Home » Newcomers » Newcomers » phpeclipse : Error opening http://localhost/prueba/index.ph
phpeclipse : Error opening http://localhost/prueba/index.ph [message #116978] Fri, 11 November 2005 13:22 Go to next message
I am trying to open the page http://localhost/prueba/index.php, and I am
getting an error message:
Not Found
The requested URL /prueba/index.php was not found on this server.
Apache/2.0.52 (Unix) PHP/5.0.5 DAV/2 Server at localhost Port 80
My Eclipse 3.1/PHPEclipse workspace is located at:
/Users/jsn/Documents/workspace/php
So the page developped is at
/Users/jsn/Documents/workspace/php/prueba/index.php
I usually open my php5 web pages at:http://localhost/~jsn/
What do I have to change in the Apache httpd.conf file, to be able to open
the page developped with phpeclipse, using
http://localhost/prueba/index.php, and pointing to
/Users/jsn/Documents/workspace/php/prueba/index.php.
jsn
Re: phpeclipse : Error opening http://localhost/prueba/index.ph [message #118346 is a reply to message #116978] Thu, 17 November 2005 12:16 Go to previous message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
You will need to play around with your httpd.conf file so that the
DocumentRoot (or a suitable Alias) matches the root of your PHPEclipse
project.
D.
jose wrote:
> Hi
> Not Found
> open the page developped with phpeclipse, using
> Thanks jsn
Previous Topic:Plug-In Developer Guide Help in PDF
Next Topic:Eclipse Ran REALLY Slow
Current Time: Tue Jul 22 13:04:06 EDT 2025
Powered by FUDForum. Page generated in 0.07409 seconds
