Error on opening Visual Editor [message #117436] |
Mon, 13 February 2006 08:27  |
Originally posted by: dxrysom.epis.gr
I can not use the Visual Editor. I have eclipse 3.1.0. I only downloaded
the required packages:
EMF 2.1.0, GEF 3.1.1, Java EMF Model 1.1.0 and Visual Editor 1.1.0.
Through the wizard i create a new project:
File -> new -> project -> Java project
(Should there be an option for a visual project or something???)
Then, I create a new visual class:
File -> new -> other.. -> visual class Or File -> new -> other.. -> Java
-> Swing -> JFrame visual class
The class is created. But when I try to open the visual editor page I
get the ERROR MESSAGE: An error has occured. See error log for more details.
the error log contains the following:
!SESSION 2006-02-13 14:37:38.687
eclipse.buildId=I20050401-1645
java.version=1.5.0_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=el_GR
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2006-02-13 14:37:38.718
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-02-13 14:37:38.859
!MESSAGE Failed to execute runnable (java.lang.NoSuchMethodError:
org.eclipse.swt.graphics.GC.getAdvanced()Z)
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.NoSuchMethodError: org.eclipse.swt.graphics.GC.getAdvanced()Z)
at org.eclipse.swt.SWT.error(SWT.java:2860)
at org.eclipse.swt.SWT.error(SWT.java:2783)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:121)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2871)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2530)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
Caused by: java.lang.NoSuchMethodError:
at org.eclipse.draw2d.SWTGraphics.init(SWTGraphics.java:707)
at org.eclipse.draw2d.SWTGraphics.<init>(SWTGraphics.java:258)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$RotatedTit leLabel.updateImage(FlyoutPaletteComposite.java:1063)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$RotatedTit leLabel.setFont(FlyoutPaletteComposite.java:1045)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$TitleCanva s.setFont(FlyoutPaletteComposite.java:1333)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$FontManage r.register(FlyoutPaletteComposite.java:1434)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$TitleCanva s.init(FlyoutPaletteComposite.java:1289)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$TitleCanva s. <init>(FlyoutPaletteComposite.java:1256)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.createTitl e(FlyoutPaletteComposite.java:269)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.access$5(F lyoutPaletteComposite.java:268)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$Sash.<init >(FlyoutPaletteComposite.java:685)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.createSash (FlyoutPaletteComposite.java:265)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.<init>(FlyoutPaletteComposite.java:190)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createSplitpaneEditor(JavaVisualEditorPart.java:636 )
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createPartControl(JavaVisualEditorPart.java:574)
org.eclipse.ui.internal.EditorManager.busyRestoreEditorHelpe r(EditorManager.java:1237)
org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:1102)
at org.eclipse.ui.internal.EditorManager$7.run(EditorManager.ja va:1064)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:1062)
org.eclipse.ui.internal.EditorManager$Editor.getEditor(Edito rManager.java:1648)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2238)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2165)
at org.eclipse.ui.internal.WorkbenchPage.access$7(WorkbenchPage .java:2157)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2143)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2138)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2123)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard$1.run(NewVisualClassCreationWizard.java:422)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:118)
.... 18 more
!ENTRY org.eclipse.jface 4 2 2006-02-13 14:37:48.140
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:231)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:129)
org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(Open ActionUtil.java:49)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:16 4)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:15 0)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:212)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:188)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:304)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:805)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:658)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1021)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:40)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:656)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:875)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:974)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:243)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:238)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:277)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
Re: Error on opening Visual Editor [message #612090 is a reply to message #117462] |
Mon, 13 February 2006 09:58  |
Jeff Myers wrote:
> Err, wait, you're getting a no such method exception? Are you sure
> you're running Eclipse 3.1 final, and not some early milestone?
> - Jeff
it's
Version: 3.1.0
Build id: I20050401-1645
the installation zip is:
eclipse-SDK-3.1M6-win32.zip
I think it's Milestone 6
FUDForum. Page generated in 0.05379 seconds
