Issue regarding report engine [message #118505] |
Fri, 27 January 2006 05:37  |
hi all,
Iam using report engine for generating the reports. I placed birt in
Jboss4.0.3 server .../default/deploy folder with birt as folder name. When
the jboss startsup at the end of starting i getting the exceptions like:
18:22:23,395 ERROR [URLDeploymentScanner] Incomplete Deployment listing:
--- Packages waiting for a deployer ---
org.jboss.deployment.DeploymentInfo@11c3fe95 {
url=file:/home/corona/corona/main/coronadeployment/preconfig ured/linux/all/corona/cms/server/default/deploy/birt/plugins /org.eclipse.birt.report.data.oda.xml/
deployer: null
status: null
state: INIT_WAITING_DEPLOYER
watch:
file:/home/corona/corona/main/coronadeployment/preconfigured /linux/all/corona/cms/server/default/deploy/birt/plugins/org .eclipse.birt.report.data.oda.xml/
altDD: null
lastDeployed: 1138193543279
lastModified: 1138184732000
mbeans:
--- Incompletely deployed packages ---
url=file:{JBOSS_HOME}/server/default/deploy/birt/plugins/org .eclipse.birt.report.data.oda.xml/
deployer: null
status: null
watch:
file:{JBOSS_HOME}/server/default/deploy/birt/plugins/org.ecl ipse.birt.report.data.oda.xml/
altDD: null
mbeans:
18:22:23,547 INFO [Http11Protocol] Starting Coyote HTTP/1.1 on
http-0.0.0.0-8080
18:22:23,826 INFO [ChannelSocket] JK: ajp13 listening on /0.0.0.0:8009
18:22:23,841 INFO [JkMain] Jk running ID=0 time=0/79 config=null
18:22:23,860 INFO [Http11Protocol] Starting Coyote HTTP/1.1 on
http-0.0.0.0-8443
18:22:23,884 INFO [Server] JBoss (MX MicroKernel) [4.0.3SP1 (build:
CVSTag=JBoss_4_0_3_SP1 date=200601251449)] Started in 1m:42s:320ms
Please help me hoe to avoid these messages
Thanks in advance,
Bhaskar.
Re: Issue regarding report engine [message #119238 is a reply to message #118505] |
Fri, 27 January 2006 17:04  |
Bhaskar
Did you name the folder
birt or birt.war ?
Jason Weathersby
BIRT PMC
"bhaskar" <penbachi@rediffmail.com> wrote in message
news:2c42a0a3a6b3b5cc04f5b827587d8773$1@www.eclipse.org...
> hi all,
> deployer: null
> status: null
> watch:
> altDD: null
> mbeans:
> deployer: null
> status: null
> watch:
> altDD: null
> mbeans:
> http-0.0.0.0-8080
> http-0.0.0.0-8443
> Thanks in advance,
> Bhaskar.
FUDForum. Page generated in 1.04900 seconds
