Home » Modeling » BPEL Designer » Usind Designer with Ganymede
Usind Designer with Ganymede [message #10733] Mon, 07 July 2008 14:43 Go to next message
Originally posted by: ganix.gmx.net
After testing the bpel designer plugin with eclipse europa, i now upgraded
to ganymede, and now the installation fails to resolve dependencies.
Is there some newer version of the bpel designer plugin for eclipse 3.4
available?
Thanks very much,
H.
Re: Usind Designer with Ganymede [message #10766 is a reply to message #10733] Fri, 11 July 2008 02:54 Go to previous messageGo to next message
Originally posted by: hariharasudan.equadriga.com
I'm also facing the same problem.
Please let us know the plan of BPEL designer with Ganymede!!
Thanks and Regards,
Hari
Re: Usind Designer with Ganymede [message #11095 is a reply to message #10766] Tue, 12 August 2008 16:53 Go to previous messageGo to next message
We are currently working on a Ganymede port. Expect to see something in
the next few weeks.
Re: Usind Designer with Ganymede [message #11125 is a reply to message #11095] Wed, 03 September 2008 07:52 Go to previous message
Originally posted by: michael.gebhart.googlemail.com
Hello Simon,
I'm just facing the same problem. Anything new about the e3.4 support? I
am a bit curious about it :)
Greetings
Michael
Previous Topic:Can't use BPEL designer after Install
Next Topic:The BPLE cannot be published to the AvtiveBPEL 3.0 using AER Plugin
Current Time: Fri Jul 18 00:34:08 EDT 2025
Powered by FUDForum. Page generated in 0.04409 seconds
