Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Net4j] newbee: Example for a simple server and client
[Net4j] newbee: Example for a simple server and client [message #117351] Tue, 08 April 2008 18:14 Go to next message
I am searching for an easy server and client example to start learning
the Net4j Framework.
I thought on something like an echo server.
I am not sure where to start.
All I have tried did not work.
Do you have any suggestion for me.
Thank you
Torsten
Re: [Net4j] newbee: Example for a simple server and client [message #117484 is a reply to message #117351] Wed, 09 April 2008 12:49 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Hi Torsten,
Have you already had a look at the slides that I prepared for my short talk at the EclipseCon?
You can find them at http://www.eclipsecon.org/2008/index.php?page=sub/&id=21 2
There are also some examples on how to implement a Net4j protocol, all of them fairly larger than an echo protocol:
- org.eclipse.net4j.buddies + org.eclipse.net4j.chat
- org.eclipse.net4j.jms
- org.eclipse.emf.cdo
I agree that a smaller example would be good to have. Please feel free to open a Bugzilla!
I guess that you'll come back with more detailed questions after you walked through the slides that I mentioned above.
If so, please give a bit of information about the environment you plan to let your client and server run in (standalone, pure OSGi, Eclipse, ...)
Cheers
/Eike
Torsten Link schrieb:
> Thank you
> Torsten
Re: [Net4j] newbee: Example for a simple server and client [message #117523 is a reply to message #117484] Wed, 09 April 2008 13:53 Go to previous messageGo to next message
Hi Eike,
I already had a look at the slides but is this for a new protokoll or for an
existing one?
I also had a look at the examples and the testcode but I get a little bit
lost. These examples are to complex for me. To find a starting point is my
problem.
The server should run as 'standalone' as possible but I would like the use
the plugin funktionality so I think it will need OSGi.
Thank you
Torsten
Eike Stepper wrote:
> Hi Torsten,
> talk at the EclipseCon? You can find them at
> them fairly larger than an echo protocol: - org.eclipse.net4j.buddies +
> org.eclipse.net4j.chat - org.eclipse.net4j.jms
> open a Bugzilla!
> walked through the slides that I mentioned above. If so, please give a bit
> Cheers
> /Eike
>> Thank you
>> Torsten
Re: [Net4j] newbee: Example for a simple server and client [message #117671 is a reply to message #117523] Thu, 10 April 2008 09:21 Go to previous messageGo to next message
Hi Torsten,
I'll write and commit an additional small ECHOProtocol example this
evening and post here when you can check it out.
Cheers
/Eike
Torsten Link wrote:
> Hi Eike,
> existing one?
> problem.
> Thank you
> Torsten
> Eike Stepper wrote:
>> Hi Torsten,
>> open a Bugzilla!
>> Cheers
>> /Eike
>>> Hi,
>>> Thank you
>>> Torsten
Re: [Net4j] newbee: Example for a simple server and client [message #117696 is a reply to message #117671] Thu, 10 April 2008 13:36 Go to previous messageGo to next message
Hi Eike,
Thank you for your quick Help.
Torsten
Eike Stepper wrote:
> Hi Torsten,
> Cheers
> /Eike
> Torsten Link wrote:
>> Hi Eike,
>> an existing one?
>> my problem.
>> use the plugin funktionality so I think it will need OSGi.
>> Thank you
>> Torsten
>> Eike Stepper wrote:
>>> Hi Torsten,
>>> of them fairly larger than an echo protocol: - org.eclipse.net4j.buddies
>>> + org.eclipse.net4j.chat - org.eclipse.net4j.jms
>>> to open a Bugzilla!
>>> Cheers
>>> /Eike
>>>> Hi,
>>>> Thank you
>>>> Torsten
Re: [Net4j] newbee: Example for a simple server and client [message #117792 is a reply to message #117696] Fri, 11 April 2008 05:46 Go to previous messageGo to next message
Torsten Link wrote:
> Hi Eike,
Your thanks came too early ;-(
Apologies for being late but my current customer ovewrly occupies me at
the moment.
I hope that on my flieght back tonight I'll have the time to hammer a
good/simple example...
Cheers
/Eike
> Torsten
> Eike Stepper wrote:
>> Hi Torsten,
>> Cheers
>> /Eike
>> Torsten Link wrote:
>>> Hi Eike,
>>> an existing one?
>>> my problem.
>>> Thank you
>>> Torsten
>>> Eike Stepper wrote:
>>>> Hi Torsten,
>>>> to open a Bugzilla!
>>>> Cheers
>>>> /Eike
>>>>> Hi,
>>>>> Thank you
>>>>> Torsten
Re: [Net4j] newbee: Example for a simple server and client [message #117928 is a reply to message #117696] Sat, 12 April 2008 03:56 Go to previous message
--------------060308000102000608000000
Hi Torsten,
You can find the ECHO protocol example in the org.eclipse.net4j.examples
plugin:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.net4j/examples/org.eclipse.net4j.examples/src/o rg/eclipse/net4j/examples/echo/?root=Modeling_Project
It is designed for running the EchoServer and EchoClients standalone.
If you plan to use OSGi/Eclipse as environment you could contribute your
protocol factories via the org.eclipse.net4j.util.factories extension
point. See
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.net4j/examples/org.eclipse.net4j.examples/plugi n.xml?revision=1.1&root=Modeling_Project&view=markup
If your own application is asymmetric and starts to grow you might want
to separate the respective client and server code into separate plugins
as well.
Cheers
/Eike
> Hi Eike,
> Torsten
> Eike Stepper wrote:
>> Hi Torsten,
>> Cheers
>> /Eike
>> Torsten Link wrote:
>>> Hi Eike,
>>> an existing one?
>>> my problem.
>>> Thank you
>>> Torsten
>>> Eike Stepper wrote:
>>>> Hi Torsten,
>>>> to open a Bugzilla!
>>>> Cheers
>>>> /Eike
>>>>> Hi,
>>>>> Thank you
>>>>> Torsten
<html>
<head>
</head>
Hi Torsten,<br>
<br>
org.eclipse.net4j.examples plugin:<br>
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.net4j/examples/org.eclipse.net4j.examples/src/o rg/eclipse/net4j/examples/echo/?root=Modeling_Project"> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.net4j/examples/org.eclipse.net4j.examples/src/o rg/eclipse/net4j/examples/echo/?root=Modeling_Project</a><br>
<br>
It is designed for running the EchoServer and EchoClients standalone.<br>
your protocol factories via the org.eclipse.net4j.util.factories
extension point. See
<a class="moz-txt-link-freetext" href=" http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.net4j/examples/org.eclipse.net4j.examples/plugi n.xml?revision=1.1&root=Modeling_Project&view=markup"> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.net4j/examples/org.eclipse.net4j.examples/plugi n.xml?revision=1.1&amp;root=Modeling_Project&amp;view=markup</a><br>
<br>
as well.<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
<blockquote cite="mid:ftlj7a$h2v$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Eike,
Torsten
Eike Stepper wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Hi Torsten,
Cheers
/Eike
Torsten Link wrote:
</pre>
</pre>
</blockquote>
<pre wrap="">I already had a look at the slides but is this for a new protokoll or for
an existing one?
</pre>
</blockquote>
<pre wrap="">I also had a look at the examples and the testcode but I get a little bit
my problem.
</pre>
</blockquote>
<pre wrap="">The server should run as 'standalone' as possible but I would like the
</pre>
</blockquote>
<pre wrap="">
</pre>
<pre wrap="">Thank you
</pre>
</blockquote>
<pre wrap="">
</pre>
<pre wrap="">Torsten
</pre>
</blockquote>
<pre wrap="">
</pre>
<pre wrap="">Eike Stepper wrote:
</pre>
</blockquote>
<a class="moz-txt-link-freetext" href=" http://www.eclipsecon.org/2008/index.php?page=sub/&id=21 2">http://www.eclipsecon.org/2008/index.php?page=sub/&amp;id=212</a>
to open a Bugzilla!
Cheers
/Eike
</pre>
<pre wrap="">Hi,
Thank you
Torsten
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------060308000102000608000000--
Re: [Net4j] newbee: Example for a simple server and client [message #616150 is a reply to message #117351] Wed, 09 April 2008 12:49 Go to previous message
Hi Torsten,
Cheers
/Eike
> Thank you
> Torsten
Re: [Net4j] newbee: Example for a simple server and client [message #616161 is a reply to message #117484] Wed, 09 April 2008 13:53 Go to previous message
Hi Eike,
existing one?
problem.
Thank you
Torsten
Eike Stepper wrote:
> Hi Torsten,
> open a Bugzilla!
> Cheers
> /Eike
>> Thank you
>> Torsten
Re: [Net4j] newbee: Example for a simple server and client [message #616184 is a reply to message #117523] Thu, 10 April 2008 09:21 Go to previous message
Hi Torsten,
Cheers
/Eike
Torsten Link wrote:
> Hi Eike,
> existing one?
> problem.
> Thank you
> Torsten
> Eike Stepper wrote:
>> Hi Torsten,
>> open a Bugzilla!
>> Cheers
>> /Eike
>>> Hi,
>>> Thank you
>>> Torsten
Re: [Net4j] newbee: Example for a simple server and client [message #616188 is a reply to message #117671] Thu, 10 April 2008 13:36 Go to previous message
Hi Eike,
Torsten
Eike Stepper wrote:
> Hi Torsten,
> Cheers
> /Eike
> Torsten Link wrote:
>> Hi Eike,
>> an existing one?
>> my problem.
>> Thank you
>> Torsten
>> Eike Stepper wrote:
>>> Hi Torsten,
>>> to open a Bugzilla!
>>> Cheers
>>> /Eike
>>>> Hi,
>>>> Thank you
>>>> Torsten
Re: [Net4j] newbee: Example for a simple server and client [message #616204 is a reply to message #117696] Fri, 11 April 2008 05:46 Go to previous message
Torsten Link wrote:
> Hi Eike,
the moment.
Cheers
/Eike
> Torsten
> Eike Stepper wrote:
>> Hi Torsten,
>> Cheers
>> /Eike
>> Torsten Link wrote:
>>> Hi Eike,
>>> an existing one?
>>> my problem.
>>> Thank you
>>> Torsten
>>> Eike Stepper wrote:
>>>> Hi Torsten,
>>>> to open a Bugzilla!
>>>> Cheers
>>>> /Eike
>>>>> Hi,
>>>>> Thank you
>>>>> Torsten
Re: [Net4j] newbee: Example for a simple server and client [message #616225 is a reply to message #117696] Sat, 12 April 2008 03:56 Go to previous message
Hi Torsten,
plugin:
point. See
as well.
Cheers
/Eike
> Hi Eike,
> Torsten
> Eike Stepper wrote:
>> Hi Torsten,
>> Cheers
>> /Eike
>> Torsten Link wrote:
>>> Hi Eike,
>>> an existing one?
>>> my problem.
>>> Thank you
>>> Torsten
>>> Eike Stepper wrote:
>>>> Hi Torsten,
>>>> to open a Bugzilla!
>>>> Cheers
>>>> /Eike
>>>>> Hi,
>>>>> Thank you
>>>>> Torsten
<html>
<head>
</head>
Hi Torsten,<br>
<br>
<br>
<br>
as well.<br>
<br>
Cheers<br>
/Eike<br>
<br>
<br>
Torsten
Eike Stepper wrote:
</pre>
Cheers
/Eike
Torsten Link wrote:
</pre>
</pre>
</blockquote>
an existing one?
</pre>
</blockquote>
my problem.
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">
</pre>
</pre>
</blockquote>
<pre wrap="">
</pre>
</pre>
</blockquote>
<pre wrap="">
</pre>
</pre>
</blockquote>
to open a Bugzilla!
Cheers
/Eike
</pre>
<pre wrap="">Hi,
Thank you
Torsten
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Previous Topic:[Teneo] org.eclipse.emf.teneo.libraries and commons-logging
Next Topic:[Teneo] Unload() questions
Current Time: Sun Jul 27 11:09:18 EDT 2025
Powered by FUDForum. Page generated in 0.06750 seconds
