Home » Eclipse Projects » Remote Application Platform (RAP) » Using umages in branding html
Using umages in branding html [message #118186] |
Sun, 11 January 2009 00:52  |
Hi all!
I registered my html file in branding extension point, I tried to use
image in html, image locates near html file, but it works only in debug
mode, built application doesn't show me image.
I think that image should be registered, can I do it by plugin.xml?
Re: Using umages in branding html [message #118481 is a reply to message #118201] |
Thu, 15 January 2009 06:04   |
Boris,
in order to get help, please provide detailed information on what
you did exactly.
Rüdiger
Boris Stepanov wrote:
> I found theme "Branding and images" and tried to implement described
> advices, but there aren't solution which works.
>> Hi all!
>> debug mode, built application doesn't show me image.
Re: Using umages in branding html [message #118506 is a reply to message #118481] |
Thu, 15 January 2009 09:40   |
Originally posted by: benjamin.wolff.web.de
Hi Boris,
exactly this guide worked for me: http://wiki.eclipse.org/RAP/FAQ#How_can_I_use_an_image_in_th e_branding_body.3F
but it is important that you use "loading.gif" instead of "/loading.gif" in the html page. the variant with the slash didn't work for me when
the application is deployed.
greetings,
ben
Rüdiger Herrmann schrieb:
> Boris,
> in order to get help, please provide detailed information on what you
> did exactly.
> Cheers,
> Rüdiger
>>> Hi all!
Re: Using umages in branding html [message #118833 is a reply to message #118506] |
Mon, 19 January 2009 23:47  |
Hi Ben,
Thanks for advice. Now it works, but alias have to start with "/" (You
will see error in console otherwise), so I've changed it to "/loading.gif".
> Hi Boris,
> greetings,
> ben
>> Boris,
>> did exactly.
>> Cheers,
>> Rüdiger
>>>> Hi all!
>>>> use image in html, image locates near html file, but it works only
>>>> in debug mode, built application doesn't show me image.
Current Time: Fri Jul 18 02:01:21 EDT 2025
Powered by FUDForum. Page generated in 0.04710 seconds
