Home » Archived » Visual Editor (VE) » VE in Eclipse 3.1.2 (Linux)
VE in Eclipse 3.1.2 (Linux) [message #116204] Sat, 28 January 2006 14:53 Go to next message
Originally posted by: nunogt.gmail.com
Hi all,
I'm sorry if this is a stupid question, but despite my recent efforts I
was unable to install VE and its required pacakges in the latest stable
version o eclipse (3.1.2) in Linux (2.6.13 kernel). The packages simply
won't show up in the "Find and Install" dialog. DO I have to provide an
alternate URL? I'm using the Eclipse Update site, as recommended in the
documentation and FAQ.
Re: VE in Eclipse 3.1.2 (Linux) [message #116218 is a reply to message #116204] Sat, 28 January 2006 19:29 Go to previous messageGo to next message
Originally posted by: nospamplease_enrictordera.vodafone.es
"nunogt" <nunogt@gmail.com> escribi
Re: VE in Eclipse 3.1.2 (Linux) [message #116230 is a reply to message #116218] Mon, 30 January 2006 09:51 Go to previous messageGo to next message
Hi, thanks for replying.
I eventually managed to install it using other projects' update sites,
such as Web tools ( http://download.eclipse.org/webtools/updates/ ) and
EMF ( http://download.eclipse.org/tools/emf/updates/ ). This is a pain in
the ass, though. I had to manually find what the VE dependencies are and
search for alternate update sites. If you could somehow report this
problem to the main update site staff so they can fix it it'd be a lot
easier. None of eclipse's subprojects currently show up in the update
list, and this includes VE, UML2, GEF, EMF, and so on...
Re: VE in Eclipse 3.1.2 (Linux) [message #116278 is a reply to message #116230] Mon, 30 January 2006 16:31 Go to previous messageGo to next message
Re: VE in Eclipse 3.1.2 (Linux) [message #116288 is a reply to message #116278] Mon, 30 January 2006 16:47 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Does any VE show? It should show VE 1.1 if this is a clean install. This
is because the main Eclipse update site only has VE 1.1 on it. However,
once VE 1.1 is installed you should be able to see VE 1.1.0.1 as a valid
update to VE 1.1. This is because VE 1.1 has the correct control info to
point to where fix packs for VE 1.1 can be found.
Enric Tordera wrote:
> "nunogt" <nunogt@gmail.com> escribió en el mensaje
> news:49f4ed2f13b926734d2874175a6b4fa0$1@www.eclipse.org...
> I can't understand why VE was so accessible in "Find and Install" in version
> 3.1.1 and now it is gone. Also, I don't know how to contact the right person
> to take care of that, I hope someone who knows that reads this posts ...
> Bye,
> - Enric
Rich Kulp
Re: VE in Eclipse 3.1.2 (Linux) [message #116858 is a reply to message #116288] Fri, 03 February 2006 07:12 Go to previous messageGo to next message
It's a clean install. I just downloaded the linux package, extracted it to
my home dir, and start using it right away. There're no permission
problems as far as I can see, and everything but the update site is
working as expected. Maybe I didn't stress this enough, but none of the
subprojects listed at http://www.eclipse.org/tools/ show. It isn't just
VE. VE happens to be the one I find more useful, hence the posts in this
newsgroup (I didn't know where to report this problem). There are no
updates available either. I just did a Find and Install | Search for
updates of the currently installed features, and nothing show up from
eclise main update site.
Re: VE in Eclipse 3.1.2 (Linux) [message #116962 is a reply to message #116204] Mon, 06 February 2006 02:16 Go to previous message
Originally posted by: news.TillHeinrich.de
Hi!
I hope my problem was a similar one... though I'm using windows...
Can you spot any feature at all? disable "Show the latest version of a feature only", download and install everything you can find.
In my case it were WebDav and FPT... after I installed both of them I had received a second download-site which offered all the expected extensions.
Now everything seems to be as it was...
Till -v
Re: VE in Eclipse 3.1.2 (Linux) [message #611894 is a reply to message #116204] Sat, 28 January 2006 19:29 Go to previous message
Re: VE in Eclipse 3.1.2 (Linux) [message #611895 is a reply to message #116218] Mon, 30 January 2006 09:51 Go to previous message
Re: VE in Eclipse 3.1.2 (Linux) [message #611899 is a reply to message #116230] Mon, 30 January 2006 16:31 Go to previous message
Re: VE in Eclipse 3.1.2 (Linux) [message #611900 is a reply to message #116278] Mon, 30 January 2006 16:47 Go to previous message
> Bye,
> - Enric
Rich Kulp
Re: VE in Eclipse 3.1.2 (Linux) [message #611961 is a reply to message #116288] Fri, 03 February 2006 07:12 Go to previous message
Re: VE in Eclipse 3.1.2 (Linux) [message #611969 is a reply to message #116204] Mon, 06 February 2006 02:16 Go to previous message
Hi!
Till -v
Previous Topic:JFace in VE
Next Topic:Installing VE in WTP 3.1 Eclipse
Current Time: Sun May 11 13:09:36 EDT 2025
Powered by FUDForum. Page generated in 0.03778 seconds
