Home » Eclipse Projects » Eclipse Platform » Eclipse View & CTabFolder w/1 Item
Eclipse View & CTabFolder w/1 Item [message #116435] Mon, 25 August 2003 17:07 Go to next message
Originally posted by: ians.rgbcoolege.com
When using the Eclipse IDE and a view window has only 1 item it in, there is
no tab display.
I'm not very clear on the terminology to use, but:
Example: When a box/window of the eclipse IDE has "Package Explorer" and
nothing else, the box/window has no tab listing.
When I drag/drop another View onto it (like "Outline") the tabs show up (on
the bottom "Package Explorer|Outline")
Is this a CTabFolder? How can I have my CTabFolder NOT show the tabs when
there is only one CTabItem in it? I am trying to make a "window" with the
CTabFolder shadow outline, but no tab display.
Re: Eclipse View & CTabFolder w/1 Item [message #116653 is a reply to message #116435] Tue, 26 August 2003 13:46 Go to previous messageGo to next message
Originally posted by: veronika_irvine.oti.com
CTabFolder will always show a tab if it has one item or more.
Eclipse does not have a CTabFolder when there is only one view. The
CTabFolder is not created until there is more than one view stacked.
Note: Views in Eclipse are not children of the CTabFolder. They are merely
positioned over the CTabFolder client area.
"L. Iansbrook" <ians@rgbcoolege.com> wrote in message
news:bidtp4$jq9$1@eclipse.org...
is
> no tab display.
(on
Re: Eclipse View & CTabFolder w/1 Item [message #116677 is a reply to message #116435] Tue, 26 August 2003 13:59 Go to previous messageGo to next message
Look at the source for the Package Explorer????
is
> no tab display.
(on
Re: Eclipse View & CTabFolder w/1 Item [message #117583 is a reply to message #116653] Wed, 27 August 2003 15:41 Go to previous messageGo to next message
I have used "setTabHeight(0)" which seems to make the tabs disappear, but I'm
sure this is wrong since the API docs say "Specifying a height of 0 will
revert to the default height." which doesn't seem to be true. (win&gtk 2.1.1)
I'm still not sure how to make a composite with a shadow outline without
placing that composite as child of a CTabItem within a CTabFolder.
I've tried scanning the source of "plugins/org.eclipse.ui.workbench/Eclipse
UI/org/eclipse/ui" but am not sure what I'm looking for..
"Veronika Irvine" <veronika_irvine@oti.com> wrote in message
news:big6cf$jtv$1@eclipse.org...
> is
> > no tab display.
> (on
Re: Eclipse View & CTabFolder w/1 Item [message #118727 is a reply to message #117583] Thu, 28 August 2003 09:58 Go to previous message
You can use org.eclipse.swt.custom.ViewForm.
news:bij1hh$aa1$1@eclipse.org...
I'm
2.1.1)
merely
there
> > is
> > > no tab display.
and
up
> > (on
when
the
Previous Topic:Skipping builder...
Next Topic:Plug-in can't connect to server
Current Time: Fri Jul 18 10:44:59 EDT 2025
Powered by FUDForum. Page generated in 0.29766 seconds
