Home » Modeling » GMF (Graphical Modeling Framework) » Europa 3.3M6, GMF 2.0M6: ZipException
Europa 3.3M6, GMF 2.0M6: ZipException [message #117715] Sat, 07 April 2007 15:55 Go to next message
Originally posted by: gerd.castan.z.zgs.de
I'm trying to update to GMF 2.0M6 via update manager.. and I get an
exgeption
!ENTRY org.eclipse.update.core 4 0 2007-04-07 21:39:29.882
!MESSAGE Error retrieving
"plugins/org.eclipse.gmf.sdk_1.0.0.v20070403-1500.jar". [error in
opening zip file]
!STACK 0
java.util.zip.ZipException: error in opening zip file
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:203)
at java.util.jar.JarFile.<init>(JarFile.java:132)
at java.util.jar.JarFile.<init>(JarFile.java:112)
org.eclipse.update.internal.jarprocessor.JarProcessor.proces sJar(JarProcessor.java:303)
org.eclipse.update.internal.core.FeaturePackagedContentProvi der.retrieveLocalJar(FeaturePackagedContentProvider.java:256 )
org.eclipse.update.internal.core.FeaturePackagedContentProvi der.getPluginEntryArchiveReferences(FeaturePackagedContentPr ovider.java:179)
org.eclipse.update.internal.operations.UpdateUtils.downloadF eatureContent(UpdateUtils.java:628)
org.eclipse.update.internal.ui.wizards.InstallWizard2.downlo ad(InstallWizard2.java:426)
org.eclipse.update.internal.ui.wizards.InstallWizard2.access $3(InstallWizard2.java:397)
org.eclipse.update.internal.ui.wizards.InstallWizard2$3.run( InstallWizard2.java:350)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
!ENTRY org.eclipse.core.runtime 8 1 2007-04-07 21:39:31.820
!MESSAGE
This is on Mac OS X 10.4.9
Has anybody seen this, too?
Gerd
Re: Europa 3.3M6, GMF 2.0M6: ZipException [message #117729 is a reply to message #117715] Sat, 07 April 2007 16:07 Go to previous messageGo to next message
This also happens if I download directly from the eclipse foundation.
Gerd
Re: Europa 3.3M6, GMF 2.0M6: ZipException [message #119245 is a reply to message #117715] Fri, 13 April 2007 11:29 Go to previous message
It seems we have a corrupt pack200 archive, which Bjorn has removed from
Europa. It should work now, but we're still working on fixing it on our own
update site, and later will update Europa with the packed jars.
Rich
On 4/7/07 3:55 PM, in article ev8sr8$mei$1@build.eclipse.org, "Gerd Castan"
<gerd.castan@z.zgs.de> wrote:
> exgeption
> opening zip file]
> !STACK 0
> at
> java:303)
> at
> ar(FeaturePackagedContentProvider.java:256)
> at
> ArchiveReferences(FeaturePackagedContentProvider.java:179)
> at
> teUtils.java:628)
> at
> java:426)
> at
> java:397)
> at
> a:350)
> !MESSAGE
> Cheers,
> Gerd
Previous Topic:Save Exception
Next Topic:Adding Annotation Details
Current Time: Sat Jul 12 17:08:53 EDT 2025
Powered by FUDForum. Page generated in 0.03214 seconds
