Home » Newcomers » Newcomers » no output after build/complie
no output after build/complie [message #116907] Fri, 11 November 2005 09:00 Go to next message
Originally posted by: marquis.altern.org
hi,
I use eclipse
Version: 3.1.1
Build id: M20050929-0840.
My problem is that I get no output after a build. There must be a way to
know whether the build failed or not, and what are the errors; but here
the "build project" dialog closes and after that, nothing.
I also, sometimes I click "build projects" and nothing happens.
I am sure there must be a way to know what's happining, similar to the
compiler output at the command line, but I cannot find it.
Thanks for any hint!
Sam
Re: no output after build/complie [message #116947 is a reply to message #116907] Fri, 11 November 2005 11:30 Go to previous messageGo to next message
Originally posted by: eclipse3.rizzoweb.com
marquis wrote:
> hi,
> I use eclipse
> Version: 3.1.1
See my response to the thread titled "Building in Eclipse" - bottom line
is that you really should go through the Tutorials and Getting Started
guides in the Help.
Eric
Re: no output after build/complie [message #117324 is a reply to message #116947] Sun, 13 November 2005 03:34 Go to previous message
I think you don't have the problems view open in the bottom pane. Hence
you are not getting to know anything.
Previous Topic:very annoying error message
Next Topic:Exproting plugin
Current Time: Mon Jul 14 13:44:05 EDT 2025
Powered by FUDForum. Page generated in 0.05545 seconds
