Home » Eclipse Projects » Equinox » P2 always strange match error. How to update P2?
P2 always strange match error. How to update P2? [message #116513] Tue, 26 August 2008 05:49 Go to next message
Hi there,
don't know if this is a bug or feature:
Whenever I try to update enything with P2, I get the following error:
Cannot complete the request. See the details.
Cannot find a solution satisfying the following requirements
Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.jst.jsf.core/[1.1.0.v2 0080528,1.1.0.v20080528]].
This error is the same for every component I try to update. Is this a
bug of P2? How can I update P2 without using P2?
The version I have is:
org.eclipse.equinox.p2.engine 1.0.0.v20080522-1735
Hauke
Re: P2 always strange match error. How to update P2? [message #116525 is a reply to message #116513] Tue, 26 August 2008 06:01 Go to previous messageGo to next message
Mine always reports:
-------8<-------
org.eclipse.equinox.p2.iu/javax.wsdl/[1.4.0.v200806030407,1. 4.0.v200806030407]].
-------8<-------
No matter what I try to install via the update manager.
Tom
Hauke Fuhrmann schrieb:
> Hi there,
> Cheers,
> Hauke
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: P2 always strange match error. How to update P2? [message #116531 is a reply to message #116525] Tue, 26 August 2008 10:08 Go to previous messageGo to next message
On the face of it looks like both of you are trying to update something from
Web Tools and it appears one of the features is mis-specifying it's
requirements. Can you guys provide more details on what's installed and what
you're trying to do?
Thanks.
-Simon
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:g90k95$heo$1@build.eclipse.org...
> -------8<-------
> -------8<-------
> Tom
>> Hi there,
>> Cheers,
>> Hauke
Re: P2 always strange match error. How to update P2? [message #116543 is a reply to message #116531] Tue, 26 August 2008 11:10 Go to previous messageGo to next message
--------------090007020700080606040500
Content-Type: text/plain; charset=ISO-8859-1
I've a standard Ganymede install with especially lot of modeling stuff
and Subversive. In the "Installed Software" there are no Web Tools
listed at all.
I get the error if I open the P2 Gui and simply press the "update"
button. Then this error is displayed for every component to be updated,
e.g. "Graphical Modeling Framework SDK" or "Subversive SVN Connectors"
or "Graphical Modeling Framework Documentation" and every other package
that can be updated.
This also happens if I select *only one* of the items in the "Installed
Software" tab and try to update only that.
As I'm not familiar at all with p2, I don't know what you need to see of
my configuration. I have attached my "bundles.info", which I understand
to hold all plugins that are installed...
Hauke
name="bundles.info"
Content-Disposition: inline;
filename="bundles.info"
com.ibm.icu,3.8.1.v20080402,file:plugins/com.ibm.icu_3.8.1.v 20080402.jar,4,false
com.jcraft.jsch,0.1.37.v200803061811,file:plugins/com.jcraft .jsch_0.1.37.v200803061811.jar,4,false
javax.activation,1.1.0.v200804101140,file:plugins/javax.acti vation_1.1.0.v200804101140.jar,4,false
javax.mail,1.4.0.v200804091730,file:plugins/javax.mail_1.4.0 .v200804091730.jar,4,false
javax.servlet,2.4.0.v200803061910,file:plugins/javax.servlet _2.4.0.v200803061910.jar,4,false
javax.servlet.jsp,2.0.0.v200803061910,file:plugins/javax.ser vlet.jsp_2.0.0.v200803061910.jar,4,false
javax.wsdl,1.4.0.v200806030407,file:plugins/javax.wsdl_1.4.0 .v200806030407.jar,4,false
javax.wsdl,1.5.1.v200806030408,file:plugins/javax.wsdl_1.5.1 .v200806030408.jar,4,false
javax.xml,1.3.4.v200806030440,file:plugins/javax.xml_1.3.4.v 200806030440.jar,4,false
javax.xml.rpc,1.1.0.v200806030420,file:plugins/javax.xml.rpc _1.1.0.v200806030420/,4,false
javax.xml.soap,1.2.0.v200806030421,file:plugins/javax.xml.so ap_1.2.0.v200806030421/,4,false
net.sourceforge.lpg.lpgjavaruntime,1.1.0.v200803061910,file: plugins/net.sourceforge.lpg.lpgjavaruntime_1.1.0.v2008030619 10.jar,4,false
org.apache.ant,1.7.0.v200803061910,file:plugins/org.apache.a nt_1.7.0.v200803061910/,4,false
org.apache.axis,1.4.0.v200806030120,file:plugins/org.apache. axis_1.4.0.v200806030120/,4,false
org.apache.batik.bridge,1.6.0.v200805290154,file:plugins/org .apache.batik.bridge_1.6.0.v200805290154.jar,4,false
org.apache.batik.css,1.6.0.v200805290154,file:plugins/org.ap ache.batik.css_1.6.0.v200805290154.jar,4,false
org.apache.batik.dom,1.6.0.v200805290154,file:plugins/org.ap ache.batik.dom_1.6.0.v200805290154.jar,4,false
org.apache.batik.dom.svg,1.6.0.v200805290154,file:plugins/or g.apache.batik.dom.svg_1.6.0.v200805290154.jar,4,false
org.apache.batik.ext.awt,1.6.0.v200805290154,file:plugins/or g.apache.batik.ext.awt_1.6.0.v200805290154.jar,4,false
org.apache.batik.extension,1.6.0.v200805290154,file:plugins/ org.apache.batik.extension_1.6.0.v200805290154.jar,4,false
org.apache.batik.parser,1.6.0.v200805290154,file:plugins/org .apache.batik.parser_1.6.0.v200805290154.jar,4,false
org.apache.batik.pdf,1.6.0.v200806031500,file:plugins/org.ap ache.batik.pdf_1.6.0.v200806031500.jar,4,false
org.apache.batik.svggen,1.6.0.v200805290154,file:plugins/org .apache.batik.svggen_1.6.0.v200805290154.jar,4,false
org.apache.batik.swing,1.6.0.v200805290154,file:plugins/org. apache.batik.swing_1.6.0.v200805290154.jar,4,false
org.apache.batik.transcoder,1.6.0.v200805290154,file:plugins /org.apache.batik.transcoder_1.6.0.v200805290154.jar,4,false
org.apache.batik.util,1.6.0.v200805290154,file:plugins/org.a pache.batik.util_1.6.0.v200805290154.jar,4,false
org.apache.batik.util.gui,1.6.0.v200805290154,file:plugins/o rg.apache.batik.util.gui_1.6.0.v200805290154.jar,4,false
org.apache.batik.xml,1.6.0.v200805290154,file:plugins/org.ap ache.batik.xml_1.6.0.v200805290154.jar,4,false
org.apache.cactus,1.7.2.v200805140145,file:plugins/org.apach e.cactus_1.7.2.v200805140145/,4,false
org.apache.commons.codec,1.3.0.v20080530-1600,file:plugins/o rg.apache.commons.codec_1.3.0.v20080530-1600.jar,4,false
org.apache.commons.discovery,0.2.0.v200806030120,file:plugin s/org.apache.commons.discovery_0.2.0.v200806030120/,4,false
org.apache.commons.el,1.0.0.v200803061811,file:plugins/org.a pache.commons.el_1.0.0.v200803061811.jar,4,false
org.apache.commons.httpclient,3.1.0.v20080605-1935,file:plug ins/org.apache.commons.httpclient_3.1.0.v20080605-1935.jar,4 ,false
org.apache.commons.lang,2.3.0.v200803061910,file:plugins/org .apache.commons.lang_2.3.0.v200803061910.jar,4,false
org.apache.commons.logging,1.0.4.v200803061811,file:plugins/ org.apache.commons.logging_1.0.4.v200803061811.jar,4,false
org.apache.commons.logging,1.0.4.v20080605-1930,file:plugins /org.apache.commons.logging_1.0.4.v20080605-1930.jar,4,false
org.apache.jasper,5.5.17.v200803061811,file:plugins/org.apac he.jasper_5.5.17.v200803061811.jar,4,false
org.apache.log4j,1.2.13.v200806030600,file:plugins/org.apach e.log4j_1.2.13.v200806030600.jar,4,false
org.apache.lucene,1.9.1.v200803061811,file:plugins/org.apach e.lucene_1.9.1.v200803061811.jar,4,false
org.apache.lucene.analysis,1.9.1.v200803061811,file:plugins/ org.apache.lucene.analysis_1.9.1.v200803061811.jar,4,false
org.apache.wsil4j,1.0.0.v200806040330,file:plugins/org.apach e.wsil4j_1.0.0.v200806040330.jar,4,false
org.apache.xerces,2.9.0.v200805270400,file:plugins/org.apach e.xerces_2.9.0.v200805270400.jar,4,false
org.apache.xml.resolver,1.2.0.v200806030312,file:plugins/org .apache.xml.resolver_1.2.0.v200806030312.jar,4,false
org.apache.xml.serializer,2.7.1.v200806030322,file:plugins/o rg.apache.xml.serializer_2.7.1.v200806030322.jar,4,false
org.eclipse.ant.core,3.2.0.v20080529,file:plugins/org.eclips e.ant.core_3.2.0.v20080529.jar,4,false
org.eclipse.ant.ui,3.3.0.v20080529,file:plugins/org.eclipse. ant.ui_3.3.0.v20080529.jar,4,false
org.eclipse.birt.chart.engine,2.3.0.v20080606,file:plugins/o rg.eclipse.birt.chart.engine_2.3.0.v20080606.jar,4,false
org.eclipse.birt.core,2.3.0.v20080606,file:plugins/org.eclip se.birt.core_2.3.0.v20080606.jar,4,false
org.eclipse.cdt,5.0.0.200806171202,file:plugins/org.eclipse. cdt_5.0.0.200806171202/,4,false
org.eclipse.cdt.core,5.0.0.200806171202,file:plugins/org.ecl ipse.cdt.core_5.0.0.200806171202.jar,4,false
org.eclipse.cdt.core.linux,5.0.0.200806171202,file:plugins/o rg.eclipse.cdt.core.linux_5.0.0.200806171202.jar,4,false
org.eclipse.cdt.core.linux.x86,5.0.0.200806171202,file:plugi ns/org.eclipse.cdt.core.linux.x86_5.0.0.200806171202.jar,4,f alse
org.eclipse.cdt.debug.core,5.0.0.200806171202,file:plugins/o rg.eclipse.cdt.debug.core_5.0.0.200806171202.jar,4,false
org.eclipse.cdt.debug.mi.core,5.0.0.200806171202,file:plugin s/org.eclipse.cdt.debug.mi.core_5.0.0.200806171202.jar,4,fal se
org.eclipse.cdt.debug.mi.ui,5.0.0.200806171202,file:plugins/ org.eclipse.cdt.debug.mi.ui_5.0.0.200806171202.jar,4,false
org.eclipse.cdt.debug.ui,5.0.0.200806171202,file:plugins/org .eclipse.cdt.debug.ui_5.0.0.200806171202.jar,4,false
org.eclipse.cdt.doc.user,5.0.0.200806171202,file:plugins/org .eclipse.cdt.doc.user_5.0.0.200806171202/,4,false
org.eclipse.cdt.launch,5.0.0.200806171202,file:plugins/org.e clipse.cdt.launch_5.0.0.200806171202.jar,4,false
org.eclipse.cdt.make.core,5.0.0.200806171202,file:plugins/or g.eclipse.cdt.make.core_5.0.0.200806171202.jar,4,false
org.eclipse.cdt.make.ui,5.0.0.200806171202,file:plugins/org. eclipse.cdt.make.ui_5.0.0.200806171202.jar,4,false
org.eclipse.cdt.managedbuilder.core,5.0.0.200806171202,file: plugins/org.eclipse.cdt.managedbuilder.core_5.0.0.2008061712 02.jar,4,false
org.eclipse.cdt.managedbuilder.gnu.ui,5.0.0.200806171202,fil e:plugins/org.eclipse.cdt.managedbuilder.gnu.ui_5.0.0.200806 171202.jar,4,false
org.eclipse.cdt.managedbuilder.ui,5.0.0.200806171202,file:pl ugins/org.eclipse.cdt.managedbuilder.ui_5.0.0.200806171202.j ar,4,false
org.eclipse.cdt.mylyn,1.0.0.200806171202,file:plugins/org.ec lipse.cdt.mylyn_1.0.0.200806171202/,4,false
org.eclipse.cdt.mylyn.ui,1.0.0.200806171202,file:plugins/org .eclipse.cdt.mylyn.ui_1.0.0.200806171202.jar,4,false
org.eclipse.cdt.ui,5.0.0.200806171202,file:plugins/org.eclip se.cdt.ui_5.0.0.200806171202.jar,4,false
org.eclipse.compare,3.4.0.I20080528,file:plugins/org.eclipse .compare_3.4.0.I20080528.jar,4,false
org.eclipse.core.boot,3.1.100.v20080218,file:plugins/org.ecl ipse.core.boot_3.1.100.v20080218.jar,4,false
org.eclipse.core.commands,3.4.0.I20080509-2000,file:plugins/ org.eclipse.core.commands_3.4.0.I20080509-2000.jar,4,false
org.eclipse.core.contenttype,3.3.0.v20080414,file:plugins/or g.eclipse.core.contenttype_3.3.0.v20080414.jar,4,false
org.eclipse.core.databinding,1.1.0.I20080527-2000,file:plugi ns/org.eclipse.core.databinding_1.1.0.I20080527-2000.jar,4,f alse
org.eclipse.core.databinding.beans,1.1.0.I20080508-2000a,fil e:plugins/org.eclipse.core.databinding.beans_1.1.0.I20080508 -2000a.jar,4,false
org.eclipse.core.expressions,3.4.0.v20080530-1508,file:plugi ns/org.eclipse.core.expressions_3.4.0.v20080530-1508.jar,4,f alse
org.eclipse.core.filebuffers,3.4.0.v20080529-1300,file:plugi ns/org.eclipse.core.filebuffers_3.4.0.v20080529-1300.jar,4,f alse
org.eclipse.core.filesystem,1.2.0.v20080421-1805,file:plugin s/org.eclipse.core.filesystem_1.2.0.v20080421-1805.jar,4,fal se
org.eclipse.core.filesystem.linux.x86,1.2.0.v20071207,file:p lugins/org.eclipse.core.filesystem.linux.x86_1.2.0.v20071207 .jar,4,false
org.eclipse.core.jobs,3.4.0.v20080512,file:plugins/org.eclip se.core.jobs_3.4.0.v20080512.jar,4,false
org.eclipse.core.net,1.1.0.I20080529,file:plugins/org.eclips e.core.net_1.1.0.I20080529.jar,4,false
org.eclipse.core.net.linux.x86,1.0.0.I20080521,file:plugins/ org.eclipse.core.net.linux.x86_1.0.0.I20080521.jar,4,false
org.eclipse.core.resources,3.4.0.v20080528-1613,file:plugins /org.eclipse.core.resources_3.4.0.v20080528-1613.jar,4,false
org.eclipse.core.resources.compatibility,3.4.0.v20071204,fil e:plugins/org.eclipse.core.resources.compatibility_3.4.0.v20 071204.jar,4,false
org.eclipse.core.runtime,3.4.0.v20080512,file:plugins/org.ec lipse.core.runtime_3.4.0.v20080512.jar,4,true
org.eclipse.core.runtime.compatibility,3.2.0.v20071008,file: plugins/org.eclipse.core.runtime.compatibility_3.2.0.v200710 08.jar,4,false
org.eclipse.core.runtime.compatibility.auth,3.2.100.v2007050 2,file:plugins/org.eclipse.core.runtime.compatibility.auth_3 .2.100.v20070502.jar,4,false
org.eclipse.core.runtime.compatibility.registry,3.2.200.v200 70717,file:plugins/org.eclipse.core.runtime.compatibility.re gistry_3.2.200.v20070717/,4,false
org.eclipse.core.variables,3.2.100.v20080529-1300,file:plugi ns/org.eclipse.core.variables_3.2.100.v20080529-1300.jar,4,f alse
org.eclipse.cvs,1.0.100.v20080324,file:plugins/org.eclipse.c vs_1.0.100.v20080324.jar,4,false
org.eclipse.datatools.connectivity,1.1.0.v200805160228,file: plugins/org.eclipse.datatools.connectivity_1.1.0.v2008051602 28.jar,4,false
org.eclipse.datatools.connectivity.console.profile,1.0.0.v20 0805231345,file:plugins/org.eclipse.datatools.connectivity.c onsole.profile_1.0.0.v200805231345.jar,4,false
org.eclipse.datatools.connectivity.db.generic,1.0.0.v2008051 52355,file:plugins/org.eclipse.datatools.connectivity.db.gen eric_1.0..0.v200805152355.jar,4,false
org.eclipse.datatools.connectivity.db.generic.ui,1.0.1.v2008 05152355,file:plugins/org.eclipse.datatools.connectivity.db. generic.ui_1.0.1.v200805152355.jar,4,false
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC, 1.0.0.v200805152355,file:plugins/org.eclipse.datatools.conne ctivity.dbdefinition.genericJDBC_1.0.0.v200805152355.jar,4,f alse
org.eclipse.datatools.connectivity.oda,3.1.2.v200805152355,f ile:plugins/org.eclipse.datatools.connectivity.oda_3.1.2.v20 0805152355.jar,4,false
org.eclipse.datatools.connectivity.oda.consumer,3.1.2.v20080 5230718,file:plugins/org.eclipse.datatools.connectivity.oda. consumer_3.1.2.v200805230718.jar,4,false
org.eclipse.datatools.connectivity.oda.design,3.0.6.v2008051 52355,file:plugins/org.eclipse.datatools.connectivity.oda.de sign_3.0.6.v200805152355.jar,4,false
org.eclipse.datatools.connectivity.oda.design.ui,3.0.6.v2008 05152355,file:plugins/org.eclipse.datatools.connectivity.oda .design.ui_3.0.6.v200805152355.jar,4,false
org.eclipse.datatools.connectivity.oda.flatfile,3.0.6.v20080 5261930,file:plugins/org.eclipse.datatools.connectivity.oda. flatfile_3.0.6.v200805261930.jar,4,false
org.eclipse.datatools.connectivity.oda.flatfile.ui,3.0.6.v20 0805261930,file:plugins/org.eclipse.datatools.connectivity.o da.flatfile.ui_3.0.6.v200805261930.jar,4,false
org.eclipse.datatools.connectivity.oda.profile,3.0.6.v200805 152355,file:plugins/org.eclipse.datatools.connectivity.oda.p rofile_3.0.6.v200805152355.jar,4,false
org.eclipse.datatools.connectivity.oda.template.ui,3.0.6.v20 0805152355,file:plugins/org.eclipse.datatools.connectivity.o da.template.ui_3.0.6.v200805152355.jar,4,false
org.eclipse.datatools.connectivity.sqm.core,1.0.1.v200806041 052,file:plugins/org.eclipse.datatools.connectivity.sqm.core _1.0.1.v200806041052.jar,4,false
org.eclipse.datatools.connectivity.sqm.core.ui,1.1.0.v200806 070326,file:plugins/org.eclipse.datatools.connectivity.sqm.c ore.ui_1.1.0.v200806070326.jar,4,false
org.eclipse.datatools.connectivity.sqm.server.ui,1.1.0.v2008 06050117,file:plugins/org.eclipse.datatools.connectivity.sqm .server.ui_1.1.0.v200806050117.jar,4,false
org.eclipse.datatools.connectivity.ui,1.1.0.v200806040132,fi le:plugins/org.eclipse.datatools.connectivity.ui_1.1.0.v2008 06040132.jar,4,false
org.eclipse.datatools.connectivity.ui.dse,1.1.0.v20080515235 5,file:plugins/org.eclipse.datatools.connectivity.ui.dse_1.1 .0.v200805152355.jar,4,false
org.eclipse.datatools.doc.user,1.6.0.20080606124249,file:plu gins/org.eclipse.datatools.doc.user_1.6.0.20080606124249.jar ,4,false
org.eclipse.datatools.help,1.5.0.v200805152355,file:plugins/ org.eclipse.datatools.help_1.5.0.v200805152355.jar,4,false
org.eclipse.datatools.modelbase.dbdefinition,1.0.0.v20080515 2355,file:plugins/org.eclipse.datatools.modelbase.dbdefiniti on_1.0.0.v200805152355.jar,4,false
org.eclipse.datatools.modelbase.sql,1.0.0.v200805152355,file :plugins/org.eclipse.datatools.modelbase.sql_1.0.0.v20080515 2355.jar,4,false
org.eclipse.datatools.modelbase.sql.edit,1.0.0.v200805152355 ,file:plugins/org.eclipse.datatools.modelbase.sql.edit_1.0.0 .v200805152355.jar,4,false
org.eclipse.datatools.modelbase.sql.query,1.0.1.v20080515235 5,file:plugins/org.eclipse.datatools.modelbase.sql.query_1.0 .1.v200805152355.jar,4,false
org.eclipse.datatools.modelbase.sql.query.edit,1.0.0.v200806 070329,file:plugins/org.eclipse.datatools.modelbase.sql.quer y.edit_1.0.0.v200806070329.jar,4,false
org.eclipse.datatools.modelbase.sql.xml.query,1.0.0.v2008051 52355,file:plugins/org.eclipse.datatools.modelbase.sql.xml.q uery_1.0.0.v200805152355.jar,4,false
org.eclipse.datatools.oda.cshelp,1.0.0.v200805152355,file:pl ugins/org.eclipse.datatools.oda.cshelp_1.0.0.v200805152355.j ar,4,false
org.eclipse.datatools.sqltools.common.ui,1.0.0.v200805152355 ,file:plugins/org.eclipse.datatools.sqltools.common.ui_1.0.0 .v200805152355.jar,4,false
org.eclipse.datatools.sqltools.data.core,1.0.0.v200805152355 ,file:plugins/org.eclipse.datatools.sqltools.data.core_1.0.0 .v200805152355.jar,4,false
org.eclipse.datatools.sqltools.data.ui,1.1.0.v200805310400,f ile:plugins/org.eclipse.datatools.sqltools.data.ui_1.1.0.v20 0805310400.jar,4,false
org.eclipse.datatools.sqltools.db.generic,1.0.0.v20080515235 5,file:plugins/org.eclipse.datatools.sqltools.db.generic_1.0 .0.v200805152355.jar,4,false
org.eclipse.datatools.sqltools.ddlgen.ui,1.0.0.v200805152355 ,file:plugins/org.eclipse.datatools.sqltools.ddlgen.ui_1.0.0 .v200805152355.jar,4,false
org.eclipse.datatools.sqltools.debugger.core,1.0.0.v20080515 2355,file:plugins/org.eclipse.datatools.sqltools.debugger.co re_1.0.0.v200805152355.jar,4,false
org.eclipse.datatools.sqltools.editor.core,1.0.0.v2008051523 55,file:plugins/org.eclipse.datatools.sqltools.editor.core_1 .0.0.v200805152355.jar,4,false
org.eclipse.datatools.sqltools.parsers.sql,1.0.1.v2008051523 55,file:plugins/org.eclipse.datatools.sqltools.parsers.sql_1 .0.1.v200805152355.jar,4,false
org.eclipse.datatools.sqltools.parsers.sql.lexer,1.0.1.v2008 05152355,file:plugins/org.eclipse.datatools.sqltools.parsers .sql.lexer_1.0.1.v200805152355.jar,4,false
org.eclipse.datatools.sqltools.parsers.sql.query,1.0.1.v2008 05152355,file:plugins/org.eclipse.datatools.sqltools.parsers .sql.query_1.0.1.v200805152355.jar,4,false
org.eclipse.datatools.sqltools.parsers.sql.xml.query,1.0.0.v 200805152355,file:plugins/org.eclipse.datatools.sqltools.par sers.sql.xml.query_1.0.0.v200805152355.jar,4,false
org.eclipse.datatools.sqltools.plan,1.0.0.v200805152355,file :plugins/org.eclipse.datatools.sqltools.plan_1.0.0.v20080515 2355.jar,4,false
org.eclipse.datatools.sqltools.result,1.0.0.v200805301309,fi le:plugins/org.eclipse.datatools.sqltools.result_1.0.0.v2008 05301309.jar,4,false
org.eclipse.datatools.sqltools.routineeditor,1.0.0.v20080526 1703,file:plugins/org.eclipse.datatools.sqltools.routineedit or_1.0.0.v200805261703.jar,4,false
org.eclipse.datatools.sqltools.sql,1.0.0.v200805152355,file: plugins/org.eclipse.datatools.sqltools.sql_1.0.0.v2008051523 55.jar,4,false
org.eclipse.datatools.sqltools.sqlbuilder,1.0.0.v20080607050 0,file:plugins/org.eclipse.datatools.sqltools.sqlbuilder_1.0 .0.v200806070500.jar,4,false
org.eclipse.datatools.sqltools.sqleditor,1.0.0.v200805152355 ,file:plugins/org.eclipse.datatools.sqltools.sqleditor_1.0.0 .v200805152355.jar,4,false
org.eclipse.datatools.sqltools.sqlscrapbook,1.0.0.v200806021 003,file:plugins/org.eclipse.datatools.sqltools.sqlscrapbook _1.0.0.v200806021003.jar,4,false
org.eclipse.datatools.sqltools.tabledataeditor,1.0.0.v200805 240400,file:plugins/org.eclipse.datatools.sqltools.tabledata editor_1.0.0.v200805240400.jar,4,false
org.eclipse.datatools.sqltools.tablewizard,1.0.0.v2008051523 55,file:plugins/org.eclipse.datatools.sqltools.tablewizard_1 .0.0.v200805152355.jar,4,false
org.eclipse.debug.core,3.4.0.v20080530,file:plugins/org.ecli pse.debug.core_3.4.0.v20080530.jar,4,false
org.eclipse.debug.ui,3.4.0.v20080529-1300,file:plugins/org.e clipse.debug.ui_3.4.0.v20080529-1300.jar,4,false
org.eclipse.dltk,1.0.0.v20080513-1615,file:plugins/org.eclip se.dltk_1.0.0.v20080513-1615.jar,4,false
org.eclipse.dltk.console,1.0.0.v20080513-1615,file:plugins/o rg.eclipse.dltk.console_1.0.0.v20080513-1615.jar,4,false
org.eclipse.dltk.console.ui,1.0.0.v20080521-1725,file:plugin s/org.eclipse.dltk.console.ui_1.0.0.v20080521-1725.jar,4,fal se
org.eclipse.dltk.core,1.0.0.v20080521-1725,file:plugins/org. eclipse.dltk.core_1.0.0.v20080521-1725.jar,4,false
org.eclipse.dltk.debug,1.0.0.v20080519-1649,file:plugins/org .eclipse.dltk.debug_1.0.0.v20080519-1649.jar,4,false
org.eclipse.dltk.debug.ui,1.0.0.v20080521-1725,file:plugins/ org.eclipse.dltk.debug.ui_1.0.0.v20080521-1725.jar,4,false
org.eclipse.dltk.launching,1.0.0.v20080521-1223,file:plugins /org.eclipse.dltk.launching_1.0.0.v20080521-1223.jar,4,false
org.eclipse.dltk.ruby,1.0.0.v20080513-1615,file:plugins/org. eclipse.dltk.ruby_1.0.0.v20080513-1615.jar,4,false
org.eclipse.dltk.ruby.abstractdebugger,1.0.0.v20080513-1615, file:plugins/org.eclipse.dltk.ruby.abstractdebugger_1.0.0.v2 0080513-1615.jar,4,false
org.eclipse.dltk.ruby.activestatedebugger,1.0.0.v20080513-16 15,file:plugins/org.eclipse.dltk.ruby.activestatedebugger_1. 0.0.v20080513-1615.jar,4,false
org.eclipse.dltk.ruby.basicdebugger,1.0.0.v20080513-1615,fil e:plugins/org.eclipse.dltk.ruby.basicdebugger_1.0.0.v2008051 3-1615.jar,4,false
org.eclipse.dltk.ruby.core,1.0.0.v20080519-1649,file:plugins /org.eclipse.dltk.ruby.core_1.0.0.v20080519-1649.jar,4,false
org.eclipse.dltk.ruby.debug,1.0.0.v20080513-1615,file:plugin s/org.eclipse.dltk.ruby.debug_1.0.0.v20080513-1615.jar,4,fal se
org.eclipse.dltk.ruby.debug.ui,1.0.0.v20080521-1223,file:plu gins/org.eclipse.dltk.ruby.debug.ui_1.0.0.v20080521-1223.jar ,4,false
org.eclipse.dltk.ruby.fastdebugger,1.0.0.v20080513-1615,file :plugins/org.eclipse.dltk.ruby.fastdebugger_1.0.0.v20080513- 1615.jar,4,false
org.eclipse.dltk.ruby.launching,1.0.0.v20080513-1615,file:pl ugins/org.eclipse.dltk.ruby.launching_1.0.0.v20080513-1615.j ar,4,false
org.eclipse.dltk.ruby.ui,1.0.0.v20080521-1841,file:plugins/o rg.eclipse.dltk.ruby.ui_1.0.0.v20080521-1841.jar,4,false
org.eclipse.dltk.testing,1.0.0.v20080513-1615,file:plugins/o rg.eclipse.dltk.testing_1.0.0.v20080513-1615.jar,4,false
org.eclipse.dltk.ui,1.0.0.v20080521-1725,file:plugins/org.ec lipse.dltk.ui_1.0.0.v20080521-1725.jar,4,false
org.eclipse.dltk.validators.core,1.0.0.v20080513-1615,file:p lugins/org.eclipse.dltk.validators.core_1.0.0.v20080513-1615 .jar,4,false
org.eclipse.dltk.validators.ui,1.0.0.v20080513-1615,file:plu gins/org.eclipse.dltk.validators.ui_1.0.0.v20080513-1615.jar ,4,false
org.eclipse.draw2d,3.4.0.v20080529,file:plugins/org.eclipse. draw2d_3.4.0.v20080529.jar,4,false
org.eclipse.draw2d.doc.isv,3.4.0.v20080226,file:plugins/org. eclipse.draw2d.doc.isv_3.4.0.v20080226.jar,4,false
org.eclipse.draw2d.source,3.4.0.v20080115-33-7w3119163_,file :plugins/org.eclipse.draw2d.source_3.4.0.v20080115-33-7w3119 163_/,4,false
org.eclipse.ecf,2.0.0.v20080528-2154,file:plugins/org.eclips e.ecf_2.0.0.v20080528-2154.jar,4,false
org.eclipse.ecf.filetransfer,2.0.0.v20080528-2154,file:plugi ns/org.eclipse.ecf.filetransfer_2.0.0.v20080528-2154.jar,4,f alse
org.eclipse.ecf.identity,2.0.0.v20080528-2154,file:plugins/o rg.eclipse.ecf.identity_2.0.0.v20080528-2154.jar,4,false
org.eclipse.ecf.provider.filetransfer,2.0.0.v20080528-2154,f ile:plugins/org.eclipse.ecf.provider.filetransfer_2.0.0.v200 80528-2154.jar,4,false
org.eclipse.ecf.provider.filetransfer.ssl,1.0.0.v20080528-21 54,file:plugins/org.eclipse.ecf.provider.filetransfer.ssl_1. 0.0.v20080528-2154.jar,4,false
org.eclipse.ecf.ssl,1.0.0.v20080528-2154,file:plugins/org.ec lipse.ecf.ssl_1.0.0.v20080528-2154.jar,4,false
org.eclipse.emf,2.4.0.v200806091234,file:plugins/org.eclipse .emf_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.ant,2.4.0.v200806091234,file:plugins/org.ecl ipse.emf.ant_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.cheatsheets,2.4.0.v200806091234,file:plugins /org.eclipse.emf.cheatsheets_2.4.0.v200806091234/,4,false
org.eclipse.emf.codegen,2.4.0.v200806091234,file:plugins/org .eclipse.emf.codegen_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.codegen.ecore,2.4.0.v200806091234,file:plugi ns/org.eclipse.emf.codegen.ecore_2.4.0.v200806091234.jar,4,f alse
org.eclipse.emf.codegen.ecore.ui,2.4.0.v200806091234,file:pl ugins/org.eclipse.emf.codegen.ecore.ui_2.4.0.v200806091234.j ar,4,false
org.eclipse.emf.codegen.ui,2.4.0.v200806091234,file:plugins/ org.eclipse.emf.codegen.ui_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.common,2.4.0.v200806091234,file:plugins/org. eclipse.emf.common_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.common.ui,2.4.0.v200806091234,file:plugins/o rg.eclipse.emf.common.ui_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.compare,0.8.0.v200806180301,file:plugins/org .eclipse.emf.compare_0.8.0.v200806180301.jar,4,false
org.eclipse.emf.compare.diff,0.8.0.v200806180301,file:plugin s/org.eclipse.emf.compare.diff_0.8.0.v200806180301.jar,4,fal se
org.eclipse.emf.compare.diff.edit,0.8.0.v200806180301,file:p lugins/org.eclipse.emf.compare.diff.edit_0.8.0.v200806180301 .jar,4,false
org.eclipse.emf.compare.doc,0.8.0.v200806180301,file:plugins /org.eclipse.emf.compare.doc_0.8.0.v200806180301/,4,false
org.eclipse.emf.compare.match,0.8.0.v200806180301,file:plugi ns/org.eclipse.emf.compare.match_0.8.0.v200806180301.jar,4,f alse
org.eclipse.emf.compare.source,0.8.0.v200806180301,file:plug ins/org.eclipse.emf.compare.source_0.8.0.v200806180301/,4,fa lse
org.eclipse.emf.compare.ui,0.8.0.v200806180301,file:plugins/ org.eclipse.emf.compare.ui_0.8.0.v200806180301.jar,4,false
org.eclipse.emf.converter,2.4.0.v200806091234,file:plugins/o rg.eclipse.emf.converter_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.databinding,1.0.0.v200806091234,file:plugins /org.eclipse.emf.databinding_1.0.0.v200806091234.jar,4,false
org.eclipse.emf.databinding.edit,1.0.0.v200806091234,file:pl ugins/org.eclipse.emf.databinding.edit_1.0.0.v200806091234.j ar,4,false
org.eclipse.emf.doc,2.4.0.v200806091234,file:plugins/org.ecl ipse.emf.doc_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.ecore,2.4.0.v200806091234,file:plugins/org.e clipse.emf.ecore_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.ecore.change,2.4.0.v200806091234,file:plugin s/org.eclipse.emf.ecore.change_2.4.0.v200806091234.jar,4,fal se
org.eclipse.emf.ecore.change.edit,2.4.0.v200806091234,file:p lugins/org.eclipse.emf.ecore.change.edit_2.4.0.v200806091234 .jar,4,false
org.eclipse.emf.ecore.edit,2.4.0.v200806091234,file:plugins/ org.eclipse.emf.ecore.edit_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.ecore.editor,2.4.0.v200806091234,file:plugin s/org.eclipse.emf.ecore.editor_2.4.0.v200806091234.jar,4,fal se
org.eclipse.emf.ecore.xmi,2.4.0.v200806091234,file:plugins/o rg.eclipse.emf.ecore.xmi_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.ecoretools,0.8.0.v200806130600,file:plugins/ org.eclipse.emf.ecoretools_0.8.0.v200806130600.jar,4,false
org.eclipse.emf.ecoretools.diagram,0.8.0.v200806130600,file: plugins/org.eclipse.emf.ecoretools.diagram_0.8.0.v2008061306 00.jar,4,false
org.eclipse.emf.ecoretools.diagram.ui.outline,0.8.0.v2008061 30600,file:plugins/org.eclipse.emf.ecoretools.diagram.ui.out line_0.8.0.v200806130600.jar,4,false
org.eclipse.emf.ecoretools.doc,0.8.0.v200806130600,file:plug ins/org.eclipse.emf.ecoretools.doc_0.8.0.v200806130600.jar,4 ,false
org.eclipse.emf.ecoretools.filters,0.8.0.v200806130600,file: plugins/org.eclipse.emf.ecoretools.filters_0.8.0.v2008061306 00.jar,4,false
org.eclipse.emf.ecoretools.properties,0.8.0.v200806130600,fi le:plugins/org.eclipse.emf.ecoretools.properties_0.8.0.v2008 06130600.jar,4,false
org.eclipse.emf.ecoretools.source,0.8.0.v200806130600,file:p lugins/org.eclipse.emf.ecoretools.source_0.8.0.v200806130600 /,4,false
org.eclipse.emf.ecoretools.tabbedproperties,0.8.0.v200806130 600,file:plugins/org.eclipse.emf.ecoretools.tabbedproperties _0.8.0.v200806130600.jar,4,false
org.eclipse.emf.edit,2.4.0.v200806091234,file:plugins/org.ec lipse.emf.edit_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.edit.ui,2.4.0.v200806091234,file:plugins/org .eclipse.emf.edit.ui_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.example.installer,1.0.0.v200806091234,file:p lugins/org.eclipse.emf.example.installer_1.0.0.v200806091234 .jar,4,false
org.eclipse.emf.exporter,2.4.0.v200806091234,file:plugins/or g.eclipse.emf.exporter_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.importer,2.4.0.v200806091234,file:plugins/or g.eclipse.emf.importer_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.importer.ecore,2.4.0.v200806091234,file:plug ins/org.eclipse.emf.importer.ecore_2.4.0.v200806091234.jar,4 ,false
org.eclipse.emf.importer.java,2.4.0.v200806091234,file:plugi ns/org.eclipse.emf.importer.java_2.4.0.v200806091234.jar,4,f alse
org.eclipse.emf.importer.rose,2.4.0.v200806091234,file:plugi ns/org.eclipse.emf.importer.rose_2.4.0.v200806091234.jar,4,f alse
org.eclipse.emf.mapping,2.4.0.v200806091234,file:plugins/org .eclipse.emf.mapping_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.mapping.ecore,2.4.0.v200806091234,file:plugi ns/org.eclipse.emf.mapping.ecore_2.4.0.v200806091234.jar,4,f alse
org.eclipse.emf.mapping.ecore.editor,2.4.0.v200806091234,fil e:plugins/org.eclipse.emf.mapping.ecore.editor_2.4.0.v200806 091234.jar,4,false
org.eclipse.emf.mapping.ecore2ecore,2.4.0.v200806091234,file :plugins/org.eclipse.emf.mapping.ecore2ecore_2.4.0.v20080609 1234.jar,4,false
org.eclipse.emf.mapping.ecore2ecore.editor,2.4.0.v2008060912 34,file:plugins/org.eclipse.emf.mapping.ecore2ecore.editor_2 .4.0.v200806091234.jar,4,false
org.eclipse.emf.mapping.ecore2xml,2.4.0.v200806091234,file:p lugins/org.eclipse.emf.mapping.ecore2xml_2.4.0.v200806091234 .jar,4,false
org.eclipse.emf.mapping.ecore2xml.ui,2.4.0.v200806091234,fil e:plugins/org.eclipse.emf.mapping.ecore2xml.ui_2.4.0.v200806 091234.jar,4,false
org.eclipse.emf.mapping.ui,2.4.0.v200806091234,file:plugins/ org.eclipse.emf.mapping.ui_2.4.0.v200806091234.jar,4,false
org.eclipse.emf.mapping.xsd2ecore,2.4.0.v200806091234,file:p lugins/org.eclipse.emf.mapping.xsd2ecore_2.4.0.v200806091234 .jar,4,false
org.eclipse.emf.mapping.xsd2ecore.editor,2.4.0.v200806091234 ,file:plugins/org.eclipse.emf.mapping.xsd2ecore.editor_2.4.0 .v200806091234.jar,4,false
org.eclipse.emf.ocl,1.1.100.v200805130238,file:plugins/org.e clipse.emf.ocl_1.1.100.v200805130238.jar,4,false
org.eclipse.emf.ocl.doc,1.1.100.v200805130238,file:plugins/o rg.eclipse.emf.ocl.doc_1.1.100.v200805130238.jar,4,false
org.eclipse.emf.ocl.examples,1.2.0.v200805130238,file:plugin s/org.eclipse.emf.ocl.examples_1.2.0.v200805130238.jar,4,fal se
org.eclipse.emf.ocl.source,1.1.100.v200805130238-108Y7w31191 6241349,file:plugins/org.eclipse.emf.ocl.source_1.1.100.v200 805130238-108Y7w311916241349/,4,false
org.eclipse.emf.query,1.2.0.v200805130238,file:plugins/org.e clipse.emf.query_1.2.0.v200805130238.jar,4,false
org.eclipse.emf.query.ocl,1.2.0.v200805130238,file:plugins/o rg.eclipse.emf.query.ocl_1.2.0.v200805130238.jar,4,false
org.eclipse.emf.search,0.7.0.v200806130939,file:plugins/org. eclipse.emf.search_0.7.0.v200806130939.jar,4,false
org.eclipse.emf.search.codegen,0.7.0.v200806130939,file:plug ins/org.eclipse.emf.search.codegen_0.7.0.v200806130939.jar,4 ,false
org.eclipse.emf.search.common,0.7.0.v200806130939,file:plugi ns/org.eclipse.emf.search.common_0.7.0.v200806130939.jar,4,f alse
org.eclipse.emf.search.common.ui,0.7.0.v200806130939,file:pl ugins/org.eclipse.emf.search.common.ui_0.7.0.v200806130939.j ar,4,false
org.eclipse.emf.search.doc,0.7.0.v200806130939,file:plugins/ org.eclipse.emf.search.doc_0.7.0.v200806130939.jar,4,false
org.eclipse.emf.search.ecore,0.7.0.v200806130939,file:plugin s/org.eclipse.emf.search.ecore_0.7.0.v200806130939.jar,4,fal se
org.eclipse.emf.search.ecore.ocl,0.7.0.v200806130939,file:pl ugins/org.eclipse.emf.search.ecore.ocl_0.7.0.v200806130939.j ar,4,false
org.eclipse.emf.search.ecore.ocl.ui,0.7.0.v200806130939,file :plugins/org.eclipse.emf.search.ecore.ocl.ui_0.7.0.v20080613 0939.jar,4,false
org.eclipse.emf.search.ecore.ui,0.7.0.v200806130939,file:plu gins/org.eclipse.emf.search.ecore.ui_0.7.0.v200806130939.jar ,4,false
org.eclipse.emf.search.genmodel,0.7.0.v200806130939,file:plu gins/org.eclipse.emf.search.genmodel_0.7.0.v200806130939.jar ,4,false
org.eclipse.emf.search.genmodel.ui,0.7.0.v200806130939,file: plugins/org.eclipse.emf.search.genmodel.ui_0.7.0.v2008061309 39.jar,4,false
org.eclipse.emf.search.ocl,0.7.0.v200806130939,file:plugins/ org.eclipse.emf.search.ocl_0.7.0.v200806130939.jar,4,false
org.eclipse.emf.search.ocl.ui,0.7.0.v200806130939,file:plugi ns/org.eclipse.emf.search.ocl.ui_0.7.0.v200806130939.jar,4,f alse
org.eclipse.emf.search.ui,0.7.0.v200806130939,file:plugins/o rg.eclipse.emf.search.ui_0.7.0.v200806130939.jar,4,false
org.eclipse.emf.source,2.4.0.v200806091234,file:plugins/org. eclipse.emf.source_2.4.0.v200806091234/,4,false
org.eclipse.emf.transaction,1.2.0.v200805130238,file:plugins /org.eclipse.emf.transaction_1.2.0.v200805130238.jar,4,false
org.eclipse.emf.transaction.ui,1.2.0.v200805130238,file:plug ins/org.eclipse.emf.transaction.ui_1.2.0.v200805130238.jar,4 ,false
org.eclipse.emf.validation,1.2.0.v200805170232,file:plugins/ org.eclipse.emf.validation_1.2.0.v200805170232.jar,4,false
org.eclipse.emf.validation.ui,1.2.0.v200805130238,file:plugi ns/org.eclipse.emf.validation.ui_1.2.0.v200805130238.jar,4,f alse
org.eclipse.emf.validation.ui.ide,1.2.0.v200805130238,file:p lugins/org.eclipse.emf.validation.ui.ide_1.2.0.v200805130238 .jar,4,false
org.eclipse.emf.workspace,1.2.0.v200805130238,file:plugins/o rg.eclipse.emf.workspace_1.2.0.v200805130238.jar,4,false
org.eclipse.emf.workspace.ui,1.2.0.v200805130238,file:plugin s/org.eclipse.emf.workspace.ui_1.2.0.v200805130238.jar,4,fal se
org.eclipse.equinox.app,1.1.0.v20080421-2006,file:plugins/or g.eclipse.equinox.app_1.1.0.v20080421-2006.jar,4,false
org.eclipse.equinox.common,3.4.0.v20080421-2006,file:plugins /org.eclipse.equinox.common_3.4.0.v20080421-2006.jar,2,true
org.eclipse.equinox.frameworkadmin,1.0.0.v20080430-1750,file :plugins/org.eclipse.equinox.frameworkadmin_1.0.0.v20080430- 1750.jar,4,false
org.eclipse.equinox.frameworkadmin.equinox,1.0.0.v20080529-1 225,file:plugins/org.eclipse.equinox.frameworkadmin.equinox_ 1.0.0.v20080529-1225.jar,4,false
org.eclipse.equinox.http.jetty,1.1.0.v20080425,file:plugins/ org.eclipse.equinox.http.jetty_1.1.0.v20080425.jar,4,false
org.eclipse.equinox.http.registry,1.0.100.v20080427-0830,fil e:plugins/org.eclipse.equinox.http.registry_1.0.100.v2008042 7-0830.jar,4,false
org.eclipse.equinox.http.servlet,1.0.100.v20080427-0830,file :plugins/org.eclipse.equinox.http.servlet_1.0.100.v20080427- 0830.jar,4,false
org.eclipse.equinox.jsp.jasper,1.0.100.v20080427-0830,file:p lugins/org.eclipse.equinox.jsp.jasper_1.0.100.v20080427-0830 .jar,4,false
org.eclipse.equinox.jsp.jasper.registry,1.0.0.v20080427-0830 ,file:plugins/org.eclipse.equinox.jsp.jasper.registry_1.0.0. v20080427-0830.jar,4,false
org.eclipse.equinox.launcher,1.0.100.v20080509-1800,file:plu gins/org.eclipse.equinox.launcher_1.0.100.v20080509-1800.jar ,4,false
org.eclipse.equinox.launcher.gtk.linux.x86,1.0.100.v20080509 -1800,file:plugins/org.eclipse.equinox.launcher.gtk.linux.x8 6_1.0.100.v20080509-1800/,4,false
org.eclipse.equinox.p2.artifact.repository,1.0.0.v20080530-1 237,file:plugins/org.eclipse.equinox.p2.artifact.repository_ 1.0.0.v20080530-1237.jar,4,false
org.eclipse.equinox.p2.console,1.0.0.v20080514-1900,file:plu gins/org.eclipse.equinox.p2.console_1.0.0.v20080514-1900.jar ,4,false
org.eclipse.equinox.p2.core,1.0.0.v20080530-1237,file:plugin s/org.eclipse.equinox.p2.core_1.0.0.v20080530-1237.jar,4,fal se
org.eclipse.equinox.p2.director,1.0.0.v20080528-1943,file:pl ugins/org.eclipse.equinox.p2.director_1.0.0.v20080528-1943.j ar,4,false
org.eclipse.equinox.p2.director.app,1.0.0.v20080530-0004,fil e:plugins/org.eclipse.equinox.p2.director.app_1.0.0.v2008053 0-0004.jar,4,false
org.eclipse.equinox.p2.directorywatcher,1.0.0.v20080505-1850 ,file:plugins/org.eclipse.equinox.p2.directorywatcher_1.0.0. v20080505-1850.jar,4,false
org.eclipse.equinox.p2.engine,1.0.0.v20080522-1735,file:plug ins/org.eclipse.equinox.p2.engine_1.0.0.v20080522-1735.jar,4 ,false
org.eclipse.equinox.p2.exemplarysetup,1.0.0.v20080427-2136,f ile:plugins/org.eclipse.equinox.p2.exemplarysetup_1.0.0.v200 80427-2136.jar,4,false
org.eclipse.equinox.p2.extensionlocation,1.0.0.v20080523-000 1,file:plugins/org.eclipse.equinox.p2.extensionlocation_1.0. 0.v20080523-0001.jar,4,false
org.eclipse.equinox.p2.garbagecollector,1.0.0.v20080506-1939 ,file:plugins/org.eclipse.equinox.p2.garbagecollector_1.0.0. v20080506-1939.jar,4,false
org.eclipse.equinox.p2.jarprocessor,1.0.0.v20080514-1900,fil e:plugins/org.eclipse.equinox.p2.jarprocessor_1.0.0.v2008051 4-1900.jar,4,false
org.eclipse.equinox.p2.metadata,1.0.0.v20080514-1900,file:pl ugins/org.eclipse.equinox.p2.metadata_1.0.0.v20080514-1900.j ar,4,false
org.eclipse.equinox.p2.metadata.generator,1.0.0.v20080530-12 37,file:plugins/org.eclipse.equinox.p2.metadata.generator_1. 0.0.v20080530-1237.jar,4,false
org.eclipse.equinox.p2.metadata.repository,1.0.0.v20080530-1 237,file:plugins/org.eclipse.equinox.p2.metadata.repository_ 1.0.0.v20080530-1237.jar,4,false
org.eclipse.equinox.p2.reconciler.dropins,1.0.0.v20080529-18 00,file:plugins/org.eclipse.equinox.p2.reconciler.dropins_1. 0.0.v20080529-1800.jar,4,true
org.eclipse.equinox.p2.touchpoint.eclipse,1.0.0.v20080529-12 25,file:plugins/org.eclipse.equinox.p2.touchpoint.eclipse_1. 0.0.v20080529-1225.jar,4,false
org.eclipse.equinox.p2.touchpoint.natives,1.0.0.v20080505-18 50,file:plugins/org.eclipse.equinox.p2.touchpoint.natives_1. 0.0.v20080505-1850.jar,4,false
org.eclipse.equinox.p2.ui,1.0.0.v20080530-1237,file:plugins/ org.eclipse.equinox.p2.ui_1.0.0.v20080530-1237.jar,4,false
org.eclipse.equinox.p2.ui.sdk,1.0.0.v20080530-1237,file:plug ins/org.eclipse.equinox.p2.ui.sdk_1.0.0.v20080530-1237.jar,4 ,false
org.eclipse.equinox.p2.updatechecker,1.0.0.v20080427-2136,fi le:plugins/org.eclipse.equinox.p2.updatechecker_1.0.0.v20080 427-2136.jar,4,false
org.eclipse.equinox.p2.updatesite,1.0.0.v20080529-1800,file: plugins/org.eclipse.equinox.p2.updatesite_1.0.0.v20080529-18 00.jar,4,false
org.eclipse.equinox.preferences,3.2.200.v20080421-2006,file: plugins/org.eclipse.equinox.preferences_3.2.200.v20080421-20 06.jar,4,false
org.eclipse.equinox.registry,3.4.0.v20080516-0950,file:plugi ns/org.eclipse.equinox.registry_3.4.0.v20080516-0950.jar,4,f alse
org.eclipse.equinox.security,1.0.0.v20080512-1800,file:plugi ns/org.eclipse.equinox.security_1.0.0.v20080512-1800.jar,4,f alse
org.eclipse.equinox.security.ui,1.0.0.v20080529-1600,file:pl ugins/org.eclipse.equinox.security.ui_1.0.0.v20080529-1600.j ar,4,false
org.eclipse.equinox.simpleconfigurator,1.0.0.v20080522-1222, file:plugins/org.eclipse.equinox.simpleconfigurator_1.0.0.v2 0080522-1222.jar,1,true
org.eclipse.equinox.simpleconfigurator.manipulator,1.0.0.v20 080427-2136,file:plugins/org.eclipse.equinox.simpleconfigura tor.manipulator_1.0.0.v20080427-2136.jar,4,false
org.eclipse.gef,3.4.0.v20080526,file:plugins/org.eclipse.gef _3.4.0.v20080526.jar,4,false
org.eclipse.gef.doc.isv,3.4.0.v20080226,file:plugins/org.ecl ipse.gef.doc.isv_3.4.0.v20080226.jar,4,false
org.eclipse.gef.examples.ui.pde,3.4.0.v20080226,file:plugins /org.eclipse.gef.examples.ui.pde_3.4.0.v20080226.jar,4,false
org.eclipse.gef.source,3.4.0.v20080115-677-8082A5696H274A,fi le:plugins/org.eclipse.gef.source_3.4.0.v20080115-677-8082A5 696H274A/,4,false
org.eclipse.gmf,1.0.0.v20080425-1959,file:plugins/org.eclips e.gmf_1.0.0.v20080425-1959.jar,4,false
org.eclipse.gmf.bridge,1.1.0.v20080528-1052,file:plugins/org .eclipse.gmf.bridge_1.1.0.v20080528-1052.jar,4,false
org.eclipse.gmf.bridge.trace,1.0.100.v20080425-1959,file:plu gins/org.eclipse.gmf.bridge.trace_1.0.100.v20080425-1959.jar ,4,false
org.eclipse.gmf.bridge.ui,1.1.100.v20080417-1610,file:plugin s/org.eclipse.gmf.bridge.ui_1.1.100.v20080417-1610.jar,4,fal se
org.eclipse.gmf.bridge.ui.dashboard,2.0.0.v20080417-1610,fil e:plugins/org.eclipse.gmf.bridge.ui.dashboard_2.0.0.v2008041 7-1610.jar,4,false
org.eclipse.gmf.codegen,2.1.0.v20080610-1132,file:plugins/or g.eclipse.gmf.codegen_2.1.0.v20080610-1132.jar,4,false
org.eclipse.gmf.codegen.edit,2.1.0.v20080610-1132,file:plugi ns/org.eclipse.gmf.codegen.edit_2.1.0.v20080610-1132.jar,4,f alse
org.eclipse.gmf.codegen.lite,1.1.100.v20080507-1326,file:plu gins/org.eclipse.gmf.codegen.lite_1.1.100.v20080507-1326.jar ,4,false
org.eclipse.gmf.codegen.lite.ui,1.1.0.v20080425-1959,file:pl ugins/org.eclipse.gmf.codegen.lite.ui_1.1.0.v20080425-1959.j ar,4,false
org.eclipse.gmf.codegen.ui,1.1.0.v20080512-1200,file:plugins /org.eclipse.gmf.codegen.ui_1.1.0.v20080512-1200.jar,4,false
org.eclipse.gmf.common,1.1.1.v20080610-1132,file:plugins/org .eclipse.gmf.common_1.1.1.v20080610-1132.jar,4,false
org.eclipse.gmf.doc,1.2.0.v20080516-1143,file:plugins/org.ec lipse.gmf.doc_1.2.0.v20080516-1143.jar,4,false
org.eclipse.gmf.ecore.editor,2.0.100.v20080610-1132,file:plu gins/org.eclipse.gmf.ecore.editor_2.0.100.v20080610-1132.jar ,4,false
org.eclipse.gmf.examples,1.0.100.v20080425-1959,file:plugins /org.eclipse.gmf.examples_1.0.100.v20080425-1959.jar,4,false
org.eclipse.gmf.examples.ui.pde,1.0.200.v20080425-1959,file: plugins/org.eclipse.gmf.examples.ui.pde_1.0.200.v20080425-19 59.jar,4,false
org.eclipse.gmf.graphdef,2.0.100.v20080528-1052,file:plugins /org.eclipse.gmf.graphdef_2.0.100.v20080528-1052.jar,4,false
org.eclipse.gmf.graphdef.codegen,2.0.100.v20080528-1052,file :plugins/org.eclipse.gmf.graphdef.codegen_2.0.100.v20080528- 1052.jar,4,false
org.eclipse.gmf.graphdef.codegen.ui,1.0.100.v20080425-1959,f ile:plugins/org.eclipse.gmf.graphdef.codegen.ui_1.0.100.v200 80425-1959.jar,4,false
org.eclipse.gmf.graphdef.edit,2.0.100.v20080610-1132,file:pl ugins/org.eclipse.gmf.graphdef.edit_2.0.100.v20080610-1132.j ar,4,false
org.eclipse.gmf.graphdef.editor,1.0.1.v20080610-1132,file:pl ugins/org.eclipse.gmf.graphdef.editor_1.0.1.v20080610-1132.j ar,4,false
org.eclipse.gmf.map,2.1.0.v20080521,file:plugins/org.eclipse .gmf.map_2.1.0.v20080521.jar,4,false
org.eclipse.gmf.map.edit,2.1.0.v20080610-1132,file:plugins/o rg.eclipse.gmf.map.edit_2.1.0.v20080610-1132.jar,4,false
org.eclipse.gmf.map.editor,1.0.0.v20080425-1959,file:plugins /org.eclipse.gmf.map.editor_1.0.0.v20080425-1959.jar,4,false
org.eclipse.gmf.runtime.common.core,1.1.0.v20080425-1959,fil e:plugins/org.eclipse.gmf.runtime.common.core_1.1.0.v2008042 5-1959.jar,4,false
org.eclipse.gmf.runtime.common.ui,1.1.0.v20080512-1200,file: plugins/org.eclipse.gmf.runtime.common.ui_1.1.0.v20080512-12 00.jar,4,false
org.eclipse.gmf.runtime.common.ui.action,1.1.0.v20080425-195 9,file:plugins/org.eclipse.gmf.runtime.common.ui.action_1.1. 0.v20080425-1959.jar,4,false
org.eclipse.gmf.runtime.common.ui.action.ide,1.1.0.v20080425 -1959,file:plugins/org.eclipse.gmf.runtime.common.ui.action. ide_1.1.0.v20080425-1959.jar,4,false
org.eclipse.gmf.runtime.common.ui.printing,1.1.0.v20080425-1 959,file:plugins/org.eclipse.gmf.runtime.common.ui.printing_ 1.1.0.v20080425-1959.jar,4,false
org.eclipse.gmf.runtime.common.ui.printing.win32,1.1.0.v2008 0612-1355,file:plugins/org.eclipse.gmf.runtime.common.ui.pri nting.win32_1.1.0.v20080612-1355.jar,4,false
org.eclipse.gmf.runtime.common.ui.services,1.1.0.v20080612-1 229,file:plugins/org.eclipse.gmf.runtime.common.ui.services_ 1.1.0.v20080612-1229.jar,4,false
org.eclipse.gmf.runtime.common.ui.services.action,1.1.0.v200 80507-2230,file:plugins/org.eclipse.gmf.runtime.common.ui.se rvices.action_1.1.0.v20080507-2230.jar,4,false
org.eclipse.gmf.runtime.common.ui.services.dnd,1.1.0.v200804 25-1959,file:plugins/org.eclipse.gmf.runtime.common.ui.servi ces.dnd_1.1.0.v20080425-1959.jar,4,false
org.eclipse.gmf.runtime.common.ui.services.dnd.ide,1.1.0.v20 080425-1959,file:plugins/org.eclipse.gmf.runtime.common.ui.s ervices.dnd.ide_1.1.0.v20080425-1959.jar,4,false
org.eclipse.gmf.runtime.common.ui.services.properties,1.1.0. v20080425-1959,file:plugins/org.eclipse.gmf.runtime.common.u i.services.properties_1.1.0.v20080425-1959.jar,4,false
org.eclipse.gmf.runtime.diagram.core,1.1.0.v20080425-1959,fi le:plugins/org.eclipse.gmf.runtime.diagram.core_1.1.0.v20080 425-1959.jar,4,false
org.eclipse.gmf.runtime.diagram.ui,1.1.0.v20080610-1132,file :plugins/org.eclipse.gmf.runtime.diagram.ui_1.1.0.v20080610- 1132.jar,4,false
org.eclipse.gmf.runtime.diagram.ui.actions,1.1.0.v20080603-1 553,file:plugins/org.eclipse.gmf.runtime.diagram.ui.actions_ 1.1.0.v20080603-1553.jar,4,false
org.eclipse.gmf.runtime.diagram.ui.dnd,1.1.0.v20080425-1959, file:plugins/org.eclipse.gmf.runtime.diagram.ui.dnd_1.1.0.v2 0080425-1959.jar,4,false
org.eclipse.gmf.runtime.diagram.ui.geoshapes,1.1.0.v20080503 -1740,file:plugins/org.eclipse.gmf.runtime.diagram.ui.geosha pes_1.1.0.v20080503-1740.jar,4,false
org.eclipse.gmf.runtime.diagram.ui.printing,1.1.0.v20080501- 1739,file:plugins/org.eclipse.gmf.runtime.diagram.ui.printin g_1.1.0.v20080501-1739.jar,4,false
org.eclipse.gmf.runtime.diagram.ui.printing.render,1.1.0.v20 080425-1959,file:plugins/org.eclipse.gmf.runtime.diagram.ui. printing.render_1.1.0.v20080425-1959.jar,4,false
org.eclipse.gmf.runtime.diagram.ui.properties,1.1.0.v2008060 3-1553,file:plugins/org.eclipse.gmf.runtime.diagram.ui.prope rties_1.1.0.v20080603-1553.jar,4,false
org.eclipse.gmf.runtime.diagram.ui.providers,1.1.0.v20080503 -1740,file:plugins/org.eclipse.gmf.runtime.diagram.ui.provid ers_1.1.0.v20080503-1740.jar,4,false
org.eclipse.gmf.runtime.diagram.ui.providers.ide,1.1.0.v2008 0425-1959,file:plugins/org.eclipse.gmf.runtime.diagram.ui.pr oviders.ide_1.1.0.v20080425-1959.jar,4,false
org.eclipse.gmf.runtime.diagram.ui.render,1.1.0.v20080603-15 53,file:plugins/org.eclipse.gmf.runtime.diagram.ui.render_1. 1.0.v20080603-1553.jar,4,false
org.eclipse.gmf.runtime.diagram.ui.resources.editor,1.1.0.v2 0080425-1959,file:plugins/org.eclipse.gmf.runtime.diagram.ui .resources.editor_1.1.0.v20080425-1959.jar,4,false
org.eclipse.gmf.runtime.diagram.ui.resources.editor.ide,1.1. 0.v20080425-1959,file:plugins/org.eclipse.gmf.runtime.diagra m.ui.resources.editor.ide_1.1.0.v20080425-1959.jar,4,false
org.eclipse.gmf.runtime.draw2d.ui,1.1.0.v20080610-1132,file: plugins/org.eclipse.gmf.runtime.draw2d.ui_1.1.0.v20080610-11 32.jar,4,false
org.eclipse.gmf.runtime.draw2d.ui.render,1.1.0.v20080507-223 0,file:plugins/org.eclipse.gmf.runtime.draw2d.ui.render_1.1. 0.v20080507-2230.jar,4,false
org.eclipse.gmf.runtime.draw2d.ui.render.awt,1.1.0.v20080603 -1553,file:plugins/org.eclipse.gmf.runtime.draw2d.ui.render. awt_1.1.0.v20080603-1553.jar,4,false
org.eclipse.gmf.runtime.emf.clipboard.core,1.1.0.v20080425-1 959,file:plugins/org.eclipse.gmf.runtime.emf.clipboard.core_ 1.1.0.v20080425-1959.jar,4,false
org.eclipse.gmf.runtime.emf.commands.core,1.1.0.v20080425-19 59,file:plugins/org.eclipse.gmf.runtime.emf.commands.core_1. 1.0.v20080425-1959.jar,4,false
org.eclipse.gmf.runtime.emf.core,1.1.0.v20080425-1959,file:p lugins/org.eclipse.gmf.runtime.emf.core_1.1.0.v20080425-1959 .jar,4,false
org.eclipse.gmf.runtime.emf.type.core,1.1.0.v20080425-1959,f ile:plugins/org.eclipse.gmf.runtime.emf.type.core_1.1.0.v200 80425-1959.jar,4,false
org.eclipse.gmf.runtime.emf.type.ui,1.1.0.v20080425-1959,fil e:plugins/org.eclipse.gmf.runtime.emf.type.ui_1.1.0.v2008042 5-1959.jar,4,false
org.eclipse.gmf.runtime.emf.ui,1.1.0.v20080516-1748,file:plu gins/org.eclipse.gmf.runtime.emf.ui_1.1.0.v20080516-1748.jar ,4,false
org.eclipse.gmf.runtime.emf.ui.properties,1.1.0.v20080425-19 59,file:plugins/org.eclipse.gmf.runtime.emf.ui.properties_1. 1.0.v20080425-1959.jar,4,false
org.eclipse.gmf.runtime.gef.ui,1.1.0.v20080503-1740,file:plu gins/org.eclipse.gmf.runtime.gef.ui_1.1.0.v20080503-1740.jar ,4,false
org.eclipse.gmf.runtime.lite,1.0.0.v20080425-1959,file:plugi ns/org.eclipse.gmf.runtime.lite_1.0.0.v20080425-1959.jar,4,f alse
org.eclipse.gmf.runtime.notation,1.1.0.v20080507-1326,file:p lugins/org.eclipse.gmf.runtime.notation_1.1.0.v20080507-1326 .jar,4,false
org.eclipse.gmf.runtime.notation.edit,1.1.0.v20080507-1326,f ile:plugins/org.eclipse.gmf.runtime.notation.edit_1.1.0.v200 80507-1326.jar,4,false
org.eclipse.gmf.runtime.notation.providers,1.1.0.v20080425-1 959,file:plugins/org.eclipse.gmf.runtime.notation.providers_ 1.1.0.v20080425-1959.jar,4,false
org.eclipse.gmf.sdk,1.0.0.v20080425-1959,file:plugins/org.ec lipse.gmf.sdk_1.0.0.v20080425-1959.jar,4,false
org.eclipse.gmf.tooldef,2.0.0.v20080417-1610,file:plugins/or g.eclipse.gmf.tooldef_2.0.0.v20080417-1610.jar,4,false
org.eclipse.gmf.tooldef.edit,2.0.0.v20080610-1132,file:plugi ns/org.eclipse.gmf.tooldef.edit_2.0.0.v20080610-1132.jar,4,f alse
org.eclipse.gmf.tooling,2.1.0.v20080425-1959,file:plugins/or g.eclipse.gmf.tooling_2.1.0.v20080425-1959.jar,4,false
org.eclipse.gmf.validate,1.1.0.v20080603-1553,file:plugins/o rg.eclipse.gmf.validate_1.1.0.v20080603-1553.jar,4,false
org.eclipse.gmf.xpand,1.1.0.v20080528-1052,file:plugins/org. eclipse.gmf.xpand_1.1.0.v20080528-1052.jar,4,false
org.eclipse.gmf.xpand.editor,1.0.0.v20080425-1959,file:plugi ns/org.eclipse.gmf.xpand.editor_1.0.0.v20080425-1959.jar,4,f alse
org.eclipse.gmt.gems.dsml,3.0.1,file:plugins/org.eclipse.gmt .gems.dsml_3.0.1.jar,4,false
org.eclipse.gmt.gems.dsml.css.manager,1.0.0,file:plugins/org .eclipse.gmt.gems.dsml.css.manager_1.0.0.jar,4,false
org.eclipse.gmt.gems.dsml.css.parser,1.0.0,file:plugins/org. eclipse.gmt.gems.dsml.css.parser_1.0.0.jar,4,false
org.eclipse.gmt.gems.dsml.emf,1.0.0,file:plugins/org.eclipse .gmt.gems.dsml.emf_1.0.0.jar,4,false
org.eclipse.gmt.gems.dsml.emf.ocl,2.0.11,file:plugins/org.ec lipse.gmt.gems.dsml.emf.ocl_2.0.11.jar,4,false
org.eclipse.gmt.gems.dsml.menu.dynamic,1.0.0,file:plugins/or g.eclipse.gmt.gems.dsml.menu.dynamic_1.0.0.jar,4,false
org.eclipse.gmt.gems.dsml.metamodel.generator,1.0.0,file:plu gins/org.eclipse.gmt.gems.dsml.metamodel.generator_1.0.0.jar ,4,false
org.eclipse.gmt.gems.dsml.metamodel2,1.0.2,file:plugins/org. eclipse.gmt.gems.dsml.metamodel2_1.0.2.jar,4,false
org.eclipse.gmt.gems.dsml.metamodel2.generator,1.0.0,file:pl ugins/org.eclipse.gmt.gems.dsml.metamodel2.generator_1.0.0.j ar,4,false
org.eclipse.gmt.gems.dsml.model.intelligence,1.0.0,file:plug ins/org.eclipse.gmt.gems.dsml.model.intelligence_1.0.0.jar,4 ,false
org.eclipse.gmt.gems.dsml.styles,1.0.0,file:plugins/org.ecli pse.gmt.gems.dsml.styles_1.0.0.jar,4,false
org.eclipse.gmt.gems.dsml.styles.active,1.0.0,file:plugins/o rg.eclipse.gmt.gems.dsml.styles.active_1.0.0.jar,4,false
org.eclipse.gmt.gems.dsml.trigger,1.0.0,file:plugins/org.ecl ipse.gmt.gems.dsml.trigger_1.0.0.jar,4,false
org.eclipse.gmt.gems.dsml.visuals,1.0.0,file:plugins/org.ecl ipse.gmt.gems.dsml.visuals_1.0.0.jar,4,false
org.eclipse.gmt.gems.model.intelligence.core,1.0.0,file:plug ins/org.eclipse.gmt.gems.model.intelligence.core_1.0.0.jar,4 ,false
org.eclipse.gmt.gems.model.intelligence.emf,1.0.0,file:plugi ns/org.eclipse.gmt.gems.model.intelligence.emf_1.0.0.jar,4,f alse
org.eclipse.help,3.3.100.v20080515,file:plugins/org.eclipse. help_3.3.100.v20080515.jar,4,false
org.eclipse.help.appserver,3.1.300.v20080507,file:plugins/or g.eclipse.help.appserver_3.1.300.v20080507.jar,4,false
org.eclipse.help.base,3.3.100.v20080528,file:plugins/org.ecl ipse.help.base_3.3.100.v20080528.jar,4,false
org.eclipse.help.ui,3.3.100.v20080521,file:plugins/org.eclip se.help.ui_3.3.100.v20080521.jar,4,false
org.eclipse.help.webapp,3.3.100.v20080528,file:plugins/org.e clipse.help.webapp_3.3.100.v20080528.jar,4,false
org.eclipse.hyades.analysis.engine,4.4.0.v200804221626,file: plugins/org.eclipse.hyades.analysis.engine_4.4.0.v2008042216 26/,4,false
org.eclipse.hyades.execution,4.4.200.v200806120100,file:plug ins/org.eclipse.hyades.execution_4.4.200.v200806120100/,4,fa lse
org.eclipse.hyades.execution.correlation,4.1.301.v2008020517 51,file:plugins/org.eclipse.hyades.execution.correlation_4.1 .301.v200802051751.jar,4,false
org.eclipse.hyades.execution.trace,4.1.201.v200802050400,fil e:plugins/org.eclipse.hyades.execution.trace_4.1.201.v200802 050400.jar,4,false
org.eclipse.hyades.logging.adapter,4.3.0.v200804221626,file: plugins/org.eclipse.hyades.logging.adapter_4.3.0.v2008042216 26/,4,false
org.eclipse.hyades.logging.adapter.ui,4.3.101.v200804221626, file:plugins/org.eclipse.hyades.logging.adapter.ui_4.3.101.v 200804221626.jar,4,false
org.eclipse.hyades.logging.core,4.3.200.v200804110100,file:p lugins/org.eclipse.hyades.logging.core_4.3.200.v200804110100 /,4,false
org.eclipse.hyades.logging.core.sample,4.1.201.v200802290100 ,file:plugins/org.eclipse.hyades.logging.core.sample_4.1.201 .v200802290100/,4,false
org.eclipse.hyades.logging.parsers,4.3.200.v200804221626,fil e:plugins/org.eclipse.hyades.logging.parsers_4.3.200.v200804 221626/,4,false
org.eclipse.hyades.lta.analysis.engine,4.5.0.v200805271330,f ile:plugins/org.eclipse.hyades.lta.analysis.engine_4.5.0.v20 0805271330/,4,false
org.eclipse.hyades.lta.logging.adapter,4.5.0.v200806121215,f ile:plugins/org.eclipse.hyades.lta.logging.adapter_4.5.0.v20 0806121215/,4,false
org.eclipse.hyades.lta.logging.adapter.ui,4.5.0.v20080513204 1,file:plugins/org.eclipse.hyades.lta.logging.adapter.ui_4.5 .0.v200805132041.jar,4,false
org.eclipse.hyades.lta.logging.parsers,4.5.0.v200805271330,f ile:plugins/org.eclipse.hyades.lta.logging.parsers_4.5.0.v20 0805271330/,4,false
org.eclipse.hyades.lta.resources.database,4.5.0.v20080527133 0,file:plugins/org.eclipse.hyades.lta.resources.database_4.5 .0.v200805271330/,4,false
org.eclipse.hyades.lta.sdb,4.5.0.v200806051823,file:plugins/ org.eclipse.hyades.lta.sdb_4.5.0.v200806051823/,4,false
org.eclipse.hyades.perfmon,4.3.0.v200802260919,file:plugins/ org.eclipse.hyades.perfmon_4.3.0.v200802260919.jar,4,false
org.eclipse.hyades.perfmon.agents,4.1.0.v200802260919,file:p lugins/org.eclipse.hyades.perfmon.agents_4.1.0.v200802260919 .jar,4,false
org.eclipse.hyades.probekit,4.2.300.v200806161620,file:plugi ns/org.eclipse.hyades.probekit_4.2.300.v200806161620/,4,fals e
org.eclipse.hyades.probekit.doc.user,4.2.200.v200805120832,f ile:plugins/org.eclipse.hyades.probekit.doc.user_4.2.200.v20 0805120832.jar,4,false
org.eclipse.hyades.probekit.ui,4.1.301.v200805300100,file:pl ugins/org.eclipse.hyades.probekit.ui_4.1.301.v200805300100.j ar,4,false
org.eclipse.hyades.resources.database,4.2.201.v200805231116, file:plugins/org.eclipse.hyades.resources.database_4.2.201.v 200805231116/,4,false
org.eclipse.hyades.sdb,4.3.101.v200805231116,file:plugins/or g.eclipse.hyades.sdb_4.3.101.v200805231116/,4,false
org.eclipse.hyades.statistical.ui,4.3.0.v200802260100,file:p lugins/org.eclipse.hyades.statistical.ui_4.3.0.v200802260100 /,4,false
org.eclipse.hyades.test.core,4.4.0.v200805200826,file:plugin s/org.eclipse.hyades.test.core_4.4.0.v200805200826/,4,false
org.eclipse.hyades.test.doc.user,4.3.100.v200805310100,file: plugins/org.eclipse.hyades.test.doc.user_4.3.100.v2008053101 00.jar,4,false
org.eclipse.hyades.test.tools.core,4.4.100.v200805310100,fil e:plugins/org.eclipse.hyades.test.tools.core_4.4.100.v200805 310100/,4,false
org.eclipse.hyades.test.tools.ui,4.5.0.v200805091741,file:pl ugins/org.eclipse.hyades.test.tools.ui_4.5.0.v200805091741.j ar,4,false
org.eclipse.hyades.test.ui,4.2.500.v200806131133,file:plugin s/org.eclipse.hyades.test.ui_4.2.500.v200806131133.jar,4,fal se
org.eclipse.hyades.test.ui.extensions,4.4.0.v200804190100,fi le:plugins/org.eclipse.hyades.test.ui.extensions_4.4.0.v2008 04190100.jar,4,false
org.eclipse.hyades.trace.sample,4.1.301.v200802290100,file:p lugins/org.eclipse.hyades.trace.sample_4.1.301.v200802290100 .jar,4,false
org.eclipse.hyades.trace.ui,4.4.101.v200806130100,file:plugi ns/org.eclipse.hyades.trace.ui_4.4.101.v200806130100.jar,4,f alse
org.eclipse.hyades.trace.views,4.1.501.v200806061557,file:pl ugins/org.eclipse.hyades.trace.views_4.1.501.v200806061557.j ar,4,false
org.eclipse.hyades.ui,4.2.200.v200804170100,file:plugins/org .eclipse.hyades.ui_4.2.200.v200804170100.jar,4,false
org.eclipse.jdt,3.4.0.v20080529-1300,file:plugins/org.eclips e.jdt_3.4.0.v20080529-1300.jar,4,false
org.eclipse.jdt.apt.core,3.3.100.v20080513-1235,file:plugins /org.eclipse.jdt.apt.core_3.3.100.v20080513-1235.jar,4,false
org.eclipse.jdt.apt.pluggable.core,1.0.100.v20080407-1345,fi le:plugins/org.eclipse.jdt.apt.pluggable.core_1.0.100.v20080 407-1345.jar,4,false
org.eclipse.jdt.apt.ui,3.3.100.v20080407-1345,file:plugins/o rg.eclipse.jdt.apt.ui_3.3.100.v20080407-1345.jar,4,false
org.eclipse.jdt.compiler.apt,1.0.100.v20080513-1235,file:plu gins/org.eclipse.jdt.compiler.apt_1.0.100.v20080513-1235.jar ,4,false
org.eclipse.jdt.compiler.tool,1.0.100.v_871,file:plugins/org .eclipse.jdt.compiler.tool_1.0.100.v_871.jar,4,false
org.eclipse.jdt.core,3.4.0.v_871,file:plugins/org.eclipse.jd t.core_3.4.0.v_871.jar,4,false
org.eclipse.jdt.core.manipulation,1.2.0.v20080529-1300,file: plugins/org.eclipse.jdt.core.manipulation_1.2.0.v20080529-13 00.jar,4,false
org.eclipse.jdt.debug,3.4.0.v20080529-1800,file:plugins/org. eclipse.jdt.debug_3.4.0.v20080529-1800/,4,false
org.eclipse.jdt.debug.ui,3.3.0.v20080529-1300,file:plugins/o rg.eclipse.jdt.debug.ui_3.3.0.v20080529-1300.jar,4,false
org.eclipse.jdt.doc.isv,3.4.0.v20080529-1300,file:plugins/or g.eclipse.jdt.doc.isv_3.4.0.v20080529-1300.jar,4,false
org.eclipse.jdt.doc.user,3.4.0.v20080529-1300,file:plugins/o rg.eclipse.jdt.doc.user_3.4.0.v20080529-1300.jar,4,false
org.eclipse.jdt.junit,3.4.0.v20080529-1300,file:plugins/org. eclipse.jdt.junit_3.4.0.v20080529-1300.jar,4,false
org.eclipse.jdt.junit.runtime,3.3.0.v20080529-1300,file:plug ins/org.eclipse.jdt.junit.runtime_3.3.0.v20080529-1300.jar,4 ,false
org.eclipse.jdt.junit4.runtime,1.0.200.v20080529-1300,file:p lugins/org.eclipse.jdt.junit4.runtime_1.0.200.v20080529-1300 .jar,4,false
org.eclipse.jdt.launching,3.4.0.v20080529-1300,file:plugins/ org.eclipse.jdt.launching_3.4.0.v20080529-1300.jar,4,false
org.eclipse.jdt.ui,3.4.0.v20080529-1300,file:plugins/org.ecl ipse.jdt.ui_3.4.0.v20080529-1300.jar,4,false
org.eclipse.jem,2.0.200.v200806051600,file:plugins/org.eclip se.jem_2.0.200.v200806051600.jar,4,false
org.eclipse.jem.beaninfo,2.0.100.v200806051600,file:plugins/ org.eclipse.jem.beaninfo_2.0.100.v200806051600.jar,4,false
org.eclipse.jem.proxy,2.0.100.v200806051600,file:plugins/org .eclipse.jem.proxy_2.0.100.v200806051600.jar,4,false
org.eclipse.jem.ui,2.0.100.v200806051600,file:plugins/org.ec lipse.jem.ui_2.0.100.v200806051600.jar,4,false
org.eclipse.jem.util,2.0.100.v200805140020,file:plugins/org. eclipse.jem.util_2.0.100.v200805140020.jar,4,false
org.eclipse.jem.workbench,2.0.100.v200806051600,file:plugins /org.eclipse.jem.workbench_2.0.100.v200806051600.jar,4,false
org.eclipse.jface,3.4.0.I20080528-2000,file:plugins/org.ecli pse.jface_3.4.0.I20080528-2000.jar,4,false
org.eclipse.jface.databinding,1.2.0.I20080515-2000a,file:plu gins/org.eclipse.jface.databinding_1.2.0.I20080515-2000a.jar ,4,false
org.eclipse.jface.text,3.4.0.v20080529-1300,file:plugins/org .eclipse.jface.text_3.4.0.v20080529-1300.jar,4,false
org.eclipse.jpt.core,2.0.0.v200805220000,file:plugins/org.ec lipse.jpt.core_2.0.0.v200805220000.jar,4,false
org.eclipse.jpt.db,1.1.1.v200805020000,file:plugins/org.ecli pse.jpt.db_1.1.1.v200805020000.jar,4,false
org.eclipse.jpt.db.ui,1.0.1.v200805020000,file:plugins/org.e clipse.jpt.db.ui_1.0.1.v200805020000.jar,4,false
org.eclipse.jpt.doc.user,1.0.100.v200805280000,file:plugins/ org.eclipse.jpt.doc.user_1.0.100.v200805280000.jar,4,false
org.eclipse.jpt.gen,1.1.0.v200805020000,file:plugins/org.ecl ipse.jpt.gen_1.1.0.v200805020000.jar,4,false
org.eclipse.jpt.ui,2.0.0.v200806050000,file:plugins/org.ecli pse.jpt.ui_2.0.0.v200806050000.jar,4,false
org.eclipse.jpt.utility,1.2.0.v200805140000,file:plugins/org .eclipse.jpt.utility_1.2.0.v200805140000.jar,4,false
org.eclipse.jsch.core,1.1.100.I20080415,file:plugins/org.ecl ipse.jsch.core_1.1.100.I20080415.jar,4,false
org.eclipse.jsch.ui,1.1.100.I20080415,file:plugins/org.eclip se.jsch.ui_1.1.100.I20080415.jar,4,false
org.eclipse.jst,1.0.100.v200805140017,file:plugins/org.eclip se.jst_1.0.100.v200805140017.jar,4,false
org.eclipse.jst.common.annotations.controller,1.1.100.v20080 5140020,file:plugins/org.eclipse.jst.common.annotations.cont roller_1.1.100.v200805140020.jar,4,false
org.eclipse.jst.common.annotations.core,1.1.100.v20080514002 0,file:plugins/org.eclipse.jst.common.annotations.core_1.1.1 00.v200805140020.jar,4,false
org.eclipse.jst.common.annotations.ui,1.1.102.v200806010600, file:plugins/org.eclipse.jst.common.annotations.ui_1.1.102.v 200806010600.jar,4,false
org.eclipse.jst.common.frameworks,1.1.200.v200805140020,file :plugins/org.eclipse.jst.common.frameworks_1.1.200.v20080514 0020.jar,4,false
org.eclipse.jst.common.project.facet.core,1.3.0.v20080515190 3,file:plugins/org.eclipse.jst.common.project.facet.core_1.3 .0.v200805151903.jar,4,false
org.eclipse.jst.common.project.facet.ui,1.3.0.v200805092201, file:plugins/org.eclipse.jst.common.project.facet.ui_1.3.0.v 200805092201.jar,4,false
org.eclipse.jst.ejb.doc.user,1.1.0.v200805152320,file:plugin s/org.eclipse.jst.ejb.doc.user_1.1.0.v200805152320.jar,4,fal se
org.eclipse.jst.ejb.ui,1.1.200.v200805292155,file:plugins/or g.eclipse.jst.ejb.ui_1.1.200.v200805292155.jar,4,false
org.eclipse.jst.ejb.ui.infopop,1.0.100.v200805222207,file:pl ugins/org.eclipse.jst.ejb.ui.infopop_1.0.100.v200805222207/, 4,false
org.eclipse.jst.j2ee,1.1.200.v200806051600,file:plugins/org. eclipse.jst.j2ee_1.1.200.v200806051600.jar,4,false
org.eclipse.jst.j2ee.core,1.1.200.v200806052000,file:plugins /org.eclipse.jst.j2ee.core_1.1.200.v200806052000.jar,4,false
org.eclipse.jst.j2ee.doc.user,1.1.0.v200805281506,file:plugi ns/org.eclipse.jst.j2ee.doc.user_1.1.0.v200805281506.jar,4,f alse
org.eclipse.jst.j2ee.ejb,1.1.200.v200806041500,file:plugins/ org.eclipse.jst.j2ee.ejb_1.1.200.v200806041500.jar,4,false
org.eclipse.jst.j2ee.ejb.annotation.model,1.1.102.v200805140 020,file:plugins/org.eclipse.jst.j2ee.ejb.annotation.model_1 .1.102.v200805140020.jar,4,false
org.eclipse.jst.j2ee.ejb.annotations.emitter,1.1.102.v200805 140135,file:plugins/org.eclipse.jst.j2ee.ejb.annotations.emi tter_1.1.102.v200805140135.jar,4,false
org.eclipse.jst.j2ee.ejb.annotations.ui,1.1.102.v20080514002 0,file:plugins/org.eclipse.jst.j2ee.ejb.annotations.ui_1.1.1 02.v200805140020.jar,4,false
org.eclipse.jst.j2ee.ejb.annotations.xdoclet,1.2.0.v20080514 0020,file:plugins/org.eclipse.jst.j2ee.ejb.annotations.xdocl et_1.2.0.v200805140020.jar,4,false
org.eclipse.jst.j2ee.infopop,1.0.300.v200805140415,file:plug ins/org.eclipse.jst.j2ee.infopop_1.0.300.v200805140415.jar,4 ,false
org.eclipse.jst.j2ee.jca,1.1.200.v200806041500,file:plugins/ org.eclipse.jst.j2ee.jca_1.1.200.v200806041500.jar,4,false
Re: P2 always strange match error. How to update P2? [message #117689 is a reply to message #116543] Thu, 18 September 2008 17:15 Go to previous messageGo to next message
Hi all,
got the same problem that you it seems,
when I try to update my custom plugin added eclipse ganymede it give
always the same error, but only from 2/3 days :
Cannot complete the request. See the details.
Cannot find a solution satisfying the following requirements
Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.gmf.runtime.emf.comman ds.core/[1.1.0.v20080425-1959,1.1.0.v20080425-1959]].
So i think the error come from milyn when i try to update one of them :
-Mylyn Bridge : Eclipse IDE
-Mylyn Bridge : Java Development
-Mylyn Bridge : Plug-in Development
-Mylyn Bridge : Team Support
-Mylyn Connector : Bugzilla
-Mylyn Focused UI (Recommended)
-Mylyn Task List(Required)
Anyone have a solution or a way to fix it ??
Thank's in advance
Hauke Fuhrmann a écrit :
> Simon Kaegi wrote:
>> On the face of it looks like both of you are trying to update something from
>> Web Tools and it appears one of the features is mis-specifying it's
>> requirements. Can you guys provide more details on what's installed and what
>> you're trying to do?
> I've a standard Ganymede install with especially lot of modeling stuff
> and Subversive. In the "Installed Software" there are no Web Tools
> listed at all.
> I get the error if I open the P2 Gui and simply press the "update"
> button. Then this error is displayed for every component to be updated,
> e.g. "Graphical Modeling Framework SDK" or "Subversive SVN Connectors"
> or "Graphical Modeling Framework Documentation" and every other package
> that can be updated.
> This also happens if I select *only one* of the items in the "Installed
> Software" tab and try to update only that.
> As I'm not familiar at all with p2, I don't know what you need to see of
> my configuration. I have attached my "bundles.info", which I understand
> to hold all plugins that are installed...
> Hauke
Re: P2 always strange match error. How to update P2? [message #117701 is a reply to message #117689] Thu, 18 September 2008 17:43 Go to previous messageGo to next message
Ok I answer to myself,
for the person like who's searching the solution to update the mylyn
plugin from the eclipse 3.4 Ganymede :
-I gone to the website of the project http://www.eclipse.org/mylyn/
-After i go to Downloads
-Then I choose the package from the 2.3.2 (the 3.0.1 doesn't seems to be
ready to download) and download the :
download.eclipse.org/tools/mylyn/update-archive/2.3.2/v20080 402-2100/e3.4
(Eclipse 3.4M6)
after extract the package in my eclipse repository
-In the end i just launch eclipse (with --clean) and make a new upgrade,
all the last package were here, and no more error message.
I hope it will help someone.
Peace
Darkshaman
darkshaman a écrit :
> Hi all,
> Thank's in advance
>>> something from Web Tools and it appears one of the features is
>>> mis-specifying it's requirements. Can you guys provide more details
>>> on what's installed and what you're trying to do?
>> listed at all.
>> Regards,
>> Hauke
Re: P2 always strange match error. How to update P2? [message #122383 is a reply to message #117701] Wed, 10 December 2008 02:55 Go to previous messageGo to next message
Originally posted by: markus.franz.kapelan.com
H all,
i am sorry to dig out this old thread, but i have got a similar problem
and the suggested solution (that it might be mylyn and to manually copy
a recent mylyn update in the eclipse installation) did not work for me.
The problem is that whenever i try to update anything (it seems to
happen with every feature, for which an update is found), p2 pops up the
following (always identical) error message and refuses to update anything:
"Cannot find a solution satisfying the following requirements
org.eclipse.equinox.p2.iu/org.eclipse.jst.enterprise_core.fe ature.feature.jar/[3.0.3.v200810010400-42E_4_kE77c_FAP7X99,3 .0.3.v200810010400-42E_4_kE77c_FAP7X99]]. "
I noticed the double "feature" in the filename and this is no typo, i
copied it directly from the error log. I suspect a false dependency
entry in some of my running plugins, but i have not (yet) dug into p2
deep enough to find out where exactly this unsatisfiable dependency
comes from. I would be glad for any suggestions.
By the way: i am primarily trying to update the SVN conectors, but i
don't think that this has anything to do with my problems.
Markus
Re: P2 always strange match error. How to update P2? [message #125627 is a reply to message #122383] Mon, 09 February 2009 03:16 Go to previous messageGo to next message
I was having a similar problem. It went away when I went to the 'Installed
Software' tab and clicked update. I also installed the available patches
first - I do not know whether that may have made a difference.
Re: P2 always strange match error. How to update P2? [message #126076 is a reply to message #122383] Fri, 20 February 2009 09:30 Go to previous message
This is a known bug in p2. See my blog for a workaround:
http://darkviews.blogspot.com/2008/09/installing-eclipse-341 -despite-p2.html
Previous Topic:[Fwd: Re: [p2] Can i somehow "reset" p2?]
Next Topic:P2 pain - Installing into WID 6.2 (Eclipse 3.4.1)
Current Time: Mon Jul 21 23:56:50 EDT 2025
Powered by FUDForum. Page generated in 0.11005 seconds
