Home » Archived » BIRT » HowTo handle "org.eclipse.swt.internal.win32.LOGFONT lf = fda.data;" on Linux?
HowTo handle "org.eclipse.swt.internal.win32.LOGFONT lf = fda.data;" on Linux? [message #10768] Thu, 24 February 2005 17:38 Go to next message
I have a combilation problem in Linux.
How should I handle the compilation problem
with:
greetings
Andreas
Re: HowTo handle "org.eclipse.swt.internal.win32.LOGFONT lf = fda.data;" on Linux? [message #10799 is a reply to message #10768] Thu, 24 February 2005 18:35 Go to previous message
Hi Andreas,
We've used some static OS specific code to support rendering of underline
and strikethrough text support for the Win32 OS. This needs to be called
dynamically using reflection instead. Thank you for pointing it out.
You could safely comment out this block of code for now:
lf.lfQuality = 4; // ANTIALIASED_QUALITY
if (fd.isStrikethrough())
lf.lfStrikeOut = 1;
if (fd.isUnderline())
lf.lfUnderline = 1;
We will update the source for this shortly.
Rohit Colaco
ECE Project Lead
FreeGroup wrote:
> Hi
> with:
> greetings
> Andreas
Previous Topic:where can i download the BIRT DEMO?
Next Topic:birt build converter project problem can't find class ExtendedDataSetHandle
Current Time: Sat Jul 12 08:40:13 EDT 2025
Powered by FUDForum. Page generated in 0.24297 seconds
