not able to use Vidusl Editor [message #116535] |
Wed, 01 February 2006 07:37  |
Originally posted by: shaper.web.de
I tried to install Visual Editor.
First manually, then with the automatic update.
I also installed PDE, but it still DOES NOT WORK.
There is no option to create a so-called "Visual Class".
(The list of installed Plug-Ins lists the Visual Editor installed
correctly and there are no Pulign-Problems detected)
I don't know where to find any help, I searched Google but all information
I found was that it often does not work.
Sorry, I can't go on with Eclipse, I've given up.
I wanted to give Eclipse a chance, I already developed with Oracle's
JDeveloper, but I was not successful.
Any help would be greatly appreciated.
Thank You.
Sven
Re: not able to use Visual Editor [message #116548 is a reply to message #116541] |
Wed, 01 February 2006 08:43  |
I deleted all of the VE stuff und updated again through the update option.
Now it works fine. Great!!
I think the Visual Editor should be packaged together with Eclipse by
default.
Best regards
Re: not able to use Visual Editor [message #611925 is a reply to message #116541] |
default.
Best regards
FUDForum. Page generated in 0.07433 seconds
