Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Announce] Texo project proposal: EMF technology for web application development environments
[Announce] Texo project proposal: EMF technology for web application development environments [message #117181] Mon, 07 April 2008 17:19 Go to next message
A proposal for a new component (Texo) under the EMFT project has been
posted to the EMFT wiki (http://wiki.eclipse.org/Texo).
The goal of the proposed Texo project is to provide model and template
driven development technology for web application environments. Texo
will provide a toolset and a set of standard templates for generating
most artifacts of a web application. Initially the focus is on
generating JSF web applications and the related artifacts: annotated
java beans, ui backing beans, JSF pages, JSF navigation, bean
configuration and property files for i18n. Texo will be based on and use
components currently present in the EMF, EMFT, M2T projects.
I am looking forward to your comments or feedback on this new proposal.
Martin Taal
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Announce] Texo project proposal: EMF technology for web application develop [message #117195 is a reply to message #117181] Mon, 07 April 2008 18:31 Go to previous messageGo to next message
Hi Martin,
This is a very interesting proposal. We would definitely be interested in
providing input on this. Is there a bugzilla for us to comment on?
Raghu Srinivasan
Project Lead - JSF Tools Project
Re: [Announce] Texo project proposal: EMF technology for web application develop [message #117221 is a reply to message #117195] Tue, 08 April 2008 03:27 Go to previous messageGo to next message
Hi Raghu,
Thanks for your interest. I am looking forward to any input or feedback you or others may have.
I created a bugzilla for more detailed discussions:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=226080
gr. Martin
Raghu Srinivasan wrote:
> Hi Martin,
> in providing input on this. Is there a bugzilla for us to comment on?
> Thanks
> Raghu Srinivasan
The Netherlands
Re: [Announce] Texo project proposal: EMF technology for web application development environments [message #118671 is a reply to message #117181] Wed, 16 April 2008 07:02 Go to previous messageGo to next message
Hi Martin,
indeed avery interesting proposal. Here are some thoughts:
1) How about adding RCP support? If the backend architecture is
well-cut, it should be easy to attach an RCP frontend (e.g. using
Spring HTTP remoting). 2) To me, the proposal sounds like a generator
"cartridge". I bet there are quite a number of people out there who
would come up with their own cartridges for other technology stacks.
So it might be worthwhile considering to create a higher-level project
for cartridges. Besides, it might be a good idea to mantion in the
proposal that Texo is a cartridge. 3) Did you consider writing a
textual DSL for Texo? Using Xtext, it is quite easy to create usable
textual DSLs in short time.
Peter
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
Re: [Announce] Texo project proposal: EMF technology for web application development environments [message #118682 is a reply to message #118671] Wed, 16 April 2008 08:05 Go to previous messageGo to next message
Hi Peter,
Thanks for your feedback, it surely is an interesting topic, see my comments below.
gr. Martin
Peter Friese wrote:
> Hi Martin,
MT>> Yes adding other target platforms (like rcp) is great. But (if I understand your remark
correctly) the idea of the Texo project is not to define a common server side for different ui's.
The idea is to generate apps which fit into the standard way of working as is common in the target
environment. So a rcp app would/could probably have a different server side then a spring web app. A
common server side for different ui's is a pretty large topic (I think e4 is also covering this)
Texo specifically talks about web apps to have a first focus. And to be honest, also because that is
were my main expertise is. But I can see (as you) that there are many opportunities there for
following a generative approach.
MT>> It all depends on the terminology ofcourse. What I understand from cartridges is that they are
more like a set of common templates. The Texo proposal both discusses templates as well extending
the model with ui-annotations and some tooling around it. The integration with Eclipse is an
important topic. So I am not sure if the word cartridge would completely cover the Texo proposal.
Regarding your other remark about creating a higher-level project for cartridges. I can see that
there is room for such a project which allows you to easily plugin your own cartridges/templates
using for example eclipse extension points. Or is this maybe something which can be done as part of
the ecoretools project?
MT>> Yes I thought about that. There are some separate ideas to start a project to define a ui-model
(and dsl) for describing ui's. My idea for Texo is first to use annotations in the model and
implement specific ui-model views in templates (a view is for example a selection grid). When the
ui-model initiatives is more clear and the related dsl language has been created then my current
idea is to plug this dsl into texo to drive the generation. My expectation is that many templates
can be re-used then. So the answer is yes I thought about that but I see this as a next step because
others are thinking about a ui-model.
The goal of the Texo project (as I proposed it) is to make a generative and template-oriented
development approach available to programmers who are not familiar with model-driven development.
Afaics and my experience is that there are still many and many developers out there who have not had
any experience with model-driven development (who have never heard of EMF for example). Imho these
developers can benefit from using a set of simple-to-use (but function-rich) tools and templates.
> Peter
The Netherlands
Re: [Announce] Texo project proposal: EMF technology for web application development environments [message #130159 is a reply to message #117181] Tue, 14 October 2008 12:26 Go to previous messageGo to next message
Originally posted by: zzhangh.cn.ibm.com
Hi Martin,
I'm very interested in this component, when will we be able to try it?
> Martin Taal
Re: [Announce] Texo project proposal: EMF technology for web application development environments [message #130172 is a reply to message #130159] Tue, 14 October 2008 12:52 Go to previous message
Hi Hao,
I worked on Texo before the summer but I have been very busy since then. My new target date is
EclipseCon next year. My goal is to release a first version before that.
I feel akward for the delay but my normal work, Teneo and some CDO work has kept me too busy.
gr. Martin
Hao Zhang wrote:
> Hi Martin,
>> use components currently present in the EMF, EMFT, M2T projects.
>> Martin Taal
The Netherlands
Cell: +31 (0)6 288 48 943
Re: [Announce] Texo project proposal: EMF technology for web application develop [message #616100 is a reply to message #117181] Mon, 07 April 2008 18:31 Go to previous message
Hi Martin,
Raghu Srinivasan
Re: [Announce] Texo project proposal: EMF technology for web application develop [message #616102 is a reply to message #117195] Tue, 08 April 2008 03:27 Go to previous message
Hi Raghu,
gr. Martin
> Hi Martin,
> Thanks
> Raghu Srinivasan
The Netherlands
Re: [Announce] Texo project proposal: EMF technology for web application development environments [message #617774 is a reply to message #117181] Wed, 16 April 2008 07:02 Go to previous message
Hi Martin,
Peter
Re: [Announce] Texo project proposal: EMF technology for web application development environments [message #617777 is a reply to message #118671] Wed, 16 April 2008 08:05 Go to previous message
Hi Peter,
gr. Martin
Peter Friese wrote:
> Hi Martin,
> Peter
The Netherlands
Re: [Announce] Texo project proposal: EMF technology for web application development environments [message #620347 is a reply to message #117181] Tue, 14 October 2008 12:26 Go to previous message
Hi Martin,
> Martin Taal
Re: [Announce] Texo project proposal: EMF technology for web application development environments [message #620348 is a reply to message #130159] Tue, 14 October 2008 12:52 Go to previous message
Hi Hao,
gr. Martin
Hao Zhang wrote:
> Hi Martin,
>> Martin Taal
The Netherlands
Previous Topic:[EMF Compare] Infos about the planned "patch/changeset model" feature?
Next Topic:[EMF Compare] Comparing 2 XML schemas
Current Time: Sat Jul 26 09:56:03 EDT 2025
Powered by FUDForum. Page generated in 0.11660 seconds
