Home » Language IDEs » Java Development Tools (JDT) » how to access java build path from ant script ?
how to access java build path from ant script ? [message #117395] Sun, 16 November 2003 15:43 Go to next message
hi all,
i'd like to compile a whole project using the external javac compiler.
afaik this is only possible by using an ant script.
the project has dependencies on other projects and on some external jars
all defined in 'properties -> java build path' in the ide.
how can i access the java build path from within my ant script ?
thanks
jakob
Re: how to access java build path from ant script ? [message #117421 is a reply to message #117395] Sun, 16 November 2003 17:26 Go to previous messageGo to next message
I believe people have developed Ant tasks that will do just as you are
requesting.
These have been mentioned on this newsgroup. I would recommend searching the
archives
Darins
"Jakob Braeuchi" <jbraeuchi@hotmail.com> wrote in message
news:bp8nfd$b92$1@eclipse.org...
> hi all,
> thanks
> jakob
Re: how to access java build path from ant script ? [message #117546 is a reply to message #117421] Mon, 17 November 2003 07:07 Go to previous messageGo to next message
hi darin,
i found AntPlus on http://members.optushome.com.au/tomdavies/eclipse.html .
why does the Ant Builder not provide this useful feature ?
jakob
> requesting.
> archives
> Darins
> > hi all,
> > thanks
> > jakob
Re: how to access java build path from ant script ? [message #117656 is a reply to message #117546] Mon, 17 November 2003 10:49 Go to previous message
No one has directly filed a feature request asking for it
I do know that there has been work on the JDTCompilerAdapter to make use of
the project build path but I am not sure what stage this work is at.
Darins
news:bpadmp$srk$1@eclipse.org...
> hi darin,
> jakob
> > requesting.
the
> > archives
> > Darins
> > > hi all,
jars
> > > thanks
> > > jakob
Previous Topic:[DEBUG] problem to break into listener?
Next Topic:new to IDEs and need experienced help!
Current Time: Thu Jul 24 02:24:32 EDT 2025
Powered by FUDForum. Page generated in 0.07020 seconds
