Home » Archived » BIRT » Diplaying image or chart report in JSP or HTML
Diplaying image or chart report in JSP or HTML [message #116996] Thu, 26 January 2006 02:18 Go to next message
Originally posted by: sri.gmail.com
hi
i am trying to diaply image or chart report which is designed using birt
report designer.
i used following code to generate HTML output
EngineConfig config = new EngineConfig( );
config.setEngineHome( "E:\\birt" );
HTMLEmitterConfig hc = new HTMLEmitterConfig( );
HTMLCompleteImageHandler imageHandler = new HTMLCompleteImageHandler( );
hc.setImageHandler( imageHandler );
config.setEmitterConfiguration( HTMLRenderOption.OUTPUT_FORMAT_HTML, hc );
ReportEngine engine = new ReportEngine( config );
IReportRunnable report = null;
try{
report = engine.openReportDesign( name );
}catch ( EngineException e ){
System.err.println( "Report " + name + " not found!\n" );
engine.destroy( );
return;
if ( showInfo ) {
showReportInfo( engine, report );
if ( format != null ){
parseParams( engine, report, params );
IRunAndRenderTask task = engine.createRunAndRenderTask( report );
HTMLRenderOption options = new HTMLRenderOption( );
options.setOutputFormat( format );
String output = name.replaceFirst( ".rptdesign", "." + format );
options.setOutputFileName( output );
task.setRenderOption( options );
task.setParameterValues( params );
try{
task.run( );
catch ( EngineException e1 ) {
System.err.println( "Report " + name + " run failed.\n" );
System.err.println( e1.toString( ) );
engine.destroy( );
This code is working fine with Simple reports which contain Tables but its
not working fine with reports which contain images or charts
this code is generating .html file for image reports but image is not
printing.
and aslo i am not clear with the following comments
// HTML reports can have embedded images or charts. Set up the
configuration
// required to write these into a directory in the output directory.
// The HTMLCompleteImageHandler is one provided by BIRT for this purpose.
// Your application can create a customized version to provide alternative
// ways to handle images.
Soultion is very URGENT PLEASE HELP ME REGARDING THIS
SRI
Re: Diplaying image or chart report in JSP or HTML [message #117300 is a reply to message #116996] Thu, 26 January 2006 06:43 Go to previous messageGo to next message
sri,
Try
HTMLRenderContext renderContext = new HTMLRenderContext();
renderContext.setImageDirectory("image");
HashMap contextMap = new HashMap();
contextMap.put( HTMLRenderContext.CONTEXT_NAME, renderContext );
task.setContext( contextMap );
right before
Jason Weathersby
BIRT PMC
"sri" <sri@gmail.com> wrote in message
news:3d827dd4068b74c15a3791b38c0e80ae$1@www.eclipse.org...
> hi
> report designer.
> try{
> engine.destroy( );
> return;
> if ( showInfo ) {
> try{
> task.run( );
> engine.destroy( );
> printing.
> configuration
> SRI
Re: Diplaying image or chart report in JSP or HTML [message #117418 is a reply to message #117300] Thu, 26 January 2006 07:15 Go to previous messageGo to next message
hi thanks for u r reply
but i have ask one thing in this code
i searched in the HTMLTenderContext for the final varible CONTEXT_NAME
BUT ITS not there in both birt 1.0.1 and 2.0.0
so can u hlep me regarding this
HTMLRenderContext.CONTEXT_NAME wether its a String or final varibale of
HTMLRenderContext class
Solution is Urgent....
please help me
sri
Re: Diplaying image or chart report in JSP or HTML [message #117430 is a reply to message #117418] Thu, 26 January 2006 07:54 Go to previous messageGo to next message
sri,
Sorry wrong snippet
from ReportRunner.java
if ( format.equalsIgnoreCase( "html" ) )
HTMLRenderContext renderContext = new HTMLRenderContext( );
renderContext.setImageDirectory( "image" ); //$NON-NLS-1$
HashMap appContext = new HashMap( );
appContext.put( EngineConstants.APPCONTEXT_HTML_RENDER_CONTEXT,
renderContext );
task.setAppContext( appContext );
Jason
news:85bb56b969eef8e66980d0735f142d75$1@www.eclipse.org...
> please help me
> sri
Re: Diplaying image or chart report in JSP or HTML [message #118321 is a reply to message #117430] Thu, 26 January 2006 22:40 Go to previous messageGo to next message
hi Jason
could u send me a java program which can display both images/chars and
table reports . i asking about hole program.
solution is urgent
regards
sri
Re: Diplaying image or chart report in JSP or HTML [message #119224 is a reply to message #118321] Fri, 27 January 2006 16:14 Go to previous message
sri,
Did you look at this program?
http://www.eclipse.org/birt/phoenix/deploy/ReportRunner.java
Jason
news:d62963e49d5c3bb2f6ef28041cabb6b5$1@www.eclipse.org...
> hi Jason
> solution is urgent
> regards
> sri
Previous Topic:Need help regarding specifying database usename and password in template(URGENT)
Next Topic:Issue regarding report engine
Current Time: Sun Jul 27 11:01:24 EDT 2025
Powered by FUDForum. Page generated in 0.03580 seconds
