtZW50PgoJPC94c2Q6c2VxdWVuY2U+CiAgPC94 c2Q6Y29tcGxl
eFR5cGU+DQogCiAgPCEtLSBUaGUgcGFyZW50IGhhcyBoYW5kbGVkIGV2ZXJ5 dGhpbmcgbmVl
ZGVkIGZvciB0aGlzIGFzc29jaWF0aW9uLiAgVGhlIGNoaWxkIGNhbm5vdCBz ZWUgdGhlIHBh
cmVudC4gLS0+DQogIDx4c2Q6Y29tcGxleFR5cGUgbmFtZT0ibzJvc2pvaW4i PgoJPHhzZDph
bm5vdGF0aW9uPjx4c2Q6YXBwaW5mbyBzb3VyY2U9InRlbmVvLmpwYSI+QFRh YmxlKG5hbWU9
Im8yb3Nqb2luIik8L3hzZDphcHBpbmZvPjwveHNkOmFubm90YXRpb24+CiAg ICA8eHNkOnNl
cXVlbmNlPgoJICAgIDx4c2Q6ZWxlbWVudCB0eXBlPSJ4c2Q6aW50IiBuYW1l PSJpZENoaWxk
Ij4JPHhzZDphbm5vdGF0aW9uPjx4c2Q6YXBwaW5mbyBzb3VyY2U9InRlbmVv LmpwYSI+QElk
IEBHZW5lcmF0ZWRWYWx1ZShzdHJhdGVneT1BVVRPKSBAQ29sdW1uKG5hbWU9 IklEQ0hJTEQi
IHVuaXF1ZT0idHJ1ZSIpPC94c2Q6YXBwaW5mbz48L3hzZDphbm5vdGF0aW9u PjwveHNkOmVs
ZW1lbnQ+CgkgICAgPHhzZDplbGVtZW50IHR5cGU9InhzZDpzdHJpbmciIG5h bWU9ImRhdGEi
Pgk8eHNkOmFubm90YXRpb24+PHhzZDphcHBpbmZvIHNvdXJjZT0idGVuZW8u anBhIj5AQ29s
dW1uKG5hbWU9IkRBVEEiIHVuaXF1ZT0idHJ1ZSIgbGVuZ3RoPSIyNSIpPC94 c2Q6YXBwaW5m
bz48L3hzZDphbm5vdGF0aW9uPjwveHNkOmVsZW1lbnQ+Cgk8L3hzZDpzZXF1 ZW5jZT4KICA8
L3hzZDpjb21wbGV4VHlwZT4KCiAgPCEtLSBUaGUgcGFyZW50IHdpbGwgYWRk IGFuIHVubWFw
cGVkIGNvbHVtbiB0byBteSB0YWJsZS4gIEdpdmVuIG9ubHkgdGhlIGNoaWxk IG9iamVjdCwg
dGhpcyBwYXJlbnQgb2JqZWN0IGNvdWxkIG5vdCBiZSBmb3VuZCB3aXRob3V0 IGRyb3BwaW5n
IHRvIFNRTC4gSSBhbHNvIGhhdmUgbm8gSmF2YSBkZXBlbmRlbmNpZXMgb24g dGhlIHBhcmVu
dCBjbGFzcy4gLS0+CiAgPHhzZDpjb21wbGV4VHlwZSBuYW1lPSJvMm9zY2hp bGRJbnZpcyI+
Cgk8eHNkOmFubm90YXRpb24+PHhzZDphcHBpbmZvIHNvdXJjZT0idGVuZW8u anBhIj5AVGFi
bGUobmFtZT0ibzJvc2NoaWxkSW52aXMiKTwveHNkOmFwcGluZm8+PC94c2Q6 YW5ub3RhdGlv
bj4KICAgIDx4c2Q6c2VxdWVuY2U+CgkgICAgPHhzZDplbGVtZW50IHR5cGU9 InhzZDppbnQi
IG5hbWU9ImlkQ2hpbGQiPgk8eHNkOmFubm90YXRpb24+PHhzZDphcHBpbmZv IHNvdXJjZT0i
dGVuZW8uanBhIj5ASWQgQEdlbmVyYXRlZFZhbHVlKHN0cmF0ZWd5PUFVVE8p IEBDb2x1bW4o
bmFtZT0iSURDSElMRCIgdW5pcXVlPSJ0cnVlIik8L3hzZDphcHBpbmZvPjwv eHNkOmFubm90
YXRpb24+PC94c2Q6ZWxlbWVudD4KCSAgICA8eHNkOmVsZW1lbnQgdHlwZT0i eHNkOnN0cmlu
ZyIgbmFtZT0iZGF0YSI+CTx4c2Q6YW5ub3RhdGlvbj48eHNkOmFwcGluZm8g c291cmNlPSJ0
ZW5lby5qcGEiPkBDb2x1bW4obmFtZT0iREFUQSIgdW5pcXVlPSJ0cnVlIiBs ZW5ndGg9IjI1
Iik8L3hzZDphcHBpbmZvPjwveHNkOmFubm90YXRpb24+PC94c2Q6ZWxlbWVu dD4KCTwveHNk
OnNlcXVlbmNlPgogIDwveHNkOmNvbXBsZXhUeXBlPgoKICA8IS0tIFRoaXMg b2JqZWN0IGlz
IG5vdCBhbGxvd2VkIHRvIGhhdmUgYSBwcmltYXJ5IGtleSEgIEFsc28gaXQg bXVzdCBiZSBt
YXJrZWQgYXMgZW1iZWRhYmxlLCBhbmQgaGF2ZSBubyB0YWJsZSBzcGVjaWZp ZWQuICBEaWZm
ZXJlbnQgZGF0YSBjb2x1bW4gZm9yIGNsYXJpdHkgLS0+CiAgPHhzZDpjb21w bGV4VHlwZSBu
YW1lPSJPMm9zY2hpbGRFbWJlZCI+Cgk8eHNkOmFubm90YXRpb24+PHhzZDph cHBpbmZvIHNv
dXJjZT0idGVuZW8uanBhIj5ARW1iZWRkYWJsZTwveHNkOmFwcGluZm8+PC94 c2Q6YW5ub3Rh
dGlvbj4KICAgIDx4c2Q6c2VxdWVuY2U+CgkgICAgPHhzZDplbGVtZW50IHR5 cGU9InhzZDpz
dHJpbmciIG5hbWU9InBob25lIj48eHNkOmFubm90YXRpb24+PHhzZDphcHBp bmZvIHNvdXJj
ZT0idGVuZW8uanBhIj5AQ29sdW1uKG5hbWU9InBob25lIiB1bmlxdWU9InRy dWUiIGxlbmd0
aD0iMjUiKTwveHNkOmFwcGluZm8+PC94c2Q6YW5ub3RhdGlvbj48L3hzZDpl bGVtZW50PgoJ
PC94c2Q6c2VxdWVuY2U+CiAgPC94c2Q6Y29tcGxleFR5cGU+CgogIDwhLS0g VGhpcyBjaGls
ZCBjYW4gZmluZCBpdHMgcGFyZW50LiAgVGhlIHBhcmVudCBob2xkcyB0aGUg Zm9yZWlnbiBr
ZXkgY29sdW1uIC0tPgogIDx4c2Q6Y29tcGxleFR5cGUgbmFtZT0ibzJvYnBh cmVudCI+Cgk8
eHNkOmFubm90YXRpb24+PHhzZDphcHBpbmZvIHNvdXJjZT0idGVuZW8uanBh Ij5AVGFibGUo
bmFtZT0ibzJvYnBhcmVudCIpPC94c2Q6YXBwaW5mbz48L3hzZDphbm5vdGF0 aW9uPgogICAg
PHhzZDpzZXF1ZW5jZT4KCSAgICA8eHNkOmVsZW1lbnQgdHlwZT0ieHNkOmlu dCIgbmFtZT0i
aWRDaGlsZCI+CTx4c2Q6YW5ub3RhdGlvbj48eHNkOmFwcGluZm8gc291cmNl PSJ0ZW5lby5q
cGEiPkBJZCBAR2VuZXJhdGVkVmFsdWUoc3RyYXRlZ3k9QVVUTykgQENvbHVt bihuYW1lPSJJ
RENISUxEIiB1bmlxdWU9InRydWUiKTwveHNkOmFwcGluZm8+PC94c2Q6YW5u b3RhdGlvbj48
L3hzZDplbGVtZW50PgoJICAgIDx4c2Q6ZWxlbWVudCB0eXBlPSJ4c2Q6c3Ry aW5nIiBuYW1l
PSJkYXRhIj4JPHhzZDphbm5vdGF0aW9uPjx4c2Q6YXBwaW5mbyBzb3VyY2U9 InRlbmVvLmpw
YSI+QENvbHVtbihuYW1lPSJEQVRBIiB1bmlxdWU9InRydWUiIGxlbmd0aD0i MjUiKTwveHNk
OmFwcGluZm8+PC94c2Q6YW5ub3RhdGlvbj48L3hzZDplbGVtZW50PgoJICAg IDx4c2Q6ZWxl
bWVudCB0eXBlPSJQYXJlbnQiIG5hbWU9InBhcmVudCI+CTx4c2Q6YW5ub3Rh dGlvbj48eHNk
OmFwcGluZm8gc291cmNlPSJ0ZW5lby5qcGEiPkBPbmVUb09uZShtYXBwZWRC eT0ibzJvYnBh
cmVudCIpPC94c2Q6YXBwaW5mbz48L3hzZDphbm5vdGF0aW9uPjwveHNkOmVs ZW1lbnQ+Cgk8
L3hzZDpzZXF1ZW5jZT4KICA8L3hzZDpjb21wbGV4VHlwZT4KCiAgPCEtLSBU aGlzIGNoaWxk
IGNhbiBmaW5kIGl0cyBwYXJlbnQuICBUaGUgY2hpbGQgaG9sZHMgdGhlIGZv cmVpZ24ga2V5
IGNvbHVtbiAtLT4KICA8eHNkOmNvbXBsZXhUeXBlIG5hbWU9Im8yb2JjaGls ZCI+Cgk8eHNk
OmFubm90YXRpb24+PHhzZDphcHBpbmZvIHNvdXJjZT0idGVuZW8uanBhIj5A VGFibGUobmFt
ZT0ibzJvYmNoaWxkIik8L3hzZDphcHBpbmZvPjwveHNkOmFubm90YXRpb24+ CiAgICA8eHNk
aW5mbz48L3hzZDphbm5vdGF0aW9uPjwveHNkOmVsZW1lbnQ+CgkgICAgPHhz ZDplbGVtZW50
IHR5cGU9IlBhcmVudCIgbmFtZT0icGFyZW50Ij4JPHhzZDphbm5vdGF0aW9u Pjx4c2Q6YXBw
aW5mbyBzb3VyY2U9InRlbmVvLmpwYSI+QE9uZVRvT25lIEBKb2luQ29sdW1u KG5hbWU9IlBB
UkVOVCIpPC94c2Q6YXBwaW5mbz48L3hzZDphbm5vdGF0aW9uPjwveHNkOmVs ZW1lbnQ+Cgk8
L3hzZDpzZXF1ZW5jZT4KICA8L3hzZDpjb21wbGV4VHlwZT4KCiAgPCEtLSBU aGUgcGFyZW50
IGNvdmVyZWQgZGVmaW5pbmcgdGhlIGpvaW4uICBJIGp1c3QgYWRkIHRoZSBh bm5vdGF0aW9u
IHNvIEkgY2FuIGZpbmQgbXkgd2F5IHRvIHRoZSBwYXJlbnQgYW5kIG1lbnRp b24gd2hpY2gg
cGFyZW50IGZpZWxkIEkgYmVsb25nIHRvIC0tPgogIDx4c2Q6Y29tcGxleFR5 cGUgbmFtZT0i
bzJvYmpvaW4iPgoJPHhzZDphbm5vdGF0aW9uPjx4c2Q6YXBwaW5mbyBzb3Vy Y2U9InRlbmVv
LmpwYSI+QFRhYmxlKG5hbWU9Im8yb2Jqb2luIik8L3hzZDphcHBpbmZvPjwv eHNkOmFubm90
YXRpb24+CiAgICA8eHNkOnNlcXVlbmNlPgoJICAgIDx4c2Q6ZWxlbWVudCB0 eXBlPSJ4c2Q6
aW50IiBuYW1lPSJpZENoaWxkIj4JPHhzZDphbm5vdGF0aW9uPjx4c2Q6YXBw aW5mbyBzb3Vy
Y2U9InRlbmVvLmpwYSI+QElkIEBHZW5lcmF0ZWRWYWx1ZShzdHJhdGVneT1B VVRPKSBAQ29s
dW1uKG5hbWU9IklEQ0hJTEQiIHVuaXF1ZT0idHJ1ZSIpPC94c2Q6YXBwaW5m bz48L3hzZDph
bm5vdGF0aW9uPjwveHNkOmVsZW1lbnQ+CgkgICAgPHhzZDplbGVtZW50IHR5 cGU9InhzZDpz
dHJpbmciIG5hbWU9ImRhdGEiPgk8eHNkOmFubm90YXRpb24+PHhzZDphcHBp bmZvIHNvdXJj
ZT0idGVuZW8uanBhIj5AQ29sdW1uKG5hbWU9IkRBVEEiIHVuaXF1ZT0idHJ1 ZSIgbGVuZ3Ro
PSIyNSIpPC94c2Q6YXBwaW5mbz48L3hzZDphbm5vdGF0aW9uPjwveHNkOmVs ZW1lbnQ+Cgkg
ICAgPHhzZDplbGVtZW50IHR5cGU9IlBhcmVudCIgbmFtZT0icGFyZW50Ij4J PHhzZDphbm5v
dGF0aW9uPjx4c2Q6YXBwaW5mbyBzb3VyY2U9InRlbmVvLmpwYSI+QE9uZVRv T25lKG1hcHBl
ZEJ5PSJvMm9iam9pbiIpPC94c2Q6YXBwaW5mbz48L3hzZDphbm5vdGF0aW9u PjwveHNkOmVs
ZW1lbnQ+Cgk8L3hzZDpzZXF1ZW5jZT4KICA8L3hzZDpjb21wbGV4VHlwZT4K CiAgPCEtLSBJ
IGNhbid0IHVzZSB0aGUgcHJpbWFyeSBrZXkgZm9yIHRoZSBhc3NvY2lhdGlv biBiZWNhdXNl
IGNoaWxkIGhvbGRzIHRoZSBGSy4gQnV0IEknbSBhbHNvIHN1cHBvc2VkIHRv IGJlIHVuaS1k
aXJlY3Rpb25hbCBmcm9tIHRoZSBwYXJlbnQuIFNvbHV0aW9uOiBNYWtlIHRo ZSBwYXJlbnQg
YWNjZXNzb3IgcHJpdmF0ZSAtLT4KICA8eHNkOmNvbXBsZXhUeXBlIG5hbWU9 Im8ybXNjaGls
ZCI+Cgk8eHNkOmFubm90YXRpb24+PHhzZDphcHBpbmZvIHNvdXJjZT0idGVu ZW8uanBhIj5A
VGFibGUobmFtZT0ibzJtc2NoaWxkIik8L3hzZDphcHBpbmZvPjwveHNkOmFu bm90YXRpb24+
CiAgICA8eHNkOnNlcXVlbmNlPgoJICAgIDx4c2Q6ZWxlbWVudCB0eXBlPSJ4 c2Q6aW50IiBu
YW1lPSJpZENoaWxkIj4JPHhzZDphbm5vdGF0aW9uPjx4c2Q6YXBwaW5mbyBz b3VyY2U9InRl
bmVvLmpwYSI+QElkIEBHZW5lcmF0ZWRWYWx1ZShzdHJhdGVneT1BVVRPKSBA Q29sdW1uKG5h
bWU9IklEQ0hJTEQiIHVuaXF1ZT0idHJ1ZSIpPC94c2Q6YXBwaW5mbz48L3hz ZDphbm5vdGF0
aW9uPjwveHNkOmVsZW1lbnQ+CgkgICAgPHhzZDplbGVtZW50IHR5cGU9Inhz ZDpzdHJpbmci
IG5hbWU9ImRhdGEiPgk8eHNkOmFubm90YXRpb24+PHhzZDphcHBpbmZvIHNv dXJjZT0idGVu
ZW8uanBhIj5AQ29sdW1uKG5hbWU9IkRBVEEiIHVuaXF1ZT0idHJ1ZSIgbGVu Z3RoPSIyNSIp
PC94c2Q6YXBwaW5mbz48L3hzZDphbm5vdGF0aW9uPjwveHNkOmVsZW1lbnQ+ CgkgICAgPHhz
ZDplbGVtZW50IHR5cGU9IlBhcmVudCIgbmFtZT0icGFyZW50IiBlY29yZTpz dXBwcmVzc1Nl
dFZpc2liaWxpdHk9J3RydWUnICBlY29yZTpzdXBwcmVzc0dldFZpc2liaWxp dHk9J3RydWUn
PgkKCSAgICAJCQkJCQkJCQkJCTx4c2Q6YW5ub3RhdGlvbj48eHNkOmFwcGlu Zm8gc291cmNl
PSJ0ZW5lby5qcGEiPkBPbmVUb09uZShtYXBwZWRCeT0ibzJvYmpvaW4iKTwv eHNkOmFwcGlu
Zm8+PC94c2Q6YW5ub3RhdGlvbj48L3hzZDplbGVtZW50PgoJPC94c2Q6c2Vx dWVuY2U+CiAg
PC94c2Q6Y29tcGxleFR5cGU+CgogIDwhLS0gSW4gdGhlIGpvaW4gdGFibGUg Y2FzZSwgdGhl
IHBhcmVudCBoYXMgYWxyZWFkeSBkb25lIGFsbCB0aGUgbWFwcGluZyBuZWVk ZWQuICBUaGlz
IG1ha2VzIHRoZSBwYXJlbnQgSW52aXNpYmxlLCBidXQgd2l0aG91dCB0aGUg J3NlY3JldCBj
b2x1bW4nIG5lZWRlZCBpbiB0aGUgbmV4dCBleGFtcGxlIC0tPgogIDx4c2Q6 Y29tcGxleFR5
cGUgbmFtZT0ibzJtc2pvaW4iPgoJPHhzZDphbm5vdGF0aW9uPjx4c2Q6YXBw aW5mbyBzb3Vy
Y2U9InRlbmVvLmpwYSI+QFRhYmxlKG5hbWU9Im8ybXNqb2luIik8L3hzZDph cHBpbmZvPjwv
eHNkOmFubm90YXRpb24+CiAgICA8eHNkOnNlcXVlbmNlPgoJICAgIDx4c2Q6 ZWxlbWVudCB0
eXBlPSJ4c2Q6aW50IiBuYW1lPSJpZENoaWxkIj4JPHhzZDphbm5vdGF0aW9u Pjx4c2Q6YXBw
aW5mbyBzb3VyY2U9InRlbmVvLmpwYSI+QElkIEBHZW5lcmF0ZWRWYWx1ZShz dHJhdGVneT1B
VVRPKSBAQ29sdW1uKG5hbWU9IklEQ0hJTEQiIHVuaXF1ZT0idHJ1ZSIpPC94 c2Q6YXBwaW5m
bz48L3hzZDphbm5vdGF0aW9uPjwveHNkOmVsZW1lbnQ+CgkgICAgPHhzZDpl bGVtZW50IHR5
cGU9InhzZDpzdHJpbmciIG5hbWU9ImRhdGEiPgk8eHNkOmFubm90YXRpb24+ PHhzZDphcHBp
bmZvIHNvdXJjZT0idGVuZW8uanBhIj5AQ29sdW1uKG5hbWU9IkRBVEEiIHVu aXF1ZT0idHJ1
ZSIgbGVuZ3RoPSIyNSIpPC94c2Q6YXBwaW5mbz48L3hzZDphbm5vdGF0aW9u PjwveHNkOmVs
biB0aGUgSW52aXNpYmxlIGNhc2Ugd2Ugd2FudCB0byBoYXZlIG5vIG1lbnRp b24gb2YgdGhl
IHBhcmVudCBhdCBhbGwuICBUaGUgb25seSB3YXkgaXMgdG8gaWdub3JlIHRo ZSBwYXJlbnQg
bWFwcGluZyBhbmQgbGV0IFRlbmVvIGFkZCBpdCB3aXRob3V0IHRoZSBjbGFz cyBrbm93aW5n
IGFib3V0IGl0LiAtLT4KICA8eHNkOmNvbXBsZXhUeXBlIG5hbWU9Im8ybXNj aGlsZEludmlz
Ij4KCTx4c2Q6YW5ub3RhdGlvbj48eHNkOmFwcGluZm8gc291cmNlPSJ0ZW5l by5qcGEiPkBU
YWJsZShuYW1lPSJvMm1zY2hpbGRJbnZpcyIpPC94c2Q6YXBwaW5mbz48L3hz ZDphbm5vdGF0
aW9uPgogICAgPHhzZDpzZXF1ZW5jZT4KCSAgICA8eHNkOmVsZW1lbnQgdHlw ZT0ieHNkOmlu
dCIgbmFtZT0iaWRDaGlsZCI+CTx4c2Q6YW5ub3RhdGlvbj48eHNkOmFwcGlu Zm8gc291cmNl
PSJ0ZW5lby5qcGEiPkBJZCBAR2VuZXJhdGVkVmFsdWUoc3RyYXRlZ3k9QVVU TykgQENvbHVt
bihuYW1lPSJJRENISUxEIiB1bmlxdWU9InRydWUiKTwveHNkOmFwcGluZm8+ PC94c2Q6YW5u
b3RhdGlvbj48L3hzZDplbGVtZW50PgoJICAgIDx4c2Q6ZWxlbWVudCB0eXBl PSJ4c2Q6c3Ry
aW5nIiBuYW1lPSJkYXRhIj4JPHhzZDphbm5vdGF0aW9uPjx4c2Q6YXBwaW5m byBzb3VyY2U9
InRlbmVvLmpwYSI+QENvbHVtbihuYW1lPSJEQVRBIiB1bmlxdWU9InRydWUi IGxlbmd0aD0i
MjUiKTwveHNkOmFwcGluZm8+PC94c2Q6YW5ub3RhdGlvbj48L3hzZDplbGVt ZW50PgoJPC94
c2Q6c2VxdWVuY2U+CiAgPC94c2Q6Y29tcGxleFR5cGU+CgogIDwhLS0gVGhp cyBjaGlsZCBj
bGFzcyB3aWxsIGJlIGVtYmVkZGVkIGp1c3QgbGlrZSB0aGUgb3RoZXIuICBO byB0YWJsZSBu
YW1lIGFsbG93ZWQsIGFuZCBubyBpZCBjb2x1bW4gYWxsb3dlZC4gRm9yIGls bHVzdHJhdGlv
biBpdCBpcyBhbHNvIGdpdmVuIGRpZmZlcmVudCBkYXRhIGNvbHVtbnMgLS0+ CiAgPHhzZDpj
b21wbGV4VHlwZSBuYW1lPSJvMm1zY2hpbGRFbWJlZCI+Cgk8eHNkOmFubm90 YXRpb24+PHhz
ZDphcHBpbmZvIHNvdXJjZT0idGVuZW8uanBhIj5ARW1iZWRkYWJsZTwveHNk OmFwcGluZm8+
PC94c2Q6YW5ub3RhdGlvbj4KICAgIDx4c2Q6c2VxdWVuY2U+CgkgICAgPHhz ZDplbGVtZW50
IHR5cGU9InhzZDpzdHJpbmciIG5hbWU9ImNpdHkiPgk8eHNkOmFubm90YXRp b24+PHhzZDph
cHBpbmZvIHNvdXJjZT0idGVuZW8uanBhIj5AQ29sdW1uKG5hbWU9IkNJVFki ICBsZW5ndGg9
IjI1Iik8L3hzZDphcHBpbmZvPjwveHNkOmFubm90YXRpb24+PC94c2Q6ZWxl bWVudD4KCSAg
ICA8eHNkOmVsZW1lbnQgdHlwZT0ieHNkOnN0cmluZyIgbmFtZT0ic3RhdGUi Pjx4c2Q6YW5u
b3RhdGlvbj48eHNkOmFwcGluZm8gc291cmNlPSJ0ZW5lby5qcGEiPkBDb2x1 bW4obmFtZT0i
U1RBVEUiIGxlbmd0aD0iMiIpPC94c2Q6YXBwaW5mbz48L3hzZDphbm5vdGF0 aW9uPjwveHNk
OmVsZW1lbnQ+Cgk8L3hzZDpzZXF1ZW5jZT4KICA8L3hzZDpjb21wbGV4VHlw ZT4KCiAgPCEt
LSBUaGlzIGlzIHRoZSBtb3N0IHN0cmFpZ2h0IGZvcndhcmQgb25lIHRvIG1h bnkgY2FzZSAt
LT4KICA8eHNkOmNvbXBsZXhUeXBlIG5hbWU9Im8ybWJjaGlsZCI+Cgk8eHNk OmFubm90YXRp
b24+PHhzZDphcHBpbmZvIHNvdXJjZT0idGVuZW8uanBhIj5AVGFibGUobmFt ZT0ibzJtYmNo
aWxkIik8L3hzZDphcHBpbmZvPjwveHNkOmFubm90YXRpb24+CiAgICA8eHNk OnNlcXVlbmNl
PgoJICAgIDx4c2Q6ZWxlbWVudCB0eXBlPSJ4c2Q6aW50IiBuYW1lPSJpZENo aWxkIj4JPHhz
ZDphbm5vdGF0aW9uPjx4c2Q6YXBwaW5mbyBzb3VyY2U9InRlbmVvLmpwYSI+ QElkIEBHZW5l
cmF0ZWRWYWx1ZShzdHJhdGVneT1BVVRPKSBAQ29sdW1uKG5hbWU9IklEQ0hJ TEQiIHVuaXF1
ZT0idHJ1ZSIpPC94c2Q6YXBwaW5mbz48L3hzZDphbm5vdGF0aW9uPjwveHNk OmVsZW1lbnQ+
CgkgICAgPHhzZDplbGVtZW50IHR5cGU9InhzZDpzdHJpbmciIG5hbWU9ImRh dGEiPgk8eHNk
OmFubm90YXRpb24+PHhzZDphcHBpbmZvIHNvdXJjZT0idGVuZW8uanBhIj5A Q29sdW1uKG5h
bWU9IkRBVEEiIHVuaXF1ZT0idHJ1ZSIgbGVuZ3RoPSIyNSIpPC94c2Q6YXBw aW5mbz48L3hz
ZDphbm5vdGF0aW9uPjwveHNkOmVsZW1lbnQ+CgkgICAgPHhzZDplbGVtZW50 IHR5cGU9IlBh
cmVudCIgbmFtZT0icGFyZW50Ij4JPHhzZDphbm5vdGF0aW9uPjx4c2Q6YXBw aW5mbyBzb3Vy
Y2U9InRlbmVvLmpwYSI+QE1hbnlUb09uZSBASm9pbkNvbHVtbihuYW1lPSJw YXJlbnQiKTwv
eHNkOmFwcGluZm8+PC94c2Q6YW5ub3RhdGlvbj48L3hzZDplbGVtZW50PgoJ PC94c2Q6c2Vx
dWVuY2U+CiAgPC94c2Q6Y29tcGxleFR5cGU+CgogIDwhLS0gdGhlIHBhcmVu dCBoYXMgdGFr
ZW4gY2FyZSBvZiBhbGwgdGhlIGFubm90YXRpb25zIG5lZWRlZCAtLT4KICA8 eHNkOmNvbXBs
ZXhUeXBlIG5hbWU9Im8ybWJqb2luIj4KCTx4c2Q6YW5ub3RhdGlvbj48eHNk OmFwcGluZm8g
c291cmNlPSJ0ZW5lby5qcGEiPkBUYWJsZShuYW1lPSJvMm1iam9pbiIpPC94 c2Q6YXBwaW5m
bz48L3hzZDphbm5vdGF0aW9uPgogICAgPHhzZDpzZXF1ZW5jZT4KCSAgICA8 eHNkOmVsZW1l
bnQgdHlwZT0ieHNkOmludCIgbmFtZT0iaWRDaGlsZCI+CTx4c2Q6YW5ub3Rh dGlvbj48eHNk
OmFwcGluZm8gc291cmNlPSJ0ZW5lby5qcGEiPkBJZCBAR2VuZXJhdGVkVmFs dWUoc3RyYXRl
Z3k9QVVUTykgQENvbHVtbihuYW1lPSJJRENISUxEIiB1bmlxdWU9InRydWUi KTwveHNkOmFw
cGluZm8+PC94c2Q6YW5ub3RhdGlvbj48L3hzZDplbGVtZW50PgoJICAgIDx4 c2Q6ZWxlbWVu
dCB0eXBlPSJ4c2Q6c3RyaW5nIiBuYW1lPSJkYXRhIj4JPHhzZDphbm5vdGF0 aW9uPjx4c2Q6
YXBwaW5mbyBzb3VyY2U9InRlbmVvLmpwYSI+QENvbHVtbihuYW1lPSJEQVRB IiB1bmlxdWU9
InRydWUiIGxlbmd0aD0iMjUiKTwveHNkOmFwcGluZm8+PC94c2Q6YW5ub3Rh dGlvbj48L3hz
ZDplbGVtZW50PgoJICAgIDx4c2Q6ZWxlbWVudCB0eXBlPSJQYXJlbnQiIG5h bWU9InBhcmVu
dCI+CTx4c2Q6YW5ub3RhdGlvbj48eHNkOmFwcGluZm8gc291cmNlPSJ0ZW5l by5qcGEiPkBN
YW55VG9PbmUgQEpvaW5UYWJsZShuYW1lPSJvMm1iam9pbmpvaW50YWJsZSIs IGpvaW5Db2x1
bW5zID0geyBASm9pbkNvbHVtbihuYW1lPSJpZENoaWxkIiwgdW5pcXVlID0g dHJ1ZSkgfSwg
aW52ZXJzZUpvaW5Db2x1bW5zID0geyBASm9pbkNvbHVtbihuYW1lPSJpZCIp IH0gKTwveHNk
OmFwcGluZm8+PC94c2Q6YW5ub3RhdGlvbj48L3hzZDplbGVtZW50PgoJPC94 c2Q6c2VxdWVu
Y2U+CiAgPC94c2Q6Y29tcGxleFR5cGU+CgogIDwhLS0gVGhpcyBvYmplY3Qg aGFzIG5vIGF3
YXJlbmVzcyBvZiB0aGUgcGFyZW50LiAgVGhpcyBjb3VsZCBiZSBhIHJldXNh YmxlIGNvZGUg
b3Igb2Z0ZW4gcmVmZXJlbmNlZCBhbmQgZWFzaWx5IHNoYXJlZCBkYXRhIG9i amVjdCAtLT4K
ICA8eHNkOmNvbXBsZXhUeXBlIG5hbWU9Im0yb3NwYXJlbnQiPgoJPHhzZDph bm5vdGF0aW9u
Pjx4c2Q6YXBwaW5mbyBzb3VyY2U9InRlbmVvLmpwYSI+QFRhYmxlKG5hbWU9 Im0yb3NwYXJl
bnQiKTwveHNkOmFwcGluZm8+PC94c2Q6YW5ub3RhdGlvbj4KICAgIDx4c2Q6 c2VxdWVuY2U+
CgkgICAgPHhzZDplbGVtZW50IHR5cGU9InhzZDppbnQiIG5hbWU9ImlkQ2hp bGQiPgk8eHNk
OmFubm90YXRpb24+PHhzZDphcHBpbmZvIHNvdXJjZT0idGVuZW8uanBhIj5A SWQgQEdlbmVy
YXRlZFZhbHVlKHN0cmF0ZWd5PUFVVE8pIEBDb2x1bW4obmFtZT0iSURDSElM RCIgdW5pcXVl
PSJ0cnVlIik8L3hzZDphcHBpbmZvPjwveHNkOmFubm90YXRpb24+PC94c2Q6 ZWxlbWVudD4K
CSAgICA8eHNkOmVsZW1lbnQgdHlwZT0ieHNkOnN0cmluZyIgbmFtZT0iZGF0 YSI+CTx4c2Q6
YW5ub3RhdGlvbj48eHNkOmFwcGluZm8gc291cmNlPSJ0ZW5lby5qcGEiPkBD b2x1bW4obmFt
ZT0iREFUQSIgdW5pcXVlPSJ0cnVlIiBsZW5ndGg9IjI1Iik8L3hzZDphcHBp bmZvPjwveHNk
OmFubm90YXRpb24+PC94c2Q6ZWxlbWVudD4KCTwveHNkOnNlcXVlbmNlPgog IDwveHNkOmNv
bXBsZXhUeXBlPgoKICA8IS0tIEFnYWluLCB0aGlzIG9iamVjdCBoYXMgbm8g YXdhcmVuZXNz
IG9mIHRoZSBwYXJlbnQuICBUaGlzIGNvdWxkIGJlIGEgcmV1c2FibGUgY29k ZSBvciBvZnRl
biByZWZlcmVuY2VkIGFuZCBlYXNpbHkgc2hhcmVkIGRhdGEgb2JqZWN0IC0t PgogIDx4c2Q6
Y29tcGxleFR5cGUgbmFtZT0ibTJvc2pvaW4iPgoJPHhzZDphbm5vdGF0aW9u Pjx4c2Q6YXBw
aW5mbyBzb3VyY2U9InRlbmVvLmpwYSI+QFRhYmxlKG5hbWU9Im0yb3Nqb2lu Iik8L3hzZDph
cHBpbmZvPjwveHNkOmFubm90YXRpb24+CiAgICA8eHNkOnNlcXVlbmNlPgoJ ICAgIDx4c2Q6
ZWxlbWVudCB0eXBlPSJ4c2Q6aW50IiBuYW1lPSJpZENoaWxkIj4JPHhzZDph bm5vdGF0aW9u
Pjx4c2Q6YXBwaW5mbyBzb3VyY2U9InRlbmVvLmpwYSI+QElkIEBHZW5lcmF0 ZWRWYWx1ZShz
dHJhdGVneT1BVVRPKSBAQ29sdW1uKG5hbWU9IklEQ0hJTEQiIHVuaXF1ZT0i dHJ1ZSIpPC94
c2Q6YXBwaW5mbz48L3hzZDphbm5vdGF0aW9uPjwveHNkOmVsZW1lbnQ+Cgkg ICAgPHhzZDpl
bGVtZW50IHR5cGU9InhzZDpzdHJpbmciIG5hbWU9ImRhdGEiPgk8eHNkOmFu bm90YXRpb24+
PHhzZDphcHBpbmZvIHNvdXJjZT0idGVuZW8uanBhIj5AQ29sdW1uKG5hbWU9 IkRBVEEiIHVu
aXF1ZT0idHJ1ZSIgbGVuZ3RoPSIyNSIpPC94c2Q6YXBwaW5mbz48L3hzZDph bm5vdGF0aW9u
PjwveHNkOmVsZW1lbnQ+Cgk8L3hzZDpzZXF1ZW5jZT4KICA8L3hzZDpjb21w bGV4VHlwZT4K
CiAgPCEtLSBUaGlzIHR5cGUgY2Fubm90IGJlIHN1cHBvcnRlZCBieSBKUnVs ZXMgYW5kIHJl
cXVpcmVzIHNwZWNpYWwgaGFuZGxpbmcgYnkgRU1GLiAgTm90aWNlIHRoYXQg dGhlIHR5cGUg
aXMgSURSRUYuICBSZWZlciB0byB0aGUgZWFybGllciBleGFtcGxlIFhTRCB0 byBzZWUgaG93
IHRvIG1hbmFnZSB0aGVzZSAtLT4KICA8IS0tIElmIHlvdSBuZWVkIFVSTHMg aW5zdGVhZCBv
ZiBpbi1kb2N1bWVudCByZWZlcmVuY2VzIGxvb2sgYWhlYWQgdG8gdGhlIGFu eVVSSSBleGFt
cGxlcyAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC0tPg0KICA8 eHNkOmNvbXBs
ZXhUeXBlIG5hbWU9Im0ybWJqb2luIj4KCTx4c2Q6YW5ub3RhdGlvbj48eHNk OmFwcGluZm8g
c291cmNlPSJ0ZW5lby5qcGEiPkBUYWJsZShuYW1lPSJtMm1iam9pbiIpPC94 c2Q6YXBwaW5m
bnQgdHlwZT0ieHNkOmludCIgbmFtZT0iaWQiPgkJPHhzZDphbm5vdGF0aW9u Pjx4c2Q6YXBw
ZW1lbnQ+CgkgICAgPHhzZDplbGVtZW50IHR5cGU9InhzZDpJRFJFRiIgZWNv cmU6cmVmZXJl
bmNlPSJQYXJlbnQiIG5hbWU9InBhcmVudCIgZWNv
Re: Two problems @GenericGenerate strategy="foreign" and @ManyToMany [message #118645 is a reply to message #118628] |
Wed, 16 April 2008 07:15 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Jason,
I checked it out and I needed to change two things to have the datastore initialize correctly. I did
not get the can't find property error. But I got the first one you mention and one other (see point
2 below).
1) The first exception you get is related to the bi-directional relation m2mbjoin.parent <-->
Parent.m2mbjoin. You set a manytomany annotation however in the xsd the m2mbjoin.parent element has
maxOccurs not set so it defaults to 1. So therefor currently in the xsd the relation is a
many-to-one instead of a many-to-many, I added maxOccurs="unbounded" and then the many-to-many
parses correctly.
2) the entity-name of the m2mbjoin type is M2mbjoin. Teneo uses as a default the eclass name and the
eclass name has the first character upper-cased. So I needed to change the name in the targetEntity
attribute below (is the last element in the xsd):
<xsd:element maxOccurs="unbounded" name="m2mbjoin" type="xsd:IDREF" ecore:reference="m2mbjoin"
<xsd:annotation><xsd:appinfo source="teneo.jpa">@ManyToMany(indexed=false,
targetEntity="M2mbjoin")
With these changes the database is created.
gr. Martin
jason henriksen wrote:
> Hi Martin,
> Jason Henriksen
> <xsd:schema
> All but one of the associations in this document are ILOG compatible. To
> Note:
> o2o => One to One
> o2m => One to Many
> m2o => Many to One
> m2m => Many to Many
> b => Bi-Directional
> join => join table
> read it
> o2osparent
> o2oschild
> o2osjoin
> o2oschildInvis
> o2oschildEmbed
> o2obparent
> o2obchild
> o2objoin
> embedded into)
> Helper)
> o2mschild
> o2msjoin
> o2mschildInvis
> o2mschildEmbed
> Helper)
> o2mbchild
> o2mbjoin
> Helper)
> m2osparent
> m2osjoin
> not longer asingle item)
> m2mbjoin
> here -->
> parameters={
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <!-- My primary key matches the parent's primary key. I don't have an
> attribute for my parent, but with this object the parent could be found -->
> work without an exception is a big trick -->
> and use that as its primary key. Otherwise -->
> erros.
> <xsd:sequence>
> @Id
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <!-- This child can find its parent. The parent holds the foreign key
> column -->
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> column -->
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> belong to -->
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <!-- In the Invisible case we want to have no mention of the parent at
> all. The only way is to ignore the parent mapping and let Teneo add it
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <!-- Again, this object has no awareness of the parent. This could be
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> the anyURI examples -->
> <xsd:sequence>
> indexed=false)
> </xsd:sequence>
> </xsd:complexType>
> in the order that they are defined.
> <xsd:annotation>
> @Table(name=PARENT)
> </xsd:appinfo>
> </xsd:annotation>
> <xsd:sequence>
> <xsd:annotation>
> @Id
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> interested in -->
> type="o2osparent">
> I can use @PrimaryKeyJoinColumn because the key of the child is the join
> I care about -->
> type="o2oschild">
> type="o2osjoin" minOccurs="0">
> control child column name; -->
> type="o2obparent">
> type="o2obchild">
> controlled by the 'parent' attribute of the CHILD object) -->
> type="o2objoin">
> type="o2mschild">
> type="o2msjoin">
> control child column name -->
> type="o2mbchild">
> type="o2mbjoin">
> type="m2osparent">
> type="m2osjoin">
> due to lack of support for IDREF types -->
> type="xsd:IDREF" ecore:reference="m2mbjoin" ecore:opposite="parent">
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Two problems @GenericGenerate strategy="foreign" and @ManyToMany [message #617768 is a reply to message #118628] |
Hi Jason,
2 below).
parses correctly.
gr. Martin
> Hi Martin,
> Jason Henriksen
> <xsd:schema
> Note:
> o2o => One to One
> o2m => One to Many
> m2o => Many to One
> m2m => Many to Many
> b => Bi-Directional
> join => join table
> read it
> o2osparent
> o2oschild
> o2osjoin
> o2oschildInvis
> o2oschildEmbed
> o2obparent
> o2obchild
> o2objoin
> embedded into)
> Helper)
> o2mschild
> o2msjoin
> o2mschildInvis
> o2mschildEmbed
> Helper)
> o2mbchild
> o2mbjoin
> Helper)
> m2osparent
> m2osjoin
> m2mbjoin
> here -->
> parameters={
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> erros.
> <xsd:sequence>
> @Id
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> column -->
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> column -->
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> belong to -->
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> indexed=false)
> </xsd:sequence>
> </xsd:complexType>
> <xsd:annotation>
> @Table(name=PARENT)
> </xsd:appinfo>
> </xsd:annotation>
> <xsd:sequence>
> <xsd:annotation>
> @Id
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> <xsd:annotation>
> </xsd:appinfo>
> </xsd:annotation>
> </xsd:element>
> interested in -->
> type="o2osparent">
> I care about -->
> type="o2oschild">
> type="o2obparent">
> type="o2obchild">
> type="o2objoin">
> type="o2mschild">
> type="o2msjoin">
> type="o2mbchild">
> type="o2mbjoin">
> type="m2osparent">
> type="m2osjoin">
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
The Netherlands
Current Time: Fri Apr 26 19:41:52 GMT 2024
Powered by FUDForum. Page generated in 0.04085 seconds
