Home » Eclipse Projects » Remote Application Platform (RAP) » Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme'
Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #117224] Sat, 27 December 2008 12:29 Go to next message
Hi, since last CVS update I'm getting this Exception and I don't what is
wrong. I think, I don't made any change on my code.
Can anybody explain this?
Roland
java.lang.IllegalArgumentException: Undefined key: 'text.SINGLE.padding'
at org.eclipse.rwt.internal.theme.Theme.getValue(Theme.java:257 )
at org.eclipse.rwt.internal.theme.Theme.getValue(Theme.java:229 )
org.eclipse.rwt.internal.theme.AppearancesUtil.substituteMac ros(AppearancesUtil.java:55)
org.eclipse.rwt.internal.theme.ThemeManager.createAppearance Theme(ThemeManager.java:966)
org.eclipse.rwt.internal.theme.ThemeManager.registerThemeFil es(ThemeManager.java:758)
org.eclipse.rwt.internal.theme.ThemeManager.registerResource s(ThemeManager.java:407)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.write Libraries(DisplayLCA.java:297)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCAFacade Impl.writeLibrariesInternal(DisplayLCAFacadeImpl.java:33)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCAFacade .writeLibraries(DisplayLCAFacade.java:36)
org.eclipse.rwt.internal.lifecycle.DisplayUtil.writeLibrarie s(DisplayUtil.java:66)
org.eclipse.rwt.internal.service.LifeCycleServiceHandlerConf igurer.getLibraries(LifeCycleServiceHandlerConfigurer.java:2 01)
org.eclipse.rwt.internal.service.LifeCycleServiceHandlerConf igurer.getTemplateOfStartupPage(LifeCycleServiceHandlerConfi gurer.java:61)
org.eclipse.rwt.internal.service.BrowserSurvey.renderScript( BrowserSurvey.java:89)
org.eclipse.rwt.internal.service.BrowserSurvey.sendBrowserSu rvey(BrowserSurvey.java:50)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.int ernalService(LifeCycleServiceHandler.java:197)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.acc ess$1(LifeCycleServiceHandler.java:185)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler$Lif eCycleServiceHandlerSync.doService(LifeCycleServiceHandler.j ava:150)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.serviceInternal(RWTLifeCycleServiceHandlerSync.java:46 )
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.service(RWTLifeCycleServiceHandlerSync.java:34)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.ser vice(LifeCycleServiceHandler.java:157)
org.eclipse.rwt.internal.service.ServiceManager$HandlerDispa tcher.service(ServiceManager.java:101)
at org.eclipse.rwt.internal.engine.RWTDelegate.doPost(RWTDelega te.java:63)
org.eclipse.ui.internal.servlet.RequestHandler.service(Reque stHandler.java:51)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:269)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #117238 is a reply to message #117224] Sat, 27 December 2008 14:30 Go to previous messageGo to next message
Originally posted by: ifurnadjiev.innoopract.com
Hi Roland,
do you use a custom theme for your application? If yes - did you switch
to CSS-based themeing or you still use the old properties one?
The support for old properties-based themeing will be discontinue in
1.2M4. Search the newsgroup for "[ANN] Properties theming support
discontinued in 1.2 M4" for more details.
Best,
Ivan
> is wrong. I think, I don't made any change on my code.
> Roland
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #117266 is a reply to message #117238] Sun, 28 December 2008 12:11 Go to previous messageGo to next message
Thanks for your hint. I found out, that I'm using an old version of the
upload-widget from the CVS.
Now everything works fine.
Roland
Ivan Furnadjiev schrieb:
> Hi Roland,
> Best,
> Ivan
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118002 is a reply to message #117266] Fri, 09 January 2009 10:46 Go to previous messageGo to next message
Hi!
I'm using the last version of the file upload from CVS, using no custom
theme but sill having the same error.
e.g.
osgi> 2009-01-09 16:27:22.142::INFO: Logging to STDERR via
org.mortbay.log.StdErrLog
2009-01-09 16:27:22.236::INFO: jetty-6.1.x
2009-01-09 16:27:23.705::INFO: Started SelectChannelConnector@0.0.0.0:4067
2009-01-09 16:27:29.972::WARN: /rap
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:255)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:487)
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:362)
org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandl er.java:181)
org.mortbay.jetty.handler.ContextHandler.handle(ContextHandl er.java:726)
org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapp er.java:139)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnectio n.java:505)
org.mortbay.jetty.HttpConnection$RequestHandler.headerComple te(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java: 211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java: 380)
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn dPoint.java:395)
org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedT hreadPool.java:450)
can I have a real help?
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118015 is a reply to message #118002] Fri, 09 January 2009 11:05 Go to previous messageGo to next message
are you using the RAP version from CVS HEAD too?
Best,
Ivan
New Yop Javeloper wrote:
> Hi!
> custom theme but sill having the same error.
> e.g.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118028 is a reply to message #118015] Fri, 09 January 2009 12:05 Go to previous messageGo to next message
Yes I'm usin the version provided here :
http://download.eclipse.org/rt/rap/1.2/update
and also using the last file upload widget version from cvs.
best regards.
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118039 is a reply to message #118028] Fri, 09 January 2009 12:27 Go to previous messageGo to next message
--------------060101010104020505050103
Is the org.eclipse.rwt.widgets.upload.demo from the CVS sandbox working
for you? Please check that you are using the the latest upload widget
from " */cvsroot/rt/*org.eclipse.rap/sandbox/org.eclipse.rwt.widget s.upload ".
Best,
Ivan
> best regards.
<html>
<head>
http-equiv="Content-Type">
</head>
from "<b>/cvsroot/rt/</b>org.eclipse.rap/sandbox/org.eclipse.rwt.widgets.upload ".<br>
<br>
Best,<br>
Ivan<br>
<br>
<blockquote
cite="mid:ba78725d77f70502ef3bead8b17b65fa$1@www.eclipse.org"
type="cite">Yes I'm usin the version provided here :
<a class="moz-txt-link-freetext" href="http://download.eclipse.org/rt/rap/1.2/update">http://download.eclipse.org/rt/rap/1.2/update</a>
<br>
<br>
<br>
best regards.
<br>
<br>
</blockquote>
</body>
</html>
--------------060101010104020505050103--
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118050 is a reply to message #118039] Fri, 09 January 2009 12:52 Go to previous messageGo to next message
Yes, i'm 500% sure that I'm usig that version!
I followed the instruction on the readme file that are:
If you get compile error you can use the supplied Team Project Set file
"rap-sandbox-upload-widget.psf", to check out all necessary projects
into your workspace.
1. Select "rap-sandbox-uploadwidget.psf"
2. Right click
3. Choose "Import Project Set..."
4. Follow the instructions in the dialog
The project set file will add these projects to your workspace:
org.apache.commons.fileupload (v1_2)
org.apache.commons.io (v_1_3_2)
org.eclipse.rwt.widgets.uploads.demo (optional, contains an example)
If you have further questions, post to the RAP newsgroup:
http://www.eclipse.org/rap/newsgroup.php
Have fun!
I'm so sure that I've any dependencies error, but it doesn't work, I have
the same stacktrace.
Best regards.
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118343 is a reply to message #118050] Mon, 12 January 2009 10:40 Go to previous messageGo to next message
Still No Way!
Can I have a real help?
this is what i did:
1 - downloaded last version on http://eclipse.org of
a/ eclipse jee for java developper
b/ pointed it to http://download.eclipse.org/rt/rap/1.2/update/ to have
the last update of RAP. and installed the target platform.
c/ imported rap-sandbox-upload-widget.psf from
:pserver:anonymous@dev.eclipse.org :/cvsroot/rt/org.eclipse.rap/sandbox/org.eclipse.rwt.widgets .upload/
(I'm so sure to have no dependencies problems)
2 - set a run configuration with the run config wizard:
a- servlet name : rap
b- entry Point : default (being the one on the plugin.xml file)
c- selected all bundles to avoid validation problems
d- set this : "-os ${target.os} -ws ${target.ws} -arch ${target.arch} -nl
${target.nl} -console -consolelog" as program arguments and
e- this "-Declipse.ignoreApp=true -Dosgi.noShutdown=true" as VM arguments
f- set "${workspace_loc:org.eclipse.rwt.widgets.upload.demo}" as default
location (my jre being 1.6.0_07)
g- \org.eclipse.rwt.widgets.upload.demo for the launch shared file
BUT IT STILL DONT WORK
I STILL HAVE THE SAME STACKTRACE:
osgi> 2009-01-12 16:39:27.992::INFO: Logging to STDERR via
2009-01-12 16:39:27.102::INFO: jetty-6.1.x
2009-01-12 16:39:27.352::INFO: Started SelectChannelConnector@0.0.0.0:4772
2009-01-12 16:39:37.610::WARN: /rap
is there someone wanting to give me a good help?
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118353 is a reply to message #118343] Mon, 12 January 2009 15:14 Go to previous messageGo to next message
you're using a custom widget which contributes an obsolete
*.appearances.js file (see [1]). If this is not the upload widget, then
it must be some other custom widget. Please check your plugin.xml files
for extensions of the themeableWidgets extension point.
[1]
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg05026.html
Regards, Ralf
> Still No Way!
> this is what i did:
> -nl ${target.nl} -console -consolelog" as program arguments and
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118386 is a reply to message #118353] Tue, 13 January 2009 07:48 Go to previous messageGo to next message
Hi & thank you!
I took a look to the upload widget source especially the *.js sources and
I found what was the error.
There's an error en the
org.eclipse.rwt.widgets.internal.uploadkit.Upload.appearance s.js file. We
have in the source code :
return {
padding :THEME_VALUE("text.SINGLE.padding"),
that sould be replaced by :
return {
padding :THEME_VALUE('text.SINGLE.padding'),
It was just a simple quotes matter, doubles ones in the source having to
be replaced by single one.
I now have no error at lauching time but when seeked the upload wigets
brings new problem that is explained here :
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg04480.html
*.js files are not delivered to the client. I'm now learning more.
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118394 is a reply to message #118386] Tue, 13 January 2009 08:36 Go to previous messageGo to next message
> Hi & thank you!
> and I found what was the error.
> We have in the source code :
> return {
This is indeed an outdated version. The current version of this file reads:
"upload-field" : {
style : function( states ) {
var tv = new org.eclipse.swt.theme.ThemeValues( states );
return {
border : tv.getCssBorder( "Text", "border" ),
font : tv.getCssFont( "Text", "font" ),
padding : tv.getCssBoxDimensions( "Text", "padding" ),
textColor : states.disabled
? tv.getColor( "widget.graytext" )
: tv.getCssColor( "Text", "color" ),
backgroundColor : tv.getCssColor( "Text", "background-color" )
> return {
No, it should not. You should get the actual version from CVS like Ivan
advised 5 postings before.
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118408 is a reply to message #118394] Tue, 13 January 2009 11:27 Go to previous messageGo to next message
Yes everything works fine now!
it's just this psf file that brang the pain:
<psf version="2.0">
<provider id="org.eclipse.team.cvs.core.cvsnature">
<project
reference="1.0,:pserver:anonymous@dev.eclipse.org :/cvsroot/tools,org.eclipse.orbit/org.apache.commons.fileupl oad,org.apache.commons.fileupload,v1_2 "/>
<project
reference="1.0,:pserver:anonymous@dev.eclipse.org :/cvsroot/tools,org.eclipse.orbit/org.apache.commons.io,org. apache.commons.io,v1_3_2 "/>
<project
reference="1.0,:pserver:anonymous@dev.eclipse.org :/cvsroot/technology,org.eclipse.rap/sandbox/org.eclipse.rwt .widgets.upload,org.eclipse.rwt.widgets.upload "/>
<project
reference="1.0,:pserver:anonymous@dev.eclipse.org :/cvsroot/technology,org.eclipse.rap/sandbox/org.eclipse.rwt .widgets.upload.demo,org.eclipse.rwt.widgets.upload.demo "/>
</provider>
</psf>
Thank You All!
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118414 is a reply to message #118408] Tue, 13 January 2009 12:39 Go to previous messageGo to next message
thanks for pointing this out. I updated the psf file.
Regards, Ralf
> <psf version="2.0">
> <project
> <project
> <project
> <project
> </provider>
> </psf>
> Thank You All!
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #118428 is a reply to message #118414] Wed, 14 January 2009 06:01 Go to previous messageGo to next message
Hi Ralf,
to prevent further problems with the outdated upload widget, maybe the old
code at cvsroot/technology should be removed.
Your new *.psf file and a README with a comment could be placed instead.
The same problem occured also for me and it works now with the new CVS
location.
Andreas
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #119332 is a reply to message #118039] Fri, 23 January 2009 04:54 Go to previous messageGo to next message
Thank you :-)
I will ask more questions in this thread, if I have more problems with it.
Re: Undefined key: 'text.SINGLE.padding' in theme 'RAP Default Theme' [message #119371 is a reply to message #118428] Fri, 23 January 2009 05:43 Go to previous message
I agree with Andreas. Furthemore is there any plan to include the upload
widget in the rap project ?
Emmanuel
> Hi Ralf,
> location.
> Andreas
Previous Topic:How to get or create the PerspectiveSwitcher Bar?
Next Topic:Not Well-Formed HttpServletResponse with custom widget
Current Time: Sat May 10 11:17:40 EDT 2025
Powered by FUDForum. Page generated in 0.06833 seconds
