Home » Modeling » EMF » [NET4J] SSL acceptor support
[NET4J] SSL acceptor support [message #885950] Wed, 13 June 2012 19:09 Go to next message
Hi, looking at the CDO 4.1 code base there seems to be quite a bit of code to support an SSP acceptor based on the TCP acceptor. Can anyone comment on how whether they've used the SSP acceptor before and how it should be configured?
Warwick
Re: [NET4J] SSL acceptor support [message #886017 is a reply to message #885950] Wed, 13 June 2012 23:53 Go to previous message
Am 14.06.2012 01:09, schrieb Warwick Burrows:
Our committers from NoMagic have developed this transport in the scope of this bugzilla:
340108: Provide an SSL transport implementation for Net4J
https://bugs.eclipse.org/bugs/show_bug.cgi?id=340108
There are a couple of examples and tests available:
/org.eclipse.emf.cdo.examples/src/org/eclipse/emf/cdo/examples/StandaloneContainerExampleSSL.java
/org.eclipse.net4j.examples/src/org/eclipse/net4j/examples/echo/client/EchoSSLClient.java
/org.eclipse.net4j.examples/src/org/eclipse/net4j/examples/echo/server/EchoSSLServer.java
/org.eclipse.net4j.examples/src/org/eclipse/net4j/examples/transfer/UploadSSLClientAction.java
/org.eclipse.net4j.examples/src/org/eclipse/net4j/examples/transfer/UploadSSLServer.java
/org.eclipse.net4j.examples/sslKey
/org.eclipse.emf.cdo.server/CDOServer_SSL.launch
/org.eclipse.emf.cdo.server.product/config-ssl/cdo-server.xml
org.eclipse.emf.cdo.tests.config.impl.SessionConfig.Net4j.SSL
/org.eclipse.emf.cdo.tests/src/org/eclipse/emf/cdo/tests/AllTestsMEMBranchesSSL.java
/org.eclipse.emf.cdo.tests/launches/CDO AllTests (MEM branching SSL).launch
/org.eclipse.emf.cdo.tests/sslKey
I hope that gives you some pointers.
Cheers
/Eike
http://www.esc-net.de
Previous Topic:XMI:ID attributed to several objects ?
Next Topic:Reading XMI error?
Current Time: Sun Jul 13 04:39:23 EDT 2025
Powered by FUDForum. Page generated in 0.04257 seconds
