Home » Archived » Visual Editor (VE) » Error configuring nature
Error configuring nature [message #117398] |
Sat, 11 February 2006 20:01  |
Originally posted by: jenya_m2001.mail.ru
When I tried to create a Visual class I got this message.
Problems encountered while setting project description.
Error configuring nature: org.eclipse.jem.beaninfo.BeanInfoNature.
I installed Eclipse 3.2M4, EMF build 2.2.0M4, GEF Build 3.2M4,
java 5.0 SDK. Why VE doesn't work?
What's wrong with it?
Re: Error configuring nature [message #117620 is a reply to message #117602] |
Mon, 13 February 2006 20:20   |
More logs
*** Date: Tue Feb 14 03:13:59 EET 2006
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20060118-1600
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
F:\Eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
4ec_7c
vmargs
Xmx256M
-vm
C:\WINNT\system32\javaw.exe
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1139879431745
eclipse.vm=C:\WINNT\system32\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
F:\Eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=F:\Eclipse\startup.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Java\jre1.5.0_06\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre1.5.0_06\lib\ext
java.home=C:\Program Files\Java\jre1.5.0_06
java.io.tmpdir=C:\DOCUME~1\YEVHEN~1\LOCALS~1\Temp\
java.library.path=C:\WINNT\system32;.;C:\WINNT\system32;C:\W INNT;C:\WINNT\sy
stem32;C:\WINNT;C:\WINNT\System32\Wbem;F:\jdk1.5.0_06\bin;F: \SWT\swt.jar
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_06-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_06
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_06-b05
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows2000
org.osgi.framework.os.version=5.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.
crypto,javax.crypto.interfaces,javax.crypto.spec,javax.image io,javax.imageio
..event,javax.imageio.metadata,javax.imageio.plugins.bmp,jav ax.imageio.plugin
s.jpeg,javax.imageio.spi,javax.imageio.stream,javax.manageme nt,javax.managem
ent.loading,javax.management.modelmbean,javax.management.mon itor,javax.manag
ement.openmbean,javax.management.relation,javax.management.r emote,javax.mana
gement.remote.rmi,javax.management.timer,javax.naming,javax. naming.directory
,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax .net,javax.net.s
sl,javax.print,javax.print.attribute,javax.print.attribute.s tandard,javax.pr
int.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.secu rity.auth,javax.
security.auth.callback,javax.security.auth.kerberos,javax.se curity.auth.logi
n,javax.security.auth.spi,javax.security.auth.x500,javax.sec urity.cert,javax
..security.sasl,javax.sound.midi,javax.sound.midi.spi,javax. sound.sampled,jav
ax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.ro wset.serial,java
x.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing. colorchooser,jav
ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.bas
ic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing .plaf.synth,java
x.swing.table,javax.swing.text,javax.swing.text.html,javax.s wing.text.html.p
arser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo ,javax.transacti
on,javax.transaction.xa,javax.xml,javax.xml.datatype,javax.x ml.namespace,jav
ax.xml.parsers,javax.xml.transform,javax.xml.transform.dom,j avax.xml.transfo
rm.sax,javax.xml.transform.stream,javax.xml.validation,javax .xml.xpath,org.i
etf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.p ortable,org.omg.
CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.p ortable,org.omg.
CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.Na mingContextExtPa
ckage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic ,org.omg.Dynamic
Any,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicA ny.DynAnyPackage
,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.Cod ecPackage,org.om
g.Messaging,org.omg.PortableInterceptor,org.omg.PortableInte rceptor.ORBInitI
nfoPackage,org.omg.PortableServer,org.omg.PortableServer.Cur rentPackage,org.
omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.o
mg.PortableServer.portable,org.omg.PortableServer.ServantLoc atorPackage,org.
omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c .dom.bootstrap,o
rg.w3c.dom.events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext ,org.xml.sax.hel
pers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows 2000
os.version=5.0
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundlestore=f:\Eclipse\configuration\org.eclipse.osgi\b undles
osgi.configuration.area=file:/f:/Eclipse/configuration/
osgi.framework=file:/f:/Eclipse/plugins/org.eclipse.osgi_3.1 .2.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.1.2
osgi.install.area=file:/f:/Eclipse/
osgi.instance.area=file:/G:/Archive/JavaWorkspace/
osgi.instance.area.default=file:/C:/Documents and Settings/Yevhenii
Miachyn/workspace/
osgi.logfile=G:\Archive\JavaWorkspace\.metadata\.log
osgi.manifest.cache=f:\Eclipse\configuration\org.eclipse.osg i\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=f:\Eclipse\plugins\org.eclipse.platform_ 3.1.2\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=f:\Eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Java\jre1.5.0_06\lib\rt.jar;C:\Program
Files\Java\jre1.5.0_06\lib\i18n.jar;C:\Program
Files\Java\jre1.5.0_06\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.5.0_06\lib\jsse.jar;C:\Program
Files\Java\jre1.5.0_06\lib\jce.jar;C:\Program
Files\Java\jre1.5.0_06\lib\charsets.jar;C:\Program
Files\Java\jre1.5.0_06\classes
sun.boot.library.path=C:\Program Files\Java\jre1.5.0_06\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486 i386
i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1251
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 4
user.country=US
user.dir=F:\Eclipse
user.home=C:\Documents and Settings\Yevhenii Miachyn
user.language=en
user.name=Yevhenii Miachyn
user.timezone=Europe/Athens
user.variant=
*** Features:
org.eclipse.emf (2.2.0) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.2.0) "EMF Service Data Objects (SDO)"
org.eclipse.gef (3.2.0) "Graphical Editing Framework"
org.eclipse.jdt (3.1.2) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.2) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.2.0) "Java EMF Model"
org.eclipse.pde (3.1.2) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.2) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.1.2) "Eclipse Platform"
org.eclipse.platform.source (3.1.2) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.rcp (3.1.2) "Eclipse RCP"
org.eclipse.rcp.source (3.1.2) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.1.2) "Eclipse Project SDK"
org.eclipse.ve (1.2.0) "Visual Editor"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.2) "Event Model" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.1) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.2) "Ant UI" [Resolved]
org.eclipse.compare (3.1.1) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.2) "File Buffers" [Active]
org.eclipse.core.resources (3.1.2) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource Management
Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management Win32
org.eclipse.core.runtime (3.1.2) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in
Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Resolved]
org.eclipse.debug.core (3.1.2) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.2) "Debug UI" [Active]
org.eclipse.draw2d (3.2.0) "Draw2d" [Resolved]
org.eclipse.emf (2.2.0) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.2.0) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.2.0) "EMF Ecore Code Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.2.0) "EMF Common" [Resolved]
org.eclipse.emf.common.ui (2.2.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
org.eclipse.emf.converter (2.2.0) "EMF Model Convert Support" [Resolved]
org.eclipse.emf.ecore (2.2.0) "EMF Ecore" [Resolved]
org.eclipse.emf.ecore.change (2.2.0) "EMF Ecore Change Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support"
[Resolved]
org.eclipse.emf.ecore.edit (2.2.0) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.2.0) "Sample Ecore Editor" [Resolved]
[Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO) Edit
Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.0) "EMF XMI" [Resolved]
org.eclipse.emf.edit (2.2.0) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.2.0) "EMF Edit UI" [Resolved]
org.eclipse.emf.exporter (2.2.0) "EMF Model Export Support" [Resolved]
org.eclipse.emf.importer (2.2.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.2.0) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.2.0) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.2.0) "EMF Rose Importer" [Resolved]
org.eclipse.emf.mapping (2.2.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0) "Ecore to Ecore Mapping"
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0) "Ecore to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0) "Ecore to XML Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.2.0) "EMF Mapping UI" [Resolved]
org.eclipse.gef (3.2.0) "Graphical Editing Framework" [Resolved]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Resolved]
org.eclipse.help.base (3.1.0) "Help System Base" [Resolved]
org.eclipse.help.ui (3.1.1) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.2) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.1) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.1.2) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.1.2) "Eclipse JDT Plug-in Developer Guide"
[Resolved]
org.eclipse.jdt.doc.user (3.1.1) "Eclipse Java Development User Guide"
[Resolved]
org.eclipse.jdt.junit (3.1.1) "Java Development Tools JUnit support"
[Resolved]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit runtime
support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching Support"
[Active]
[Resolved]
org.eclipse.jdt.ui (3.1.2) "Java Development Tools UI" [Active]
org.eclipse.jem (1.2.0) "Java EMF Model" [Resolved]
org.eclipse.jem.beaninfo (1.2.0) "Java EMF Model BeanInfo (Introspection)
Support" [Resolved]
org.eclipse.jem.proxy (1.2.0) "Java EMF Model Proxy Support" [Active]
org.eclipse.jem.ui (1.2.0) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.2.0) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.2.0) "Java EMF Model Workbench Support"
[Resolved]
org.eclipse.jface (3.1.1) "JFace" [Active]
org.eclipse.jface.text (3.1.2) "JFace Text" [Active]
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Active]
org.eclipse.ltk.ui.refactoring (3.1.1) "Refactoring UI" [Active]
org.eclipse.osgi.services (3.1.2) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.1) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment" [Resolved]
org.eclipse.pde.build (3.1.2) "Plug-in Development Environment Build
Support" [Resolved]
org.eclipse.pde.core (3.1.1) "Plug-in Development Core" [Active]
org.eclipse.pde.doc.user (3.1.2) "Eclipse Plug-in Development User Guide"
[Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.1.1) "Plug-in Development Environment Runtime"
[Resolved]
Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.2) "Plug-in Development UI" [Resolved]
org.eclipse.platform (3.1.2) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.2) "Eclipse Platform Plug-in Developer
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.1) "Eclipse Workbench User Guide"
[Resolved]
org.eclipse.platform.source.win32.win32.x86 (3.1.2) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
[Resolved]
org.eclipse.rcp.source.win32.win32.x86 (3.1.2) "Eclipse RCP Plug-in
org.eclipse.sdk (3.1.2) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.1.2) "Search Support" [Resolved]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.1.2) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.1.1) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.1) "CVS Team Provider Core" [Resolved]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.1.1) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.1.1) "Team Support UI" [Resolved]
org.eclipse.text (3.1.1) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.1.2) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.1) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.1.1) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.2) "Console" [Active]
org.eclipse.ui.editors (3.1.1) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.1) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.1.1) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.1) "Welcome Framework" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in"
[Resolved]
org.eclipse.ui.views (3.1.1) "Views" [Active]
org.eclipse.ui.win32 (3.1.0) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.1.2) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility"
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.2) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator"
[Active]
org.eclipse.update.core (3.1.2) "Install/Update Core" [Resolved]
org.eclipse.update.core.win32 (3.1.0) "Install/Update Core for Windows"
[Resolved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.1.1) "Install/Update UI" [Resolved]
org.eclipse.ve (1.2.0) "Visual Editor" [Resolved]
org.eclipse.ve.cde (1.2.0) "Visual Editor Common Data Editor" [Resolved]
org.eclipse.ve.doc (1.2.0) "Visual Editor for Java User Guide" [Resolved]
org.eclipse.ve.java.core (1.2.0) "Visual Editor Java Core" [Active]
org.eclipse.ve.jfc (1.2.0) "Visual Editor for Java Foundation Classes"
[Resolved]
org.eclipse.ve.propertysheet (1.2.0) "Visual Editor PropertySheet"
[Resolved]
org.eclipse.ve.swt (1.2.0) "Visual Editor for Standard Widget Toolkit"
[Active]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
system.bundle (3.1.2) "OSGi System Bundle" [Active]
*** User Preferences:
#Tue Feb 14 03:13:59 EET 2006
@org.eclipse.debug.ui=3.1.2
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?><templates/>
@org.eclipse.ui.ide=3.1.1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.packages.lin ktoeditor=true
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?
xml version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 1,0 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="0" javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"
name\="jre1.5.0_06" path\="C\:\\Program
Files\\Java\\jre1.5.0_06"/>\r\n</vmType>\r\n</vmSettings >\r\n
@org.eclipse.pde.core=3.1.1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.ondemandthre shold=99
/instance/org.eclipse.ve.java.core/VISUAL_CLASS_WIZARD_SELEC TED_ELEMENT_KEY=
org.eclipse.ve.swt.cat-Shell-java.lang.Object
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_te mplates_migrated
=true
/instance/org.eclipse.debug.ui/Console.highWaterMark=88000
/instance/org.eclipse.ui.workbench/perspectives=org.eclipse. jdt.ui.JavaPersp
ective
@org.eclipse.ui.browser=3.1.1
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
@org.eclipse.jdt.ui=3.1.2
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.ignorelowerc asenames=true
/instance/org.eclipse.core.resources/version=1
@org.eclipse.core.resources=3.1.2
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.help.ui/browser.y=0
/instance/org.eclipse.help.ui/browser.x=0
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.help.ui/browser.w=1024
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.USE_STEP _FILTERS=true
/instance/org.eclipse.pde.core/platform_path=f\:\\Eclipse
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.ui.workbench=3.1.2
@org.eclipse.ve.java.core=1.2.0
file_export_version=3.0
@org.eclipse.jdt.launching=3.1.0
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.jdt.ui/formatter_settings_version=8
/instance/org.eclipse.help.ui/browser.h=740
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.exception.na me=e
/instance/org.eclipse.ve.java.core/PALETTE_WIDTH=125
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.enumIde
ntifier=error
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.importorder= java;javax;org;c
om;
/instance/org.eclipse.ui.ide/platformState=141
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .compliance=1.5
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityC
heck=enabled
@org.eclipse.ui.editors=3.1.1
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=G\:\\Arc hive\\JavaWorksp
ace,f\:\\Eclipse\\workspace
/instance/org.eclipse.ui.ide/quickStart=true
/instance/org.eclipse.jdt.ui/formatter_profile=org.eclipse.j dt.ui.default.ec
lipse_profile
/instance/org.eclipse.jdt.ui/markOccurrences=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.targetP
latform=1.5
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.DebugVie w+org.eclipse.de
bug.ui.debugview.toolbar.toggleStepFilters=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=8
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.inlineJ
srBytecode=enabled
@org.eclipse.jdt.core=3.1.2
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templat es_migrated=true
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.manage_v iew_perspectives
=org.eclipse.debug.ui.DebugPerspective,
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.gettersetter .use.is=true
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<web-browsers current\="0">\r\n<system/>\r\n<external
location\="C\:\\Program Files\\Internet Explorer\\iexplore.exe"
name\="Internet Explorer"/>\r\n</web-browsers>
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=tr
ue
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .source=1.5
/instance/org.eclipse.jdt.ui/internal.default.compliance=def ault
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExcl
usionFilter=*.launch
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.overrideanno tation=true
/instance/org.eclipse.ui.workbench/PLUGINS_NOT_ACTIVATED_ON_ STARTUP=
/instance/org.eclipse.ui.workbench/org.eclipse.jdt.ui.JavaPe rspective_persp=
<?xml version\="1.0" encoding\="UTF-8"?>\r\n<perspective
editorAreaVisible\="1" fixed\="0" version\="0.016">\r\n<descriptor
class\="org.eclipse.jdt.internal.ui.JavaPerspectiveFactory"
id\="org.eclipse.jdt.ui.JavaPerspective" label\="Java"/>\r\n<window
height\="748" width\="1032" x\="-4" y\="-4"/>\r\n<alwaysOnActionSet
id\="org.eclipse.ui.cheatsheets.actionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.search.searchActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.openExternalFile"/ >\r\n<alwaysOnActi
onSet
id\="org.eclipse.ui.edit.text.actionSet.navigation"/>\r\n <alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo "/>\r\n<alway
sOnActionSet
id\="org.eclipse.ui.externaltools.ExternalToolsSet"/>\r\n <alwaysOnActionSet
id\="org.eclipse.ui.actionSet.keyBindings"/>\r\n<alwaysOnActionSet
id\="org.eclipse.update.ui.softwareUpdates"/>\r\n<alwaysOnActionSet
id\="org.eclipse.debug.ui.launchActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.ui.JavaActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.ui.JavaElementCreationActionSet"/>\r\n <alwaysOnActionSe
t id\="org.eclipse.ui.NavigateActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.debug.ui.breakpointActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.debug.ui.JDTDebugActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.jdt.junit.JUnitActionSet"/>\r\n<alwaysOnActionSet
id\="org.eclipse.debug.ui.debugActionSet"/>\r\n<show_view_action
id\="org.eclipse.jdt.ui.PackageExplorer"/>\r\n<show_view_action
id\="org.eclipse.jdt.ui.TypeHierarchy"/>\r\n<show_view_action
id\="org.eclipse.jdt.ui.SourceView"/>\r\n<show_view_action
id\="org.eclipse.jdt.ui.JavadocView"/>\r\n<show_view_action
id\="org.eclipse.search.ui.views.SearchView"/>\r\n<show_view_action
id\="org.eclipse.ui.console.ConsoleView"/>\r\n<show_view_action
id\="org.eclipse.ui.views.ContentOutline"/>\r\n<show_view_action
id\="org.eclipse.ui.views.ProblemView"/>\r\n<show_view_action
id\="org.eclipse.ui.views.ResourceNavigator"/>\r\n<show_view_action
id\="org.eclipse.ant.ui.views.AntView"/>\r\n<show_view_action
id\="org.eclipse.pde.runtime.LogView"/>\r\n<new_wizard_action
id\="org.eclipse.jdt.ui.wizards.NewPackageCreationWizard"/ >\r\n<new_wizard_a
ction
id\="org.eclipse.jdt.ui.wizards.NewClassCreationWizard"/>\r\n <new_wizard_act
ion
id\="org.eclipse.jdt.ui.wizards.NewInterfaceCreationWizard"/ >\r\n<new_wizard
_action
id\="org.eclipse.jdt.ui.wizards.NewEnumCreationWizard"/>\r\n <new_wizard_acti
on
id\="org.eclipse.jdt.ui.wizards.NewAnnotationCreationWizard "/>\r\n<new_wizar
d_action
id\="org.eclipse.jdt.ui.wizards.NewSourceFolderCreationWizard "/>\r\n<new_wiz
ard_action
id\="org.eclipse.jdt.ui.wizards.NewSnippetFileCreationWizard "/>\r\n<new_wiza
rd_action id\="org.eclipse.ui.wizards.new.folder"/>\r\n<new_wizard_action
id\="org.eclipse.ui.wizards.new.file"/>\r\n<new_wizard_action
id\="org.eclipse.ui.editors.wizards.UntitledTextFileWizard"/ >\r\n<new_wizard
_action
id\="org.eclipse.jdt.junit.wizards.NewTestCaseCreationWizard "/>\r\n<perspect
ive_action id\="org.eclipse.jdt.ui.JavaPerspective"/>\r\n<perspective_action
id\="org.eclipse.debug.ui.DebugPerspective"/>\r\n<perspective_action
id\="org.eclipse.jdt.ui.JavaBrowsingPerspective"/>\r\n<view
id\="org.eclipse.jdt.ui.PackageExplorer"/>\r\n<view
id\="org.eclipse.ui.views.ContentOutline"/>\r\n<view
id\="org.eclipse.ui.views.ProblemView"/>\r\n<view
id\="org.eclipse.jdt.ui.SourceView"/>\r\n<view
id\="org.eclipse.ui.console.ConsoleView"/>\r\n<view
id\="org.eclipse.debug.ui.DebugView"/>\r\n<layout>\r\n<mainWindow >\r\n<info
folder\="true" part\="left">\r\n<folder
activePageID\="org.eclipse.ui.views.ContentOutline" appearance\="2"
expanded\="2">\r\n<page content\="org.eclipse.jdt.ui.PackageExplorer"
label\="Package Explorer"/>\r\n<page
content\="org.eclipse.jdt.ui.TypeHierarchy"
label\="LabelNotFound"/>\r\n<page
content\="org.eclipse.ui.views.ResourceNavigator"
content\="org.eclipse.jdt.junit.ResultView"
content\="org.eclipse.ui.views.ContentOutline"
label\="Outline"/>\r\n<presentation
id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory ">\r\n<part
id\="0"/>\r\n<part
id\="1"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n <info folder\="true"
part\="org.eclipse.ui.internal.ViewStack@83d8be" ratio\="0.74950296"
ratioLeft\="754" ratioRight\="252" relationship\="2"
relative\="left">\r\n<folder appearance\="2" expanded\="2">\r\n<page
content\="org.eclipse.help.ui.HelpView" label\="LabelNotFound"/>\r\n<page
content\="org.eclipse.ui.internal.introview"
content\="org.eclipse.ui.cheatsheets.views.CheatSheetView"
label\="LabelNotFound"/>\r\n<presentation
id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory "/>\r\n</folde
r>\r\n</info>\r\n<info part\="org.eclipse.ui.editorss" ratio\="0.165183"
ratioLeft\="167" ratioRight\="844" relationship\="2"
relative\="left"/>\r\n<info folder\="true" part\="bottom" ratio\="0.878882"
ratioLeft\="566" ratioRight\="78" relationship\="4"
relative\="org.eclipse.ui.editorss">\r\n<folder
activePageID\="org.eclipse.ui.console.ConsoleView" appearance\="2"
expanded\="2">\r\n<page content\="org.eclipse.ui.views.ProblemView"
label\="Problems"/>\r\n<page content\="org.eclipse.jdt.ui.JavadocView"
label\="LabelNotFound"/>\r\n<page content\="org.eclipse.jdt.ui.SourceView"
label\="Declaration"/>\r\n<page
content\="org.eclipse.search.ui.views.SearchView"
content\="org.eclipse.ui.console.ConsoleView" label\="Console"/>\r\n<page
content\="org.eclipse.ui.views.BookmarkView"
content\="org.eclipse.ui.views.ProgressView"
label\="LabelNotFound"/>\r\n<page content\="org.eclipse.debug.ui.DebugView"
label\="Debug"/>\r\n<presentation
id\="0"/>\r\n<part id\="1"/>\r\n<part id\="3"/>\r\n<part
id\="2"/>\r\n</presentation>\r\n</folder>\r\n</info>\r\n <info
part\="org.eclipse.ant.ui.views.AntView" ratio\="0.5" ratioLeft\="382"
ratioRight\="382" relationship\="2"
relative\="bottom"/>\r\n</mainWindow>\r\n</layout>\r\n </perspective>
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.assertI
dentifier=error
@org.eclipse.help.ui=3.1.1
/instance/org.eclipse.jdt.ui/fontPropagated=true
/instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDO W=false
@org.eclipse.ui=3.1.2
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ code_templates= <
?xml version\="1.0" encoding\="UTF-8"?><templates/>
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
*** Current Install Configuration:
Install configuration:
Last changed on Feb 12, 2006
Location: file:/f:/Eclipse/configuration/org.eclipse.update/platform.x ml
Configured sites:
platform:/base/
Configured features:
ID: org.eclipse.platform, Version: 3.1.2
ID: org.eclipse.jdt, Version: 3.1.2
ID: org.eclipse.jdt.source, Version: 3.1.2
ID: org.eclipse.jem, Version: 1.2.0
ID: org.eclipse.gef, Version: 3.2.0
ID: org.eclipse.pde.source, Version: 3.1.2
ID: org.eclipse.sdk, Version: 3.1.2
ID: org.eclipse.rcp.source, Version: 3.1.2
ID: org.eclipse.emf, Version: 2.2.0
ID: org.eclipse.platform.source, Version: 3.1.2
ID: org.eclipse.rcp, Version: 3.1.2
ID: org.eclipse.ve, Version: 1.2.0
ID: org.eclipse.pde, Version: 3.1.2
ID: org.eclipse.emf.ecore.sdo, Version: 2.2.0
Configured plug-ins:
file:/f:/Eclipse/plugins/com.ibm.etools.emf.event_3.0.0.2.ja r
file:/f:/Eclipse/plugins/org.apache.ant_1.6.5/
file:/f:/Eclipse/plugins/org.apache.lucene_1.4.3/
file:/f:/Eclipse/plugins/org.eclipse.ant.core_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.ant.ui_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.compare_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.core.boot_3.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.core.commands_3.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.core.expressions_3.1.0. jar
file:/f:/Eclipse/plugins/org.eclipse.core.filebuffers_3.1.2. jar
file:/f:/Eclipse/plugins/org.eclipse.core.resources.compatib ility_3.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.core.resources.win32_3. 1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.core.resources_3.1.2.ja r
file:/f:/Eclipse/plugins/org.eclipse.core.runtime.compatibil ity_3.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.core.runtime_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.core.variables_3.1.0.ja r
file:/f:/Eclipse/plugins/org.eclipse.debug.core_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.debug.ui_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.draw2d_3.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.ant_2.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.codegen.ecore.ui_2. 2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.codegen.ecore_2.2.0 .jar
file:/f:/Eclipse/plugins/org.eclipse.emf.codegen.ui_2.1.0.ja r
file:/f:/Eclipse/plugins/org.eclipse.emf.codegen_2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.common.ui_2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.commonj.sdo_2.1.0.j ar
file:/f:/Eclipse/plugins/org.eclipse.emf.common_2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.converter_2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.ecore.change.edit_2 .1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.ecore.change_2.2.0. jar
file:/f:/Eclipse/plugins/org.eclipse.emf.ecore.editor_2.2.0. jar
file:/f:/Eclipse/plugins/org.eclipse.emf.ecore.edit_2.2.0.ja r
file:/f:/Eclipse/plugins/org.eclipse.emf.ecore.sdo.editor_2. 1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.ecore.sdo.edit_2.1. 0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.ecore.sdo_2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.ecore.xmi_2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.ecore_2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.edit.ui_2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.edit_2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.exporter_2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.importer.ecore_2.2. 0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.importer.java_2.2.0 .jar
file:/f:/Eclipse/plugins/org.eclipse.emf.importer.rose_2.2.0 .jar
file:/f:/Eclipse/plugins/org.eclipse.emf.importer_2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.mapping.ecore2ecore .editor_2.2.0.ja
r
file:/f:/Eclipse/plugins/org.eclipse.emf.mapping.ecore2ecore _2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.mapping.ecore2xml.u i_2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.mapping.ecore2xml_2 .2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf.mapping.ui_2.2.0.ja r
file:/f:/Eclipse/plugins/org.eclipse.emf.mapping_2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.emf_2.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.gef_3.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.help.appserver_3.1.0.ja r
file:/f:/Eclipse/plugins/org.eclipse.help.base_3.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.help.ui_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.help.webapp_3.1.0/
file:/f:/Eclipse/plugins/org.eclipse.help_3.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.jdt.core_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.jdt.debug.ui_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.jdt.debug_3.1.1/
file:/f:/Eclipse/plugins/org.eclipse.jdt.doc.isv_3.1.2/
file:/f:/Eclipse/plugins/org.eclipse.jdt.doc.user_3.1.1/
file:/f:/Eclipse/plugins/org.eclipse.jdt.junit.runtime_3.1.0 /
file:/f:/Eclipse/plugins/org.eclipse.jdt.junit_3.1.1/
file:/f:/Eclipse/plugins/org.eclipse.jdt.launching_3.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.jdt.source_3.1.2/
file:/f:/Eclipse/plugins/org.eclipse.jdt.ui_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.jdt_3.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.jem.beaninfo_1.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.jem.proxy_1.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.jem.ui_1.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.jem.util_1.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.jem.workbench_1.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.jem_1.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.jface.text_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.jface_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.ltk.core.refactoring_3. 1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.ltk.ui.refactoring_3.1. 1.jar
file:/f:/Eclipse/plugins/org.eclipse.osgi.services_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.osgi.util_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.osgi_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.pde.build_3.1.2/
file:/f:/Eclipse/plugins/org.eclipse.pde.core_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.pde.doc.user_3.1.2/
file:/f:/Eclipse/plugins/org.eclipse.pde.junit.runtime_3.1.0 /
file:/f:/Eclipse/plugins/org.eclipse.pde.runtime_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.pde.source_3.1.2/
file:/f:/Eclipse/plugins/org.eclipse.pde.ui_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.pde_3.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.platform.doc.isv_3.1.2/
file:/f:/Eclipse/plugins/org.eclipse.platform.doc.user_3.1.1 /
file:/f:/Eclipse/plugins/org.eclipse.platform.source.win32.w in32.x86_3.1.2/
file:/f:/Eclipse/plugins/org.eclipse.platform.source_3.1.2/
file:/f:/Eclipse/plugins/org.eclipse.platform_3.1.2/
file:/f:/Eclipse/plugins/org.eclipse.rcp.source.win32.win32. x86_3.1.2/
file:/f:/Eclipse/plugins/org.eclipse.rcp.source_3.1.2/
file:/f:/Eclipse/plugins/org.eclipse.rcp_3.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.sdk_3.1.2/
file:/f:/Eclipse/plugins/org.eclipse.search_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.swt.win32.win32.x86_3.1 .2.jar
file:/f:/Eclipse/plugins/org.eclipse.swt_3.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.team.core_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.team.cvs.core_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.team.cvs.ssh2_3.1.0/
file:/f:/Eclipse/plugins/org.eclipse.team.cvs.ssh_3.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.team.cvs.ui_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.team.ui_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.text_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.tomcat_4.1.30.1/
file:/f:/Eclipse/plugins/org.eclipse.ui.browser_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.ui.cheatsheets_3.1.1.ja r
file:/f:/Eclipse/plugins/org.eclipse.ui.console_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.ui.editors_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.ui.externaltools_3.1.1. jar
file:/f:/Eclipse/plugins/org.eclipse.ui.forms_3.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.ui.ide_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.ui.intro_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.ui.presentations.r21_3. 1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.ui.views_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.ui.win32_3.1.0.jar
file:/f:/Eclipse/plugins/org.eclipse.ui.workbench.compatibil ity_3.1.0/
file:/f:/Eclipse/plugins/org.eclipse.ui.workbench.texteditor _3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.ui.workbench_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.ui_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.update.configurator_3.1 .0.jar
file:/f:/Eclipse/plugins/org.eclipse.update.core.win32_3.1.0 .jar
file:/f:/Eclipse/plugins/org.eclipse.update.core_3.1.2.jar
file:/f:/Eclipse/plugins/org.eclipse.update.scheduler_3.1.0. jar
file:/f:/Eclipse/plugins/org.eclipse.update.ui_3.1.1.jar
file:/f:/Eclipse/plugins/org.eclipse.ve.cde_1.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.ve.doc_1.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.ve.java.core_1.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.ve.jfc_1.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.ve.propertysheet_1.2.0. jar
file:/f:/Eclipse/plugins/org.eclipse.ve.swt_1.2.0.jar
file:/f:/Eclipse/plugins/org.eclipse.ve_1.2.0.jar
file:/f:/Eclipse/plugins/org.junit_3.8.1/
Attachment: log.htm
(Size: 347.16KB, Downloaded 404 times)
Re: Error configuring nature [message #612094 is a reply to message #117398] |
Mon, 13 February 2006 11:53  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Two things, you didn't say what VE your where using, and second please
append the .log file. It will give the complete stack trace of the error.
Yevhenii wrote:
> Hello,
Rich Kulp
Re: Error configuring nature [message #612098 is a reply to message #117540] |
Mon, 13 February 2006 19:48  |
I use VE 1.2.0.
When I create a Visual file - the program throws the exception
"Problems encountered while setting project description. Error configuring
nature: org.eclipse.jem.beaninfo.BeanInfoNature."
VE's tool bar doesn't appear.
This is that I found in the log-file.
Thanks for the help.
!ENTRY org.eclipse.ui 4 4 2006-02-14 02:31:22.657
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-02-14 02:31:22.657
!MESSAGE java.lang.NoClassDefFoundError
!STACK 0
org.eclipse.gef.ui.palette.PaletteViewerProvider.createPalet teViewer(Palette
ViewerProvider.java:56)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.setState(F lyoutPaletteComp
osite.java:593)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.updateStat e(FlyoutPaletteC
omposite.java:639)
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.<init>(FlyoutPaletteCompos
ite.java:201)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createS
plitpaneEditor(JavaVisualEditorPart.java:747)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.createP
artControl(JavaVisualEditorPart.java:602)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.jav
a:609)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:384)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReferenc
e.java:552)
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:239)
at org.eclipse.ui.internal.EditorPane.requestActivation(EditorP ane.java:88)
org.eclipse.ui.internal.presentations.PresentablePart.setFoc us(PresentablePa
rt.java:137)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.handleE
vent(TabbedStackPresentation.java:92)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(Abstr
actTabFolder.java:267)
actTabFolder.java:272)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .handleMouseDown
(AbstractTabFolder.java:342)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder $3.mouseDown(Abs
tractTabFolder.java:79)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:133)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.ve.java.core 4 0 2006-02-14 02:31:22.687 !MESSAGE
Exception thrown. !STACK 0 java.lang.NullPointerException
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.re
trieveFromCache(DefaultVisitorFactoryRule.java:83)
org.eclipse.ve.internal.java.codegen.java.rules.DefaultVisit orFactoryRule.ge
tTypeVisitor(DefaultVisitorFactoryRule.java:109)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitType(Jav
aBeanModelBuilder.java:533)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBea
nModelBuilder.java:442)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.reverseParse(
JavaSourceTranslator.java:837)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocumen
t(JavaSourceTranslator.java:919)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(Jav
aSourceTranslator.java:577)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.r
un(JavaVisualEditorPart.java:1971)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.osgi 2006-02-14 02:31:45.440
!MESSAGE Error while stopping "org.eclipse.jem.proxy_1.2.0". !STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.jem.internal.proxy.core.ProxyPlugin.stop() of bundle
org.eclipse.jem.proxy.
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContex
tImpl.java:1051)
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.ja
va:397)
org.eclipse.osgi.framework.internal.core.AbstractBundle.stop (AbstractBundle.
java:408)
org.eclipse.core.runtime.internal.adaptor.BundleStopper.basi cStopBundles(Bun
dleStopper.java:82)
org.eclipse.core.runtime.internal.adaptor.BundleStopper.stop Bundles(BundleSt
opper.java:72)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSto pping(EclipseAda
ptor.java:766)
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:5
28)
org.eclipse.osgi.framework.internal.core.SystemBundle$1.run( SystemBundle.jav
a:171)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NoClassDefFoundError:
org/eclipse/ve/internal/java/codegen/editorpart/JavaVisualEd itorPart$2
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$1.regis
tryTerminated(JavaVisualEditorPart.java:1269)
org.eclipse.jem.internal.proxy.core.ProxyFactoryRegistry.fir eRegistryTermina
ted(ProxyFactoryRegistry.java:149)
org.eclipse.jem.internal.proxy.core.ProxyFactoryRegistry.ter minateRegistry(P
roxyFactoryRegistry.java:304)
roxyFactoryRegistry.java:244)
org.eclipse.jem.internal.proxy.remote.REMRegistryController. shutdown(REMRegi
stryController.java:172)
org.eclipse.jem.internal.proxy.remote.REMRegistryController$ 2.shutdown(REMRe
gistryController.java:77)
org.eclipse.jem.internal.proxy.core.ProxyPlugin.stop(ProxyPl ugin.java:846)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$3 .run(BundleConte
xtImpl.java:1035)
tImpl.java:1031)
.... 8 more
Root exception:
xtImpl.java:1035)
tImpl.java:1031)
va:397)
java:408)
dleStopper.java:82)
opper.java:72)
ptor.java:766)
28)
a:171)
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:<dsqdhp$pvh$1@utils.eclipse.org>...
> error.
> Yevhenii wrote:
> > Hello,
> > java 5.0 SDK. Why VE doesn't work? What's wrong with it?
> Rich Kulp
Re: Error configuring nature [message #612099 is a reply to message #117588] |
Mon, 13 February 2006 20:02  |
I believe this log will be more helpful
!ENTRY org.eclipse.core.resources 4 568 2006-02-14 02:59:53.618
!MESSAGE Problems encountered while setting project description.
!SUBENTRY 1 org.eclipse.core.resources 4 566 2006-02-14 02:59:53.618
!MESSAGE Error configuring nature: org.eclipse.jem.beaninfo.BeanInfoNature.
!STACK 0
java.lang.ExceptionInInitializerError
org.eclipse.jem.util.emf.workbench.EMFWorkbenchContextBase.c reateURIConverte
r(EMFWorkbenchContextBase.java:142)
org.eclipse.jem.util.emf.workbench.EMFWorkbenchContextBase.i nitializeResourc
eSet(EMFWorkbenchContextBase.java:114)
org.eclipse.jem.util.emf.workbench.EMFWorkbenchContextBase.g etResourceSet(EM
FWorkbenchContextBase.java:89)
org.eclipse.jem.internal.plugin.JavaEMFNature.primaryContrib uteToContext(Jav
aEMFNature.java:137)
org.eclipse.jem.internal.util.emf.workbench.EMFWorkbenchCont extFactory.initi
alizeEMFContextFromContributors(EMFWorkbenchContextFactory.j ava:127)
org.eclipse.jem.internal.util.emf.workbench.EMFWorkbenchCont extFactory.creat
eEMFContext(EMFWorkbenchContextFactory.java:110)
org.eclipse.jem.util.emf.workbench.WorkbenchResourceHelperBa se.createEMFCont
ext(WorkbenchResourceHelperBase.java:249)
org.eclipse.jem.util.emf.workbench.nature.EMFNature.createEm fContext(EMFNatu
re.java:105)
org.eclipse.jem.util.emf.workbench.nature.EMFNature.getEmfCo ntextBase(EMFNat
ure.java:229)
org.eclipse.jem.util.emf.workbench.nature.EMFNature.getResou rceSet(EMFNature
..java:184)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.se tProject(Beaninf
oNature.java:317)
org.eclipse.core.internal.resources.NatureManager.createNatu re(NatureManager
..java:229)
org.eclipse.core.internal.resources.NatureManager$1.run(Natu reManager.java:1
39)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
org.eclipse.core.internal.resources.NatureManager.configureN ature(NatureMana
ger.java:155)
org.eclipse.core.internal.resources.NatureManager.configureN atures(NatureMan
ager.java:200)
org.eclipse.core.internal.resources.Project.basicSetDescript ion(Project.java
:62)
org.eclipse.core.internal.resources.Project.setDescription(P roject.java:940)
org.eclipse.core.internal.resources.Project.setDescription(P roject.java:968)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.ad dNatureToProject
(BeaninfoNature.java:137)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.cr eateRuntime(Bean
infoNature.java:126)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoNature.ge tRuntime(Beaninf
oNature.java:83)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.i
nitializeForProject(JavaVisualEditorPart.java:2319)
nitialize(JavaVisualEditorPart.java:2209)
un(JavaVisualEditorPart.java:1913)
Caused by: java.lang.NullPointerException
org.eclipse.jem.util.emf.workbench.WorkbenchURIConverterImpl . <clinit>(Workbe
nchURIConverterImpl.java:38)
... 27 more
!ENTRY org.eclipse.ui 4 4 2006-02-14 03:00:04.343
!ENTRY org.eclipse.ui 4 0 2006-02-14 03:00:04.363
!STACK 0
osite.java:593)
omposite.java:639)
ite.java:201)
a:609)
e.java:552)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:28 3)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(Presentable
Part.java:126)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(Pres
entablePartFolder.java:269)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftTo
RightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPar
t(TabbedStackPresentation.java:391)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.jav
a:1102)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1051)
org.eclipse.ui.internal.PartStack.presentationSelectionChang ed(PartStack.jav
a:785)
at org.eclipse.ui.internal.PartStack.access$0(PartStack.java:77 1)
at org.eclipse.ui.internal.PartStack$1.selectPart(PartStack.jav a:119)
vent(TabbedStackPresentation.java:126)
actTabFolder.java:276)
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder.a
ccess$1(DefaultTabFolder.java:1)
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder$2
..handleEvent(DefaultTabFolder.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:6 60)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.ja va:3138)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:19 22)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:288)
java:226)
!ENTRY org.eclipse.jem.beaninfo 2 0 2006-02-14 03:00:06.106
!MESSAGE Error loading
file" platform:/plugin/org.eclipse.jem/overrides/..ROOT...override "
!STACK 0
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri
'http://www.eclipse.org/emf/2003/Change' not found.
(platform:/plugin/org.eclipse.jem/overrides/..ROOT...overrid e, 2, 240)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2
215)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.jav
a:2053)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java
:1049)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:11
51)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:789
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:76)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:771)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:558)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Un
known Source)
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartEl
ement(Unknown Source)
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl$NSContentDi
spatcher.scanRootElementHook(Unknown Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$Fragm
entContentDispatcher.dispatch(Unknown Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanD
ocument(Unknown Source)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:162)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:1
72)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1015
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:869)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetIm
pl.java:249)
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.demandLoa
d(ProjectResourceSetImpl.java:83)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(Resourc
eSetImpl.java:264)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetI
mpl.java:349)
org.eclipse.jem.internal.util.emf.workbench.ProjectResourceS etImpl.getResour
ce(ProjectResourceSetImpl.java:262)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter$ExtensionDoc
Applies.run(BeaninfoClassAdapter.java:985)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.createOverri
deCache(BeaninfoClassAdapter.java:955)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.applyExtensi
onDocument(BeaninfoClassAdapter.java:916)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(B
eaninfoClassAdapter.java:616)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIf
Necessary(BeaninfoClassAdapter.java:429)
Necessary(BeaninfoClassAdapter.java:416)
org.eclipse.jem.java.internal.impl.JavaClassImpl.getEAnnotat ions(JavaClassIm
pl.java:387)
org.eclipse.ve.internal.cde.emf.ClassDecoratorSourceIterator .findDecorator(C
lassDecoratorSourceIterator.java:37)
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.initi alize(ClassDecor
atorIterator.java:47)
org.eclipse.ve.internal.cde.emf.ClassDecoratorSourceIterator . <init>(ClassDec
oratorSourceIterator.java:33)
org.eclipse.ve.internal.cde.emf.ClassDecoratorFeatureAccess. getDecoratorWith
Feature(ClassDecoratorFeatureAccess.java:67)
trieveFromCache(DefaultVisitorFactoryRule.java:82)
!ENTRY org.eclipse.jem.beaninfo 2 0 2006-02-14 03:00:06.386
file" platform:/plugin/org.eclipse.ve.java.core/overrides/..ROOT.. .override "
!STACK 0
(platform:/plugin/org.eclipse.ve.java.core/overrides/..ROOT. ..override, 2,
530)
215)
a:2053)
:1049)
51)
known Source)
Source)
Source)
Source)
Source)
72)
pl.java:249)
eSetImpl.java:264)
mpl.java:349)
pl.java:387)
!ENTRY org.eclipse.ve.java.core 4 0 2006-02-14 03:00:06.386
!MESSAGE Exception thrown.
!STACK 0
!ENTRY org.eclipse.ui 4 4 2006-02-14 03:00:09.90
!ENTRY org.eclipse.ui 4 0 2006-02-14 03:00:09.100
!STACK 0
osite.java:593)
omposite.java:639)
ite.java:201)
a:609)
e.java:552)
rt.java:137)
java:226)
!ENTRY org.eclipse.ve.java.core 4 0 2006-02-14 03:00:09.180
!STACK 0
!ENTRY org.eclipse.osgi 2006-02-14 03:00:14.618
!STACK 0
tImpl.java:1051)
va:397)
java:408)
dleStopper.java:82)
opper.java:72)
ptor.java:766)
28)
a:171)
xtImpl.java:1035)
tImpl.java:1031)
... 8 more
Root exception:
xtImpl.java:1035)
tImpl.java:1031)
va:397)
java:408)
dleStopper.java:82)
opper.java:72)
ptor.java:766)
28)
a:171)
Re: Error configuring nature [message #612100 is a reply to message #117602] |
More logs
win32
-ws
win32
-arch
x86
-launcher
-name
Eclipse
-showsplash
600
-exitdata
4ec_7c
vmargs
Xmx256M
-vm
-Xmx256m
-jar
eof=eof
file.separator=\
line.separator=
pers
os.arch=x86
os.version=5.0
osgi.arch=x86
Miachyn/workspace/
osgi.nl=en_US
osgi.os=win32
osgi.ws=win32
path.separator=;
i86
sun.desktop=windows
user.country=US
user.dir=F:\Eclipse
user.language=en
user.variant=
*** Features:
Resources"
[Resolved]
[Resolved]
[Resolved]
[Resolved]
Support" [Resolved]
Editor" [Resolved]
[Resolved]
[Resolved]
Editor" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
support" [Resolved]
[Active]
[Resolved]
Support" [Resolved]
[Resolved]
Support" [Resolved]
[Resolved]
[Resolved]
Guide" [Resolved]
[Resolved]
[Resolved]
Windows" [Resolved]
[Resolved]
[Resolved]
[Active]
[Resolved]
[Resolved]
[Resolved]
[Active]
=true
ective
ntifier=error
om;
heck=enabled
lipse_profile
latform=1.5
srBytecode=enabled
ue
onSet
sOnActionSet
ction
ion
_action
on
d_action
ard_action
_action
id\="0"/>\r\n<part
dentifier=error
Configured sites:
platform:/base/
r
Attachment: log.htm
(Size: 347.16KB, Downloaded 669 times)
Re: Error configuring nature [message #612103 is a reply to message #117620] |
Tue, 14 February 2006 10:35  |
You don't have Eclipse 3.2M4 installed. You have Eclipse 3.1.2
installed. That version of Eclipse is not compatible with VE 1.2, GEF
3.2M4, and EMF 2.2M4. Please step up to Eclipse 3.2M4.
Yevhenii wrote:
> More logs
Rich Kulp
Re: Error configuring nature [message #612107 is a reply to message #117821] |
Tue, 14 February 2006 12:58  |
Thanks.
news:dsstcf$m0m$1@utils.eclipse.org...
> Yevhenii wrote:
> > More logs
> Rich Kulp
Re: Error configuring nature [message #612108 is a reply to message #117821] |
Tue, 14 February 2006 13:23  |
Which version of VE, GEF, and EMF should I install on Eclipse 3.1.2?
> Yevhenii wrote:
> > More logs
> Rich Kulp
Re: Error configuring nature [message #612109 is a reply to message #117878] |
Tue, 14 February 2006 14:06  |
VE 1.1.0.1, GEF 3.1.1, EMF 2.1.2
> Thanks
>>Yevhenii wrote:
>>>More logs
>>Thanks,
>>Rich Kulp
Rich Kulp
Re: Error configuring nature [message #612173 is a reply to message #117588] |
Thu, 23 February 2006 00:56  |
Originally posted by: suresh_cud.yahoo.co.in
I use VE 1.1.0.
Very Urgent !!!!!!!!
Please give some valid suggestions.
I am waiting for Ur Reply
Thanks & Regards,
Suresh Ramanujam.
Current Time: Mon Jul 21 21:00:34 EDT 2025
Powered by FUDForum. Page generated in 0.08038 seconds
