publishing error [message #116792] |
Wed, 06 July 2005 11:54 |
I am using jboss4.0.2 with WTP M5, The server configaration is working
fine, except when I tried to publish the application on server, eventhough
it gets deployed, I get a pop saying it could not publish. Following is
the stack trace, Monitor is the context path of the appliation. I
appreicate any help.
!ENTRY org.eclipse.wst.server.core 4 0 2005-07-06 11:47:05.274
!MESSAGE Publishing results
!SUBENTRY 1 org.eclipse.wst.server.core 0 0 2005-07-06 11:47:05.274
!MESSAGE Monitor published successfully
!SUBENTRY 1 org.eclipse.wst.server.core 4 0 2005-07-06 11:47:05.290
!MESSAGE Could not publish to the server.
!STACK 0
org.eclipse.jst.server.generic.core.internal.GenericServerBe haviour.r
emoveFromServer(GenericServerBehaviour.java:114)
org.eclipse.jst.server.generic.core.internal.GenericServerBe haviour.p
ublishModule(GenericServerBehaviour.java:95)
org.eclipse.wst.server.core.model.ServerBehaviourDelegate.pu blishModu
le(ServerBehaviourDelegate.java:633)
les(ServerBehaviourDelegate.java:686)
org.eclipse.wst.server.core.model.ServerBehaviourDelegate.pu blish(Ser
verBehaviourDelegate.java:584)
org.eclipse.wst.server.core.internal.Server.doPublish(Server .java:684
org.eclipse.wst.server.core.internal.Server.publish(Server.j ava:671)
org.eclipse.wst.server.core.internal.PublishServerJob.run(Pu blishServ
erJob.java:140)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
FUDForum. Page generated in 0.03920 seconds
