Home » Archived » Test and Performance Tools Platform (TPTP) » RAServer startup - Fileserver class not found
RAServer startup - Fileserver class not found [message #10674] Sat, 19 March 2005 16:17 Go to next message
Originally posted by: jeffperry_2003.yahoo.com
I am having trouble getting RAServer from TPTP version 4.0.0
(TPTP-4.0-200503171458) to work.
The problem seems to be a class not found error for FileServer while
starting RAServer. (Also as a side question - I'm not sure what to do with
the native logging package which is also on that download page - the file
it includes seems to be already includeded in one of the other TPTP
packages - is this extra file a patched newer version perhaps??? If so, it
would be helpful if the docs mentioned this)
After consulting the archives - I see no mention of this problem.
I have checked my setup several times and can't find the cause.
It's probably something simple, but I'd appreciate some advice on how to
get this working.
My setup:
Fedora Core 3
Java sdk 1.4.2_06
Eclipse 3.1M5 I20050219-1500
(downloaded by following the link on the TPTP page)
(w/listed requirements for TPTP installed by downloading from links on
TPTP page and unzipping into the eclipse directory)
LD_LIBRARY_PATH is not being set in my .bashrc file and ...
I added a line to .bashrc to source the following script
# JAVA_HOME needed for JBOSS - fix path so this java found first instead
of gcj
version from gcc installed by FC3
export JAVA_HOME="/usr/java/j2sdk1.4.2_06/jre"
export JAVABIN="$JAVA_HOME/bin"
export PATH="$JAVABIN:$PATH"
# Setup for Eclipse 3.1 RASERVER AgentController
# used by TPTP eclipse profiling tools
export
LD_LIBRARY_PATH=" /usr/java/j2sdk1.4.2_06/jre/lib/i386/server:/usr/java/j2sdk1 .4.2_06/jre/lib/i386 "
# The name RASERVER_HOME is important to the RAS server
# it needs this env var
export RASERVER_HOME="/opt/eclipse3.1-tptp-raserver"
export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:$RASERVER_HOME/lib"
export PATH="$RASERVER_HOME/bin:$PATH"
I did run SetConfig from the RAS bin dir.
When I run RAServer as me (NO NEED TO RUN AS ROOT) I get the following
messages: (in short it can't find Java classes that are in the RAS plugins
directory - I have also included my generated serviceconfig.xml file below)
java.lang.NoClassDefFoundError:
org/eclipse/hyades/internal/execution/file/FileServer
What am I missing?
Thanks in advance for the assistance!
Here is my serviceconfig.xml file:
<AgentControllerConfiguration activeConfiguration="default"
loggingDetail="LOW"
loggingLevel="INFORMATION" port="10002" securedPort="10003"
version="4.0.0" filePort="10005" processPolling="true"
jvm="/usr/java/j2sdk1.4.2_06/jre/lib/i386/server/libjvm.so" >
<AgentControllerEnvironment configuration="default">
<Variable name="JAVA_PATH"
value="/usr/java/j2sdk1.4.2_06/jre/bin/java" position="replace"/>
<Variable name="RASERVER_HOME"
value="/opt/eclipse3.1-tptp-raserver" position="replace"/>
<Variable name="PLUGINS_HOME"
value="%RASERVER_HOME%/plugins" position="replace"/>
<Variable name="LD_LIBRARY_PATH"
value="%RASERVER_HOME%/lib" position="prepend"/>
<Variable name="SYS_TEMP_DIR" value="/tmp"
<Variable name="LOCAL_AGENT_TEMP_DIR"
value="%SYS_TEMP_DIR%" position="replace"/>
<Variable
name="CLASSPATH_ORG_APACHE_JAKARTA_COMMONS_LOGGING"
value=" %PLUGINS_HOME%/org.apache.jakarta_commons_logging_1.0.3/comm ons-logging.jar "
position="append"/>
<Variable name="CLASSPATH_ORG_ECLIPSE_CORE_RUNTIME"
position="append"
value="%PLUGINS_HOME%/org.eclipse.core.runtime_3.1.0/runtime.jar "/>
<Variable name="CLASSPATH_ORG_ECLIPSE_EMF_COMMON"
value=" %PLUGINS_HOME%/org.eclipse.emf.common_2.1.0/runtime/common.j ar "
position="append"/>
<Variable name="CLASSPATH_ORG_ECLIPSE_EMF_ECORE"
value=" %PLUGINS_HOME%/org.eclipse.emf.ecore_2.1.0/runtime/ecore.jar "
position="append"/>
<Variable name="CLASSPATH_ORG_ECLIPSE_EMF_ECORE_XMI"
position="append"
value=" %PLUGINS_HOME%/org.eclipse.emf.ecore.xmi_2.1.0/runtime/ecore .xmi.jar "/>
<Variable
name="CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_MODELS" position="append"
value=" %PLUGINS_HOME%/org.eclipse.tptp.platform.models/tptp-models. jar "/>
<Variable name="CLASSPATH_ORG_JUNIT" position="append"
value="%PLUGINS_HOME%/org.junit_3.8.1/junit.jar"/>
</AgentControllerEnvironment>
<Application configuration="default" executable="java.exe"
path="%JAVA_PATH%" location="%SYS_TEMP_DIR%"/>
<Hosts configuration="default">
<Allow host="LOCAL"/>
</Hosts>
<Plugin path="%PLUGINS_HOME%"/>
</AgentControllerConfiguration>
Re: RAServer startup - Fileserver class not found [message #11208 is a reply to message #10674] Mon, 21 March 2005 09:51 Go to previous message
Thanks for reporting this problem. I have confirmed this problem and
captured this bug under bugzilla 88639.
For a temporary workaround, you can do the following before starting up
RAServer
export
CLASSPATH=$CLASSPATH:$RASERVER_HOME/plugins/org.eclipse.hyad es.execution_4.0
..0/hexcore.jar
export
..0/hexl.jar
export
..0/hexr.jar
export
CLASSPATH=$CLASSPATH:$RASERVER_HOME/plugins/org.eclipse.tptp .platform.collec
tion.framework_4.0.0/hcframe.jar
Samson
"Jeff Perry" <jeffperry_2003@yahoo.com> wrote in message
news:255f372e9b25f2f5fa32a468587b613e$1@www.eclipse.org...
> get this working.
> My setup:
> Fedora Core 3
> Java sdk 1.4.2_06
> of gcj
> export
LD_LIBRARY_PATH="/usr/java/j2sdk1.4.2_06/jre/lib/i386/server:/usr/java/j2sdk
1.4.2_06/jre/lib/i386"
below)
> What am I missing?
> loggingDetail="LOW"
> <Variable
ng.jar"
> position="append"/>
> position="append"
> position="append"/>
> position="append"/>
> position="append"
> <Variable
> </Hosts>
Previous Topic:Branch and line coverage using Hyades
Next Topic:How can I perform logging from within a HyadesTestCase?
Current Time: Sat Jul 26 02:30:09 EDT 2025
Powered by FUDForum. Page generated in 0.03513 seconds
