Home » Eclipse Projects » Equinox » Help finding javax.ws and javax.xml components
Help finding javax.ws and javax.xml components [message #116389] |
Fri, 22 August 2008 07:44  |
Originally posted by: bcox.virtualschool.edu
I seem to be stuck on this problem and really need some help. This is my
first OSGI project so I still have a tenuous grasp of the relationships
between OSGI, Maven2, Eclipse, Maven plugins, MANIFEST.MF and the
Eclipse PDE tools. The fundamental problem is this for one of my bundles:
Direct constraints which are unresolved:
Missing imported package javax.jws_0.0.0.
Missing imported package javax.xml.bind_0.0.0.
Missing imported package javax.xml.bind.annotation_0.0.0.
Missing imported package javax.xml.ws_0.0.0.
My application is a dataflow system with a half-dozen or so modules. One
of these, PEP, is a policy enforcement point based on OpenSSO. To get
started, I compiled the IdSvcsClient tutorial in Netbeans and copied the
generated source code into Eclipse, then used the intructions at
http://mohanrajk.wordpress.com/2006/12/03/maven-2-jax-ws-ri- and-tomcat-deploy-part-i/
to create a local repository (local.com.sun...) with the dependencies.
The problem is, these work at compile time (the project compiles
correctly in eclipse and with mvn install) but the four bundles listed
above aren't being found at startup time. Everything else loads fine
except for my test module which (I think) fails because it depends on
the PEP.
Can someone please help?
Here's more startup details. I'm launching this in Eclipse debugger for now:
Configuration location:
file:/SoftwareDevelopment/workspace/.metadata/.plugins/org.e clipse.pde.core/SOAKIT/
Configuration file:
file:/SoftwareDevelopment/workspace/.metadata/.plugins/org.e clipse.pde.core/SOAKIT/config.ini
loaded
Install location:
file:/Applications/eclipse-3.5m1/
Framework located:
file:/Applications/eclipse-3.5m1/plugins/org.eclipse.osgi_3. 5.0.v20080804-1730.jar
Framework classpath:
Debug options:
file:/SoftwareDevelopment/workspace/.metadata/.plugins/org.e clipse.pde.core/SOAKIT/.options
loaded
osgi> Time to load bundles: 100
XSLT Activator: Starting to listen for service events.
Core start()
IDENT Activator: Starting to listen for service events.
FILE Activator: Starting to listen for service events.
HTTP Activator: Starting to listen for service events.
LOG Activator: Starting to listen for service events.
ss
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.5.0.v20080804-1730
12 ACTIVE javax.xml_1.3.4.v200806030440
22 ACTIVE javax.servlet_2.4.0.v200806031604
87 ACTIVE soakit-transform-xsl_1.0.0.SNAPSHOT
95 ACTIVE com.gestalt.soakit.core_1.0.0.SNAPSHOT
96 ACTIVE soakit-transform-identity_1.0.0.SNAPSHOT
97 INSTALLED com.gestalt.soakit.test_1.0.0.SNAPSHOT
98 ACTIVE soakit-port-file_1.0.0.SNAPSHOT
99 ACTIVE com.gestalt.soakit.port.http_1.0.0.SNAPSHOT
100 ACTIVE soakit-transform-log_1.0.0.SNAPSHOT
101 ACTIVE soakit_1.0.0
106 INSTALLED soakit-transform-pep_1.0.0.SNAPSHOT
osgi> start 106
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Import-Package: javax.jws; version="0.0.0"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:303)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:267)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:259)
org.eclipse.osgi.framework.internal.core.FrameworkCommandPro vider._start(FrameworkCommandProvider.java:254)
org.eclipse.osgi.framework.internal.core.FrameworkCommandInt erpreter.execute(FrameworkCommandInterpreter.java:150)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.do command(FrameworkConsole.java:302)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.co nsole(FrameworkConsole.java:287)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.ru n(FrameworkConsole.java:223)
at java.lang.Thread.run(Thread.java:613)
osgi> diag 106
initial@reference :file:../../SoftwareDevelopment/Projects/soakit/soakit-trans form/soakit-transform-pep/
[106]
Here's the PEP's POM (ask it you need its parent chain)
<project>
<modelVersion>4.0.0</modelVersion>
<groupId>soakit</groupId>
<artifactId>soakit-transform-pep</artifactId>
<packaging>bundle</packaging>
<name>soakit-transform-pep</name>
<version>1.0-SNAPSHOT</version>
<description>OpenSSO Policy Enforcement Point Transform</description>
<parent>
<artifactId>soakit-transform</artifactId>
</parent>
<dependencies>
<dependency>
<groupId>local.sun.java.net</groupId>
<artifactId>jaxws-ri</artifactId>
<version>2.1-EA3-SNAPSHOT</version>
<type>pom</type>
</dependency>
<dependency>
<groupId>javax.jws</groupId>
<artifactId>jsr181</artifactId>
<version>1.0</version>
</dependency>
</dependencies>
<build>
<resources>
<resource>
<directory>src/main/resources</directory>
</resource>
<resource>
<directory>.</directory>
<includes>
<include>plugin.xml</include>
</includes>
</resource>
</resources>
<plugins>
<plugin>
<groupId>org.apache.felix</groupId>
<artifactId>maven-bundle-plugin</artifactId>
<version>1.2.0</version>
<extensions>true</extensions>
<configuration>
<manifestLocation>META-INF</manifestLocation>
<instructions>
<Bundle-Version>${pom.version}</Bundle-Version>
<Bundle-SymbolicName>com.gestalt.soakit.transform.pep</Bundle-SymbolicName >
<Export-Package>com.gestalt.soakit.transform.pep.*;version= "${pom.version}"</Export-Package>
<Private-Package>com.gestalt.*</Private-Package>
<Bundle-Activator>com.gestalt.soakit.transform.pep.Activator </Bundle-Activator>
<Embed-Dependency>*;scope=compile|runtime;inline=false</Embed-Dependency >
<Embed-Directory>target/dependency</Embed-Directory>
</instructions>
</configuration>
</plugin>
<plugin>
<artifactId>maven-dependency-plugin</artifactId>
<executions>
<execution>
<id>copy-dependencies</id>
<phase>package</phase>
<goals>
<goal>copy-dependencies</goal>
</goals>
</execution>
</executions>
</plugin>
</plugins>
</build>
</project>
The jsr181 entry is guesswork. There seem to be several of these out
there, one from BEA and another in the jaxws-ri collection. They're
completely different inside.
Here's META-INF/MANIFEST.MF as produced by eclipse PDE Tools/Organize
Manifests (I really don't understand how this tool relates to editing
the POM vs editing MANIFEST.MF, and why com.gestalt.soakit.transform.pdp
keeps reappearing under Export-Package; this is a proxy for the PDP that
should be private to the PEP right now. I specifically excluded that
with <Private-Package>com.gestalt.*</Private-Package> above. I usually
fix that by editing MANIFEST.MF by hand before running.
Manifest-Version: 1.0
Built-By: bradcox
Created-By: Apache Maven Bundle Plugin
Bundle-Activator: com.gestalt.soakit.transform.pep.Activator
Import-Package: javax.jws,
javax.xml.bind,
javax.xml.bind.annotation,
javax.xml.namespace,
javax.xml.ws,
org.osgi.framework;version="1.3"
Bnd-LastModified: 1219153025015
Export-Package: com,
com.gestalt,
com.gestalt.soakit;x-internal:=true,
com.gestalt.soakit.transform;x-internal:=true,
com.gestalt.soakit.transform.pdp;x-internal:=true,
com.gestalt.soakit.transform.pep;version="1.0.0.SNAPSHOT";x-internal:=true;
uses:="com.gestalt.soakit.transform.pdp,
org.jdom.input,
org.osgi.framework,
org.jdom,
javax.jws,
com.gestalt.soakit.core"
Bundle-Version: 1.0.0.SNAPSHOT
Bundle-Name: soakit-transform-pep
Bundle-Description: OpenSSO Policy Enforcement Point Transform
Build-Jdk: 1.5.0_13
Private-Package: com.gestalt.soakit.core,com.gestalt.soakit.transform.
pdp
Bundle-ManifestVersion: 2
Bundle-SymbolicName: soakit-transform-pep;singleton:=true
Tool: Bnd-0.0.227
Bundle-ClassPath: .
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Obviously I'm confused about something. Can someone please help?
Re: Help finding javax.ws and javax.xml components [message #116418 is a reply to message #116389] |
Fri, 22 August 2008 12:44   |
Did this get thru? Could someone please respond? Thanks!
> the PEP.
> now:
> Configuration file:
> loaded
> Install location:
> Framework located:
> Debug options:
> loaded
> Core start()
> ss
> id State Bundle
> osgi> start 106
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> osgi> diag 106
> [106]
> <project>
> <parent>
> </parent>
> <dependencies>
> <dependency>
> <type>pom</type>
> </dependency>
> <dependency>
> </dependency>
> </dependencies>
> <build>
> <resources>
> <resource>
> </resource>
> <resource>
> <includes>
> </includes>
> </resource>
> </resources>
> <plugins>
> <plugin>
> <configuration>
> <instructions>
> </instructions>
> </configuration>
> </plugin>
> <plugin>
> <executions>
> <execution>
> <goals>
> </goals>
> </execution>
> </executions>
> </plugin>
> </plugins>
> </build>
> </project>
> Built-By: bradcox
> javax.xml.bind,
> javax.xml.ws,
> com.gestalt,
> org.jdom.input,
> org.osgi.framework,
> org.jdom,
> javax.jws,
> Build-Jdk: 1.5.0_13
> pdp
> Tool: Bnd-0.0.227
> Bundle-ClassPath: .
Re: Help finding javax.ws and javax.xml components [message #116451 is a reply to message #116389] |
Sat, 23 August 2008 13:31   |
Thanks to everyone who responded (no one). I figured it out.
> the PEP.
> now:
> Configuration file:
> loaded
> Install location:
> Framework located:
> Debug options:
> loaded
> Core start()
> ss
> id State Bundle
> osgi> start 106
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> osgi> diag 106
> [106]
> <project>
> <parent>
> </parent>
> <dependencies>
> <dependency>
> <type>pom</type>
> </dependency>
> <dependency>
> </dependency>
> </dependencies>
> <build>
> <resources>
> <resource>
> </resource>
> <resource>
> <includes>
> </includes>
> </resource>
> </resources>
> <plugins>
> <plugin>
> <configuration>
> <instructions>
> </instructions>
> </configuration>
> </plugin>
> <plugin>
> <executions>
> <execution>
> <goals>
> </goals>
> </execution>
> </executions>
> </plugin>
> </plugins>
> </build>
> </project>
> Built-By: bradcox
> javax.xml.bind,
> javax.xml.ws,
> com.gestalt,
> org.jdom.input,
> org.osgi.framework,
> org.jdom,
> javax.jws,
> Build-Jdk: 1.5.0_13
> pdp
> Tool: Bnd-0.0.227
> Bundle-ClassPath: .
Current Time: Wed Aug 13 12:19:38 EDT 2025
Powered by FUDForum. Page generated in 0.05047 seconds
