Re: HowTo handle "org.eclipse.swt.internal.win32.LOGFONT lf = fda.data;" on Linux? [message #10799 is a reply to message #10768] |
Thu, 24 February 2005 18:35  |
Hi Andreas,
We've used some static OS specific code to support rendering of underline
and strikethrough text support for the Win32 OS. This needs to be called
dynamically using reflection instead. Thank you for pointing it out.
You could safely comment out this block of code for now:
lf.lfQuality = 4; // ANTIALIASED_QUALITY
if (fd.isStrikethrough())
lf.lfStrikeOut = 1;
if (fd.isUnderline())
lf.lfUnderline = 1;
We will update the source for this shortly.
Rohit Colaco
ECE Project Lead
FreeGroup wrote:
> Hi
> I have a combilation problem in Linux.
> How should I handle the compilation problem
> with:
> greetings
> Andreas
FUDForum. Page generated in 0.05696 seconds
