Home » Archived » BIRT » Custom Template not in 2.0?
Custom Template not in 2.0? [message #116873] Wed, 25 January 2006 17:04 Go to next message
So I was looking at the NewReportWizard and noticed that there were
entries for Custom Template choices, via WizardCustomTemplatePage.java
but all the code is commented out. Was the intent to support user
provided templates and the feature didn't make 2.0? Note, I filed an
enhancement request a while back for this support 93996 ( I would check
status but bugzilla is offline at the moment).
Any ideas? Thanks for update.
Re: Custom Template not in 2.0? [message #116885 is a reply to message #116873] Wed, 25 January 2006 19:49 Go to previous messageGo to next message
Mike:
Custom report template is supported in BIRT 2.0. You can covert any report
design into a report template, and publish to the report template folder,
then it will be available for use for new report design.
The old commented out in the NewReportWizard is out of date. The template
implementation didn't use that design.
-wenbin
"Mike Boyersmith" <mjboyers@us.ibm.com> wrote in message
news:dr8sl6$ked$1@utils.eclipse.org...
Re: Custom Template not in 2.0? [message #117643 is a reply to message #116885] Thu, 26 January 2006 12:11 Go to previous messageGo to next message
Wenbin, Thanks for the quick reply!
A follow up question, whats the flow to convert a rptdesign file to a
template? I looked under context menu "export", and also looked in the
report designer for "export to" or "convert to" options but I don't see
them, any ideas?
thanks for your help
- Mike
Wenbin He wrote:
> Mike:
> -wenbin
Re: Custom Template not in 2.0? [message #117959 is a reply to message #117643] Thu, 26 January 2006 15:12 Go to previous messageGo to next message
BIRT template and design share the same schema. You can simple copy or
rename a report design to a report template. You find more information on
how the template works in BPS speification document.
-wenbin
news:dravrq$a2g$1@utils.eclipse.org...
> them, any ideas?
> - Mike
> Wenbin He wrote:
> > Mike:
report
folder,
template
> > -wenbin
Re: Custom Template not in 2.0? [message #118198 is a reply to message #117959] Thu, 26 January 2006 18:29 Go to previous messageGo to next message
Another question for ya, How do I contribute my templates to the "new
Report" wizard. Is there an extension point I can use or something like
that currently?
> -wenbin
>>them, any ideas?
>>- Mike
>>Wenbin He wrote:
>>>Mike:
> report
> folder,
> template
>>>-wenbin
Re: Custom Template not in 2.0? [message #118268 is a reply to message #118198] Thu, 26 January 2006 20:26 Go to previous messageGo to next message
You can publish a template to the BIRT template folder, which will be picked
up by the new report wizard automatically.
-wenbin
news:drbm0g$emn$2@utils.eclipse.org...
> that currently?
on
> > -wenbin
> >>them, any ideas?
> >>- Mike
> >>Wenbin He wrote:
> >>>Mike:
> > report
> > folder,
> > template
> >>>-wenbin
check
Re: Custom Template not in 2.0? [message #118294 is a reply to message #118268] Thu, 26 January 2006 21:29 Go to previous messageGo to next message
You set up the Template folder in the BIRT -- Template page of the Eclipse
Preferences dialog.
Jane Tatchell
BIRT documentation lead
"Wenbin He" <whe@actuate.com> wrote in message
news:drbsoo$nh9$1@utils.eclipse.org...
> picked
> -wenbin
>> that currently?
> on
>> > -wenbin
>> >>them, any ideas?
>> >>- Mike
>> >>Wenbin He wrote:
>> >>>Mike:
>> > report
>> > folder,
>> > template
>> >>>-wenbin
> check
Re: Custom Template not in 2.0? [message #118911 is a reply to message #118294] Fri, 27 January 2006 12:13 Go to previous message
Thank you Jane and Wenbin thats what I was missing.
> Preferences dialog.
Previous Topic:class loading constraint violated
Next Topic:Building a library of templates
Current Time: Sun Aug 31 06:53:35 EDT 2025
Powered by FUDForum. Page generated in 0.14489 seconds
