Home » Archived » Test and Performance Tools Platform (TPTP) » Xerces problem when profiling Tomcat
Xerces problem when profiling Tomcat [message #116440] Mon, 29 October 2007 06:07 Go to next message
Originally posted by: svileng.gmail.com
I'm tryng to profile a web application running on Tomcat 5.5.20 using
AgentController 4.4.0.0.
What is happening exactly is when I start the tomcat server with
"-agentlib:JPIBootLoader=JPIAgent:server=enabled;CGProf" It starts to some
point and then error message like this is displayed:
"[Error: EC JPIAgent received message (FATAL ERROR): Internal error (see
log file).]".
This message is not very informative so I turned on MARTINI logger with
debug level.
What I saw at the end of the log file was like this:
Informative 10/29/07 09:48:42 4740 5 CJVMTIInterface ClassPrepare event
received: class = 'Lorg/apache/xerces/impl/xs/XMLSchemaValidator;',
generic = '(null)'
Error 10/29/07 09:48:42 4740 0 CDataManager File: DataManager.cpp (Line:
1568) condition failed: uiJVMPIMethodIndex < uiJVMPINumMethods
So I assumed that this is related to a problem during instrumentation of
xerces distribution I use with Tomcat (I just have a xercesImpl.jar in
<tomcat_dir>\common\lib). Removing xerces is not an option of course.
I looked up at the agent controller documentation an discovered that there
is filtering of which classes to be included/excluded but It doesn't seems
to work. I've placed filters.txt in the tomcat/bin directory (which should
be the current working dir) but I'm still getting the same error.
Anyway, according the documentation, the filter should be available only
to "standalone" mode and I really would like to use "enabled" mode.
Makes me wonder hasn't anybody profiled and application using xerces ,
because I wasn't able to find anything on the subject over the internet.
I have this problem for several days now and Its driving me crazy.
Please help!
Re: Xerces problem when profiling Tomcat [message #116693 is a reply to message #116440] Mon, 29 October 2007 20:20 Go to previous messageGo to next message
Can you share your filters.txt file?
I have profiled things with xerces before but not things with multiple
versions of xerces.
Thx,
Chris
Re: Xerces problem when profiling Tomcat [message #116730 is a reply to message #116693] Tue, 30 October 2007 04:44 Go to previous messageGo to next message
Hi Chris,
Hmm, perhaps I didn't make myself clear - I'm using single version of
xerces(2.5.0 to be precise) not multiple...And It's located in
<tocmat_dir>\common\lib
As for the filters.txt here It is, I just copied It from
<Agent_Controller_install_dir>\Resources\filters.txt:
java* * EXCLUDE
sun* * EXCLUDE
com.sun.* * EXCLUDE
com.ibm.* * EXCLUDE
org.eclipse.* * EXCLUDE
org.apache.* * EXCLUDE
org.w3c.* * EXCLUDE
org.xml.* * EXCLUDE
javax.xml.parsers.* * EXCLUDE
Svilen
Re: Xerces problem when profiling Tomcat [message #116754 is a reply to message #116440] Tue, 30 October 2007 14:34 Go to previous messageGo to next message
I have tested some simple apps that enable schema validation with Xerces
2.5.0 and see no issues. I've run in both enabled and standalone mode
without filtering out xerces... My trcxml file reports that it is
successfully loaded/instrumented. It works for me with both TPTP 4.4.0
and 4.4.0.3.
<classDef name="org/apache/xerces/impl/xs/XMLSchemaValidator"
sourceName="&lt;Unknown&gt;" classId="541" time="1193768184.783088731"/>
<methodDef name="-clinit-" signature="()V" startLineNumber="0"
endLineNumber="0" methodId="71665" classIdRef="541"/>
<methodEntry threadIdRef="3" time="1193768184.783149354"
methodIdRef="71665" classIdRef="541" ticket="119071" stackDepth="8"/>
<methodExit threadIdRef="3" methodIdRef="71665" classIdRef="541"
ticket="119071" time="1193768184.783217519"/>
set TPTP_AC_HOME=C:\utils\eclipseAC440
set
JAVA_PROFILER_HOME=C:\utils\eclipseAC440\plugins\org.eclipse .tptp.javaprofiler
set PATH=%PATH%;%JAVA_PROFILER_HOME%;%TPTP_AC_HOME%\bin
set JVM=C:\java\sun50_09_jre\bin\java
set CLASSPATH=xercesImpl.jar;xercesSamples.jar
%JVM% %AGENT% sax.Counter -s data/personal.xml
where agent is set to one of the following three options:
set AGENT=-agentlib:JPIBootLoader=JPIAgent:server=standalone;CGP rof
set AGENT=-agentlib:JPIBootLoader=JPIAgent:server=enabled;CGProf
set
AGENT=-agentlib:JPIBootLoader=JPIAgent:server=standalone;CGP rof:execdetails=true
With verbose Martini, I get log messages of the form:
Informative 10/30/07 18:29:03 2452 5 CJVMTIInterface ClassPrepare event
received: class = 'Lorg/apache/xerces/xni/parser/XMLInputSource;', generic
= '(null)'
Informative 10/30/07 18:29:03 2452 5 CJVMTIInterface [ClassFileLoadHookHandler]
I
I do not see the errors that you have.
the md5sum of my Xerces impl jar (binary release from Apache) is
17c7b058d32d6df45456e1728a299ba1 *xercesImpl.jar
Re: Xerces problem when profiling Tomcat [message #116854 is a reply to message #116440] Wed, 31 October 2007 06:49 Go to previous message
Svilen Genchev wrote:
> Hello,
> some point and then error message like this is displayed:
> log file).]".
> debug level. What I saw at the end of the log file was like this:
> ClassPrepare event received: class =
> 'Lorg/apache/xerces/impl/xs/XMLSchemaValidator;', generic = '(null)'
> DataManager.cpp (Line: 1568) condition failed: uiJVMPIMethodIndex <
> uiJVMPINumMethods
This seems like a bug in JVMTI Runtime. Please open a Bugzilla for the
TPTP Project, Profiler component at http://bugs.eclipse.org/bugs
Make sure to include this information in the bug details, along with the
OS, Eclipse, TPTP and Java versions you are using.
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Previous Topic:How to get more info...
Next Topic:EclipseCon 2008: 2 1/2 weeks remaining to propose a talk or tutorial!
Current Time: Wed Aug 13 12:19:25 EDT 2025
Powered by FUDForum. Page generated in 0.03882 seconds
