Home » Archived » BIRT » birt build converter project problem can't find class ExtendedDataSetHandle
birt build converter project problem can't find class ExtendedDataSetHandle [message #10703] Thu, 24 February 2005 13:11 Go to next message
I'm following the birt build notes
(http://www.eclipse.org/birt/attachments/birtbuild.html)
and I have everything building except the converters
(com.eclipse.birt.converters.jasper) project.
The problem I'm seeing is that the build can't find the following class
import org.eclipse.birt.report.model.api.ExtendedDataSetHandle;
When I do a file grep, I see javadoc notes in other places but
this class simply doesn't exist.
any ideas where to get it?
Re: birt build converter project problem can't find class ExtendedDataSetHandle [message #10821 is a reply to message #10703] Fri, 25 February 2005 02:09 Go to previous message
Mike,
Problem has been fixed if you just refresh from cvs. A changed was made in
the model by a developer that did not have access to the converter
repository. ExtendedDataSet changed to OdaDataSet.
Scott Rosenbaum
"Mike Boyersmith" <mjboyers@us.ibm.com> wrote in message
news:cvl5cg$jsq$1@www.eclipse.org...
Previous Topic:HowTo handle "org.eclipse.swt.internal.win32.LOGFONT lf = fda.data;" on Linux?
Next Topic:BIRT Source Reorganization
Current Time: Wed Jul 16 02:58:42 EDT 2025
Powered by FUDForum. Page generated in 0.28583 seconds
