Home » Language IDEs » C / C++ IDE (CDT) » CDT 2.0.1 is now available
Re: CDT 2.0.1 is now available [message #119273 is a reply to message #119124] |
Fri, 03 September 2004 05:22   |
Originally posted by: e.egberts.tantec.de
Hello Sean,
> If Eclipse/CDT is crashing as frequently as you say,
no, it is not crashing, it hangs, gets stuck, hooks (I'm not native
english speaker). For example, when typing in text (I'm fast ;o) the
text doesn't appear for a moment and then I can see it coming (typing a
little faster than me ;o). Similar the scrolling - taking the scrollbar
by mouse and moving the text up and down it stops for a moment and then
goes on. This is different to CDT 2.0.0.
> Why not start with a clean Eclipse 3.0 install, install CDT 2.0.1 from
> the update site, and try again.
I ordered a faster PC (not only for Eclipse ;o) and will try to use
features, when working on it. But in the moment CDT 2.0.0 is good
enough, I learned how to use it and there are several things I like.
Ed
Re: CDT 2.0.1 is now available [message #119492 is a reply to message #119445] |
Sat, 04 September 2004 18:57   |
Originally posted by: ddaoust.ca.ibm.com
In general, a comment that translates to "it is broken" (without any detail)
is ignored by anybody that could help you.
If you were to provide the steps that you did, followed by what actually
happens, and then tell us what is different from what you expect, you are
likely to get help.
For example,
I installed eclipse-SDK-3.0-win32.zip into c:\eclipse which was a new
empty directory
I then started eclipse, selected a new workspace.
From the help menu, I select SoftwareUpdates->Find and Install
Select Search for new features to install
Add a new remote site http://update.eclipse.org/tools/cdt/releases/new
(I called it CDT)
I expanded this new site and selected CDT 2.0.1
Then I selected the Eclipse C/C++ Development Tools
After accepting all the legal mumbo jumbo, Everything installed
I did this before sending the initial posting about 2.0.1 and I did it again
before responding to this post.
There is a funny artical written on how to get help in an open source
environment "How to ask questions the smart way" by Eric Raymond. (This
is mentioned in the FAQ). The people who work on the CDT are not as
behaviorially challanged as the examples in the article (my opinion -- it is
likely that I am biased), but there is a lot of good advice that applies
anyway.
- Dave
"Dejan Lekic" <dejan@nu6.org> wrote in message
news:chcrg3$q3a$1@eclipse.org...
> I still don't have it in Eclipse updates... :(
> Kind regards
> Dejan
> Dejan Lekic
> developer, sysadmin and DBA
> http://dejan.lekic.orgN
Re: CDT 2.0.1 is now available [message #119601 is a reply to message #119588] |
Mon, 06 September 2004 10:13   |
But there is a CDT 2.0.1 update site. (it was in my original post, it is on
the download page, ....)
I was saying that I have no idea why YOU have a problem doing this. It
works for me. If you want anybody to help, YOU need to explain what you
did, and what didn't work.
If you don't have a problem, I don't understand why you sent the original
post. Did you want someone to do something? If so, who? and what?
- Dave
news:chho9h$8i6$1@eclipse.org...
> David, i didn't quite understand why you are telling ME this? I didn't say
I
> had any particular problem. Simply, I said there there is no new 2.0.1 in
> Eclipse/CDT automatic updates...
> Kind regards
> Dejan
> Dejan Lekic
Re: CDT 2.0.1 is now available [message #119928 is a reply to message #119787] |
Tue, 07 September 2004 14:37   |
Sean Evoy wrote:
> So Daniel,
> Your work-around of creating a new workspace does not solve the problem?
> Just out of curiosity, what was the last version of the CDT you were
> using (i.e. was it a 1.2 -> 2.0.1 upgrade, or a 2.0 -> to 2.0.1
> upgrade). As well, what version of Eclipse are you running with?
> Finally, do you have a .log file in your .metadata directory? If so, it
> should have a stack trace which may help pin-point the problem.
The last Version of CDT I was using was: 2.0
At the time of my last post I used Eclipse 3.0 and now I'm using
Version: 3.1.0
Build id: 200409011200
I'm using jre 1.4.2.
Since Installing 3.1.0 the problem occurs not so often but is not gone
completely
I did a search with google and it seems that something is causing
javaw.exe to shut down.
I found this explanation for a (maybe??) similar error with another
eclipse plugin:
> When opening a pre-existing html page, clicking on the visual designer tab causes Eclipse to hang indefinitely, then crash on forced exit with an javaw.exe error (exit code: 1073807364). I'm running Eclipse 3.0, workbench version 3.7.2.00 Build id: 200407091200-3.8-Beta2. Please advise
> There is a known bug with 3.8 Beta 2 in the visual design where a certain set of HTML will cause the designer to go into an infinite loop
I do not know if this has something to do with my problem, because I'm
rather new to programming and specially with java!!
There is no log-file in my .metadata directory
Thanks for your help,
Daniel
Re: CDT 2.0.1 is now available [message #121027 is a reply to message #120895] |
Tue, 14 September 2004 23:04  |
Sure, just be clear in the defect that its not easily reproducible.
JC
"Daniel Jeller" <djeller@chello.at> wrote in message
news:ci4qcc$8iv$1@eclipse.org...
> > johnc wrote:
> >> If you can raise a defect w/a code example or project that causes the
> >> problem, I'll take a look at it this week.
> Sorry, it seems, I'm not able to get this error reproducable.
> should i raise a bug anyways??
> Daniel
Current Time: Mon Oct 20 07:53:34 EDT 2025
Powered by FUDForum. Page generated in 0.09508 seconds
