Home » Eclipse Projects » Equinox » Equinox Aspects - BundleException at Shutdown
Equinox Aspects - BundleException at Shutdown [message #117217] Tue, 09 September 2008 12:28 Go to next message
my tried to use Equinox Aspects in a RCP application. Therefore, I created
an application from the "hello world" template and loaded it with the two
bundles from the hello world example for equinox aspects.
org.eclipse.equinox.weaving.demo.hello and
org.eclipse.equinox.weaving.demo.hello.aspects
Everything works fine, but at the equinox shutdown after the Activator's
stop method is left following exception is thrown:
org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException:
The bundle's start level is not met. Cannot transient start the bundle:
initial@reference:file:../../org.eclipse.equinox.weaving.demo.hello/ [18]
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:313)
org.eclipse.osgi.framework.internal.core.AbstractBundle.upda teWorker(AbstractBundle.java:702)
org.eclipse.osgi.framework.internal.core.AbstractBundle.upda te(AbstractBundle.java:613)
org.eclipse.equinox.service.weaving.SupplementerRegistry.upd ateInstalledBundle(SupplementerRegistry.java:255)
org.eclipse.equinox.weaving.adaptors.AspectJAdaptorFactory$1 .serviceChanged(AspectJAdaptorFactory.java:107)
org.eclipse.osgi.framework.internal.core.FilteredServiceList ener.serviceChanged(FilteredServiceListener.java:91)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1248)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEventPrivileged(Framework.java:1563)
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEvent(Framework.java:1538)
org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl.unregister(ServiceRegistrationImpl.java:177)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.c lose(BundleContextImpl.java:132)
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.java:460)
org.eclipse.osgi.framework.internal.core.AbstractBundle.susp end(AbstractBundle.java:531)
org.eclipse.osgi.framework.internal.core.Framework.suspendBu ndle(Framework.java:1104)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ecFWSL(StartLevelManager.java:655)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:312)
org.eclipse.osgi.framework.internal.core.StartLevelManager.s hutdown(StartLevelManager.java:257)
org.eclipse.osgi.framework.internal.core.SystemBundle.suspen d(SystemBundle.java:236)
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:678)
org.eclipse.osgi.framework.internal.core.Framework.close(Fra mework.java:576)
at org.eclipse.osgi.framework.internal.core.OSGi.close(OSGi.jav a:41)
org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(Ecl ipseStarter.java:420)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:200)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Does anyone know if I made something wrong?
I have used the Milestone 1 version of Equinox Aspects.
Greetings
Adam
Re: Equinox Aspects - BundleException at Shutdown [message #117232 is a reply to message #117217] Wed, 10 September 2008 04:31 Go to previous message
I found the failure in my test environment. I mixed up
BundleActivators(org.osgi.framework) with
Plugins(org.eclipse.core.runtime). After converting the Equinox Aspects
helloworld example to plugins everything was fine.
Adam
Previous Topic:[P2] Problem creating repository with .product when exporting for multiple platforms
Next Topic:[P2] Test code
Current Time: Sun Jul 27 01:38:21 EDT 2025
Powered by FUDForum. Page generated in 0.04410 seconds
