Changing the Activity name through a listener [message #10798] |
Wed, 15 April 2009 17:53  |
Originally posted by: klia0001.um.edu.mt
I am using the plugin as part of my thesis, and so far it has been very
useful. I have created a custom annotation for the activities that
associates the Task to a WSDL Operation. This is done populating a
combobox.
I would like it so that when the user changes the selection in the
combobox, the actual name of the activity also changes from the default
"Task" to the name of the Operation. Is there a listener that I can use to
achieve this functionality?
I also want to programmatically retrieve the generated XML file so that I
can parse it while the program is running. Is there an easy way to do this?
Lia.
Re: Changing the Activity name through a listener [message #11592 is a reply to message #11335] |
Fri, 24 April 2009 08:12   |
Hi Antoine,
Thanks for all your help, it was really useful.
I have one problem hovewer. I have put two Tasks in the diagram pool (Task
1 and Task 2). When I change the annotation of Task 1 it's ok.
When I change the annotation of Task 1 and then click on Task 2
immediately, the annotation of Task 1 changes to that of Task 2.
If however, I change the annotation on Task 1, then click on the pool, and
THEN click on Task 2, this does not happen.
I don't know whether I explained myself in a clear manner, but would
appreciate if you can point me in the right direction.
Lia
Re: Changing the Activity name through a listener [message #11628 is a reply to message #11592] |
Fri, 24 April 2009 09:25   |
Originally posted by: atoulme.intalio.com
Not sure what's happening but it sure looks like a bug in your code.
Lia wrote:
> Hi Antoine,
> (Task 1 and Task 2). When I change the annotation of Task 1 it's ok.
> and THEN click on Task 2, this does not happen.
> Lia
FUDForum. Page generated in 0.03662 seconds
