| Getting started with Generate Javadoc [message #117642] |
Mon, 14 November 2005 12:38 |
I am trying the Project > Generate Javadoc facility for the first time and
I can't get off the ground.
I picked a project that doesn't refer to any other projects, although it
does use Eclipse plug-ins such as ui and swt and some external jars and
tried to run it on this with default options. I didn't tick any
referenced archives or projects.
The javadoc is from Sun J2SE1.5.0_04.
It gives the following exception:
Constructing Javadoc information...
Standard Doclet version 1.5.0_04
Building tree for all the packages and classes...
Generating C:\Distribution Modeller
Workspace\ch.actuary.dmodeller\doc\ch/actuary/maths/\FastMat hs.html...
java.lang.IllegalArgumentException
at sun.net.www.ParseUtil.decode(ParseUtil.java:183)
at sun.misc.URLClassPath$FileLoader.<init>(URLClassPath.java:863)
This exception appears to refer to number format errors.
The preferences are set to process Javadoc comments and there are no
errors or warnings in this project.
Is there a way of finding out the precise command that Eclipse has issued
to Javadoc programme or running the generate command in debug mode to
investigate further?
Many thanks
Roger
FUDForum. Page generated in 0.07822 seconds
